root/radiance/ray/src/gen/gendaymtx.c
Revision: 2.5
Committed: Sun Jan 20 01:16:49 2013 UTC (11 years, 4 months ago) by greg
Fixed usage reporting
2 static const char RCSid[] = "$Id: gendaymtx.c,v 2.4 2013/01/20 01:16:15 greg Exp $";
5 * gendaymtx.c
6 *
7 * Generate a daylight matrix based on Perez Sky Model.
8 *
9 * Most of this code is borrowed (see copyright below) from Ian Ashdown's
10 * excellent re-implementation of Jean-Jacques Delaunay's gendaylit.c
11 *
12 * Created by Greg Ward on 1/16/13.
13 */
14
15 /*********************************************************************
16 *
17 * H32_gendaylit.CPP - Perez Sky Model Calculation
18 *
19 * Version: 1.00A
20 *
21 * History: 09/10/01 - Created.
22 * 11/10/08 - Modified for Unix compilation.
23 * 11/10/12 - Fixed conditional __max directive.
24 * 1/11/13 - Tweaks and optimizations (G.Ward)
25 *
26 * Compilers: Microsoft Visual C/C++ Professional V10.0
27 *
28 * Author: Ian Ashdown, P.Eng.
29 * byHeart Consultants Limited
30 * 620 Ballantree Road
31 * West Vancouver, B.C.
32 * Canada V7S 1W3
33 * e-mail: [email protected]
34 *
35 * References: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R.
36 * Stewart. 1990. ìModeling Daylight Availability and
37 * Irradiance Components from Direct and Global
38 * Irradiance,î Solar Energy 44(5):271-289.
39 *
40 * Perez, R., R. Seals, and J. Michalsky. 1993.
41 * ìAll-Weather Model for Sky Luminance Distribution -
42 * Preliminary Configuration and Validation,î Solar Energy
43 * 50(3):235-245.
44 *
45 * Perez, R., R. Seals, and J. Michalsky. 1993. "ERRATUM to
46 * All-Weather Model for Sky Luminance Distribution -
47 * Preliminary Configuration and Validation,î Solar Energy
48 * 51(5):423.
49 *
50 * NOTE: This program is a completely rewritten version of
51 * gendaylit.c written by Jean-Jacques Delaunay (1994).
52 *
53 * Copyright 2009-2012 byHeart Consultants Limited. All rights
54 * reserved.
55 *
56 * Redistribution and use in source and binary forms, with or without
57 * modification, are permitted for personal and commercial purposes
58 * provided that redistribution of source code must retain the above
59 * copyright notice, this list of conditions and the following
60 * disclaimer:
61 *
62 * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESSED OR IMPLIED
63 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
64 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
65 * DISCLAIMED. IN NO EVENT SHALL byHeart Consultants Limited OR
66 * ITS EMPLOYEES BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
67 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
68 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
69 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
70 * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
71 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
72 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
73 * POSSIBILITY OF SUCH DAMAGE.
74 *
75 *********************************************************************/
76
77 /* Zenith is along the Z-axis */
78 /* X-axis points east */
79 /* Y-axis points north */
80 /* azimuth is measured as degrees or radians east of North */
81
82 /* Include files */
83 #define _USE_MATH_DEFINES
84 #include <stdio.h>
85 #include <stdlib.h>
86 #include <string.h>
87 #include <ctype.h>
88 #include "rtmath.h"
89 #include "color.h"
90
91 char *progname; /* Program name */
92 char errmsg[128]; /* Error message buffer */
93 const double DC_SolarConstantE = 1367.0; /* Solar constant W/m^2 */
94 const double DC_SolarConstantL = 127.5; /* Solar constant klux */
95
96 double altitude; /* Solar altitude (radians) */
97 double azimuth; /* Solar azimuth (radians) */
98 double apwc; /* Atmospheric precipitable water content */
99 double dew_point = 11.0; /* Surface dew point temperature (deg. C) */
100 double diff_illum; /* Diffuse illuminance */
101 double diff_irrad; /* Diffuse irradiance */
102 double dir_illum; /* Direct illuminance */
103 double dir_irrad; /* Direct irradiance */
104 int julian_date; /* Julian date */
105 double perez_param[5]; /* Perez sky model parameters */
106 double sky_brightness; /* Sky brightness */
107 double sky_clearness; /* Sky clearness */
108 double solar_rad; /* Solar radiance */
109 double sun_zenith; /* Sun zenith angle (radians) */
110 int input = 0; /* Input type */
111
112 extern double dmax( double, double );
113 extern double CalcAirMass();
114 extern double CalcDiffuseIllumRatio( int );
115 extern double CalcDiffuseIrradiance();
116 extern double CalcDirectIllumRatio( int );
117 extern double CalcDirectIrradiance();
118 extern double CalcEccentricity();
119 extern double CalcPrecipWater( double );
120 extern double CalcRelHorzIllum( float *parr );
121 extern double CalcRelLuminance( double, double );
122 extern double CalcSkyBrightness();
123 extern double CalcSkyClearness();
124 extern int CalcSkyParamFromIllum();
125 extern int GetCategoryIndex();
126 extern void CalcPerezParam( double, double, double, int );
127 extern void CalcSkyPatchLumin( float *parr );
128 extern void ComputeSky( float *parr );
129
130 /* Degrees into radians */
131 #define DegToRad(deg) ((deg)*(PI/180.))
132
133 /* Radiuans into degrees */
134 #define RadToDeg(rad) ((rad)*(180./PI))
135
136
137 /* Perez sky model coefficients */
138
139 /* Reference: Perez, R., R. Seals, and J. Michalsky, 1993. "All- */
140 /* Weather Model for Sky Luminance Distribution - */
141 /* Preliminary Configuration and Validation," Solar */
142 /* Energy 50(3):235-245, Table 1. */
143
144 static const double PerezCoeff[8][20] =
145 {
146 /* Sky clearness (epsilon): 1.000 to 1.065 */
147 { 1.3525, -0.2576, -0.2690, -1.4366, -0.7670,
148 0.0007, 1.2734, -0.1233, 2.8000, 0.6004,
149 1.2375, 1.0000, 1.8734, 0.6297, 0.9738,
150 0.2809, 0.0356, -0.1246, -0.5718, 0.9938 },
151 /* Sky clearness (epsilon): 1.065 to 1.230 */
152 { -1.2219, -0.7730, 1.4148, 1.1016, -0.2054,
153 0.0367, -3.9128, 0.9156, 6.9750, 0.1774,
154 6.4477, -0.1239, -1.5798, -0.5081, -1.7812,
155 0.1080, 0.2624, 0.0672, -0.2190, -0.4285 },
156 /* Sky clearness (epsilon): 1.230 to 1.500 */
157 { -1.1000, -0.2515, 0.8952, 0.0156, 0.2782,
158 -0.1812, - 4.5000, 1.1766, 24.7219, -13.0812,
159 -37.7000, 34.8438, -5.0000, 1.5218, 3.9229,
160 -2.6204, -0.0156, 0.1597, 0.4199, -0.5562 },
161 /* Sky clearness (epsilon): 1.500 to 1.950 */
162 { -0.5484, -0.6654, -0.2672, 0.7117, 0.7234,
163 -0.6219, -5.6812, 2.6297, 33.3389, -18.3000,
164 -62.2500, 52.0781, -3.5000, 0.0016, 1.1477,
165 0.1062, 0.4659, -0.3296, -0.0876, -0.0329 },
166 /* Sky clearness (epsilon): 1.950 to 2.800 */
167 { -0.6000, -0.3566, -2.5000, 2.3250, 0.2937,
168 0.0496, -5.6812, 1.8415, 21.0000, -4.7656 ,
169 -21.5906, 7.2492, -3.5000, -0.1554, 1.4062,
170 0.3988, 0.0032, 0.0766, -0.0656, -0.1294 },
171 /* Sky clearness (epsilon): 2.800 to 4.500 */
172 { -1.0156, -0.3670, 1.0078, 1.4051, 0.2875,
173 -0.5328, -3.8500, 3.3750, 14.0000, -0.9999,
174 -7.1406, 7.5469, -3.4000, -0.1078, -1.0750,
175 1.5702, -0.0672, 0.4016, 0.3017, -0.4844 },
176 /* Sky clearness (epsilon): 4.500 to 6.200 */
177 { -1.0000, 0.0211, 0.5025, -0.5119, -0.3000,
178 0.1922, 0.7023, -1.6317, 19.0000, -5.0000,
179 1.2438, -1.9094, -4.0000, 0.0250, 0.3844,
180 0.2656, 1.0468, -0.3788, -2.4517, 1.4656 },
181 /* Sky clearness (epsilon): 6.200 to ... */
182 { -1.0500, 0.0289, 0.4260, 0.3590, -0.3250,
183 0.1156, 0.7781, 0.0025, 31.0625, -14.5000,
184 -46.1148, 55.3750, -7.2312, 0.4050, 13.3500,
185 0.6234, 1.5000, -0.6426, 1.8564, 0.5636 }
186 };
187
188 /* Perez irradiance component model coefficients */
189
190 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
191 /* Stewart. 1990. ìModeling Daylight Availability and */
192 /* Irradiance Components from Direct and Global */
193 /* Irradiance,î Solar Energy 44(5):271-289. */
194
195 typedef struct
196 {
197 double lower; /* Lower bound */
198 double upper; /* Upper bound */
199 } CategoryBounds;
200
201 /* Perez sky clearness (epsilon) categories (Table 1) */
202 static const CategoryBounds SkyClearCat[8] =
203 {
204 { 1.000, 1.065 }, /* Overcast */
205 { 1.065, 1.230 },
206 { 1.230, 1.500 },
207 { 1.500, 1.950 },
208 { 1.950, 2.800 },
209 { 2.800, 4.500 },
210 { 4.500, 6.200 },
211 { 6.200, 12.00 } /* Clear */
212 };
213
214 /* Luminous efficacy model coefficients */
215 typedef struct
216 {
217 double a;
218 double b;
219 double c;
220 double d;
221 } ModelCoeff;
222
223 /* Diffuse luminous efficacy model coefficients (Table 4, Eqn. 7) */
224 static const ModelCoeff DiffuseLumEff[8] =
225 {
226 { 97.24, -0.46, 12.00, -8.91 },
227 { 107.22, 1.15, 0.59, -3.95 },
228 { 104.97, 2.96, -5.53, -8.77 },
229 { 102.39, 5.59, -13.95, -13.90 },
230 { 100.71, 5.94, -22.75, -23.74 },
231 { 106.42, 3.83, -36.15, -28.83 },
232 { 141.88, 1.90, -53.24, -14.03 },
233 { 152.23, 0.35, -45.27, -7.98 }
234 };
235
236 /* Direct luminous efficacy model coefficients (Table 4, Eqn. 8) */
237 static const ModelCoeff DirectLumEff[8] =
238 {
239 { 57.20, -4.55, -2.98, 117.12 },
240 { 98.99, -3.46, -1.21, 12.38 },
241 { 109.83, -4.90, -1.71, -8.81 },
242 { 110.34, -5.84, -1.99, -4.56 },
243 { 106.36, -3.97, -1.75, -6.16 },
244 { 107.19, -1.25, -1.51, -26.73 },
245 { 105.75, 0.77, -1.26, -34.44 },
246 { 101.18, 1.58, -1.10, -8.29 }
247 };
248
249 #ifndef NSUNPATCH
250 #define NSUNPATCH 4 /* # patches to spread sun into */
251 #endif
252
253 extern int jdate(int month, int day);
254 extern double stadj(int jd);
255 extern double sdec(int jd);
256 extern double salt(double sd, double st);
257 extern double sazi(double sd, double st);
258 /* sun calculation constants */
259 extern double s_latitude;
260 extern double s_longitude;
261 extern double s_meridian;
262
263 int verbose = 0; /* progress reports to stderr? */
264
265 int outfmt = 'a'; /* output format */
266
267 int rhsubdiv = 1; /* Reinhart sky subdivisions */
268
269 COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */
270 COLOR suncolor = {1., 1., 1.}; /* sun color */
271 COLOR grefl = {.2, .2, .2}; /* ground reflectance */
272
273 int nskypatch; /* number of Reinhart patches */
274 float *rh_palt; /* sky patch altitudes (radians) */
275 float *rh_pazi; /* sky patch azimuths (radians) */
276 float *rh_dom; /* sky patch solid angle (sr) */
277
278 #define vector(v,alt,azi) ( (v)[1] = tcos(alt), \
279 (v)[0] = (v)[1]*tsin(azi), \
280 (v)[1] *= tcos(azi), \
281 (v)[2] = tsin(alt) )
282
283 #define rh_vector(v,i) vector(v,rh_palt[i],rh_pazi[i])
284
285 #define rh_cos(i) tsin(rh_palt[i])
286
287 extern int rh_init(void);
288 extern float * resize_dmatrix(float *mtx_data, int nsteps, int npatch);
289 extern void AddDirect(float *parr);
290
291 int
292 main(int argc, char *argv[])
293 {
294 char buf[256];
295 double elevation; /* site elevation (meters) */
296 int dir_is_horiz; /* direct is meas. on horizontal? */
297 float *mtx_data = NULL; /* our matrix data */
298 int ntsteps = 0; /* number of rows in matrix */
299 int last_monthly = 0; /* month of last report */
300 int mo, da; /* month (1-12) and day (1-31) */
301 double hr; /* hour (local standard time) */
302 double dir, dif; /* direct and diffuse values */
303 int mtx_offset;
304 int i, j;
305
306 progname = argv[0];
307 /* get options */
308 for (i = 1; i < argc && argv[i][0] == '-'; i++)
309 switch (argv[i][1]) {
310 case 'g': /* ground reflectance */
311 grefl[0] = atof(argv[++i]);
312 grefl[1] = atof(argv[++i]);
313 grefl[2] = atof(argv[++i]);
314 break;
315 case 'v': /* verbose progress reports */
316 verbose++;
317 break;
318 case 'o': /* output format */
319 switch (argv[i][2]) {
320 case 'f':
321 case 'd':
322 case 'a':
323 outfmt = argv[i][2];
324 break;
325 default:
326 goto userr;
327 }
328 break;
329 case 'm': /* Reinhart subdivisions */
330 rhsubdiv = atoi(argv[++i]);
331 break;
332 case 'c': /* sky color */
333 skycolor[0] = atof(argv[++i]);
334 skycolor[1] = atof(argv[++i]);
335 skycolor[2] = atof(argv[++i]);
336 break;
337 case 'd': /* solar (direct) only */
338 skycolor[0] = skycolor[1] = skycolor[2] = 0;
339 if (suncolor[1] <= 1e-4)
340 suncolor[0] = suncolor[1] = suncolor[2] = 1;
341 break;
342 case 's': /* sky only (no direct) */
343 suncolor[0] = suncolor[1] = suncolor[2] = 0;
344 if (skycolor[1] <= 1e-4)
345 skycolor[0] = skycolor[1] = skycolor[2] = 1;
346 break;
347 default:
348 goto userr;
349 }
350 if (i < argc-1)
351 goto userr;
352 if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) {
353 fprintf(stderr, "%s: cannot open '%s' for input\n",
354 progname, argv[i]);
355 exit(1);
356 }
357 if (verbose) {
358 if (i == argc-1)
359 fprintf(stderr, "%s: reading weather tape '%s'\n",
360 progname, argv[i]);
361 else
362 fprintf(stderr, "%s: reading weather tape from <stdin>\n",
363 progname);
364 }
365 /* read weather tape header */
366 if (scanf("place %[^\r\n] ", buf) != 1)
367 goto fmterr;
368 if (scanf("latitude %lf\n", &s_latitude) != 1)
369 goto fmterr;
370 if (scanf("longitude %lf\n", &s_longitude) != 1)
371 goto fmterr;
372 if (scanf("time_zone %lf\n", &s_meridian) != 1)
373 goto fmterr;
374 if (scanf("site_elevation %lf\n", &elevation) != 1)
375 goto fmterr;
376 if (scanf("weather_data_file_units %d\n", &input) != 1)
377 goto fmterr;
378 switch (input) { /* translate units */
379 case 1:
380 input = 1; /* radiometric quantities */
381 dir_is_horiz = 0; /* direct is perpendicular meas. */
382 break;
383 case 2:
384 input = 1; /* radiometric quantities */
385 dir_is_horiz = 1; /* solar measured horizontally */
386 break;
387 case 3:
388 input = 2; /* photometric quantities */
389 dir_is_horiz = 0; /* direct is perpendicular meas. */
390 break;
391 default:
392 goto fmterr;
393 }
394 rh_init(); /* initialize sky patches */
395 if (verbose) {
396 fprintf(stderr, "%s: location '%s'\n", progname, buf);
397 fprintf(stderr, "%s: (lat,long)=(%.1f,%.1f) degrees north, west\n",
398 progname, s_latitude, s_longitude);
399 fprintf(stderr, "%s: %d sky patches per time step\n",
400 progname, nskypatch);
401 }
402 /* convert quantities to radians */
403 s_latitude = DegToRad(s_latitude);
404 s_longitude = DegToRad(s_longitude);
405 s_meridian = DegToRad(s_meridian);
406 /* process each time step in tape */
407 while (scanf("%d %d %lf %lf %lf\n", &mo, &da, &hr, &dir, &dif) == 5) {
408 double sda, sta;
409 /* make space for next time step */
410 mtx_offset = 3*nskypatch*ntsteps++;
411 mtx_data = resize_dmatrix(mtx_data, ntsteps, nskypatch);
412 if (dif <= 1e-4) {
413 memset(mtx_data+mtx_offset, 0, sizeof(float)*3*nskypatch);
414 continue;
415 }
416 if (verbose && mo != last_monthly)
417 fprintf(stderr, "%s: stepping through month %d...\n",
418 progname, last_monthly=mo);
419 /* compute solar position */
420 julian_date = jdate(mo, da);
421 sda = sdec(julian_date);
422 sta = stadj(julian_date);
423 altitude = salt(sda, hr+sta);
424 azimuth = sazi(sda, hr+sta) + PI;
425 /* convert measured values */
426 if (dir_is_horiz && altitude > 0.)
427 dir /= sin(altitude);
428 if (input == 1) {
429 dir_irrad = dir;
430 diff_irrad = dif;
431 } else /* input == 2 */ {
432 dir_illum = dir;
433 diff_illum = dif;
434 }
435 /* compute sky patch values */
436 ComputeSky(mtx_data+mtx_offset);
437 AddDirect(mtx_data+mtx_offset);
438 }
439 /* check for junk at end */
440 while ((i = fgetc(stdin)) != EOF)
441 if (!isspace(i)) {
442 fprintf(stderr, "%s: warning - unexpected data past EOT: ",
443 progname);
444 buf[0] = i; buf[1] = '\0';
445 fgets(buf+1, sizeof(buf)-1, stdin);
446 fputs(buf, stderr); fputc('\n', stderr);
447 break;
448 }
449 /* write out matrix */
450 #ifdef getc_unlocked
451 flockfile(stdout);
452 #endif
453 if (verbose)
454 fprintf(stderr, "%s: writing %smatrix with %d time steps...\n",
455 progname, outfmt=='a' ? "" : "binary ", ntsteps);
456 /* patches are rows (outer sort) */
457 for (i = 0; i < nskypatch; i++) {
458 mtx_offset = 3*i;
459 switch (outfmt) {
460 case 'a':
461 for (j = 0; j < ntsteps; j++) {
462 printf("%.3g %.3g %.3g\n", mtx_data[mtx_offset],
463 mtx_data[mtx_offset+1],
464 mtx_data[mtx_offset+2]);
465 mtx_offset += 3*nskypatch;
466 }
467 if (ntsteps > 1)
468 fputc('\n', stdout);
469 break;
470 case 'f':
471 for (j = 0; j < ntsteps; j++) {
472 fwrite(mtx_data+mtx_offset, sizeof(float), 3,
473 stdout);
474 mtx_offset += 3*nskypatch;
475 }
476 break;
477 case 'd':
478 for (j = 0; j < ntsteps; j++) {
479 double ment[3];
480 ment[0] = mtx_data[mtx_offset];
481 ment[1] = mtx_data[mtx_offset+1];
482 ment[2] = mtx_data[mtx_offset+2];
483 fwrite(ment, sizeof(double), 3, stdout);
484 mtx_offset += 3*nskypatch;
485 }
486 break;
487 }
488 if (ferror(stdout))
489 goto writerr;
490 }
491 if (fflush(stdout) == EOF)
492 goto writerr;
493 if (verbose)
494 fprintf(stderr, "%s: done.\n", progname);
495 exit(0);
496 userr:
497 fprintf(stderr, "Usage: %s [-v][-d|-s][-m N][-g r g b][-c r g b][-o{f|d}] [tape.wea]\n",
498 progname);
499 exit(1);
500 fmterr:
501 fprintf(stderr, "%s: input weather tape format error\n", progname);
502 exit(1);
503 writerr:
504 fprintf(stderr, "%s: write error on output\n", progname);
505 exit(1);
506 }
507
508 /* Return maximum of two doubles */
509 double dmax( double a, double b )
510 { return (a > b) ? a : b; }
511
512 /* Compute sky patch radiance values (modified by GW) */
513 void
514 ComputeSky(float *parr)
515 {
516 int index; /* Category index */
517 double norm_diff_illum; /* Normalized diffuse illuimnance */
518 double zlumin; /* Zenith luminance */
519 int i;
520
521 /* Calculate atmospheric precipitable water content */
522 apwc = CalcPrecipWater(dew_point);
523
524 /* Limit solar altitude to keep circumsolar off zenith */
525 if (altitude > DegToRad(87.0))
526 altitude = DegToRad(87.0);
527
528 /* Calculate sun zenith angle */
529 sun_zenith = DegToRad(90.0) - altitude;
530
531 /* Compute the inputs for the calculation of the sky distribution */
532
533 if (input == 0) /* XXX never used */
534 {
535 /* Calculate irradiance */
536 diff_irrad = CalcDiffuseIrradiance();
537 dir_irrad = CalcDirectIrradiance();
538
539 /* Calculate illuminance */
540 index = GetCategoryIndex();
541 diff_illum = diff_irrad * CalcDiffuseIllumRatio(index);
542 dir_illum = dir_irrad * CalcDirectIllumRatio(index);
543 }
544 else if (input == 1)
545 {
546 sky_brightness = CalcSkyBrightness();
547 sky_clearness = CalcSkyClearness();
548
549 /* Calculate illuminance */
550 index = GetCategoryIndex();
551 diff_illum = diff_irrad * CalcDiffuseIllumRatio(index);
552 dir_illum = dir_irrad * CalcDirectIllumRatio(index);
553 }
554 else if (input == 2)
555 {
556 /* Calculate sky brightness and clearness from illuminance values */
557 index = CalcSkyParamFromIllum();
558 }
559
560 if (bright(skycolor) <= 1e-4) { /* 0 sky component? */
561 memset(parr, 0, sizeof(float)*3*nskypatch);
562 return;
563 }
564 /* Compute ground radiance (include solar contribution if any) */
565 parr[0] = diff_illum;
566 if (altitude > 0)
567 parr[0] += dir_illum * sin(altitude);
568 parr[2] = parr[1] = parr[0] *= (1./PI/WHTEFFICACY);
569 multcolor(parr, grefl);
570
571 /* Calculate Perez sky model parameters */
572 CalcPerezParam(sun_zenith, sky_clearness, sky_brightness, index);
573
574 /* Calculate sky patch luminance values */
575 CalcSkyPatchLumin(parr);
576
577 /* Calculate relative horizontal illuminance */
578 norm_diff_illum = CalcRelHorzIllum(parr);
579
580 /* Normalization coefficient */
581 norm_diff_illum = diff_illum / norm_diff_illum;
582
583 /* Calculate relative zenith luminance */
584 zlumin = CalcRelLuminance(sun_zenith, 0.0);
585
586 /* Calculate absolute zenith illuminance */
587 zlumin *= norm_diff_illum;
588
589 /* Apply to sky patches to get absolute radiance values */
590 for (i = 1; i < nskypatch; i++) {
591 scalecolor(parr+3*i, zlumin*(1./WHTEFFICACY));
592 multcolor(parr+3*i, skycolor);
593 }
594 }
595
596 /* Add in solar direct to nearest sky patches (GW) */
597 void
598 AddDirect(float *parr)
599 {
600 FVECT svec;
601 double near_dprod[NSUNPATCH];
602 int near_patch[NSUNPATCH];
603 double wta[NSUNPATCH], wtot;
604 int i, j, p;
605
606 if (dir_illum <= 1e-4 || bright(suncolor) <= 1e-4)
607 return;
608 /* identify NSUNPATCH closest patches */
609 for (i = NSUNPATCH; i--; )
610 near_dprod[i] = -1.;
611 vector(svec, altitude, azimuth);
612 for (p = 1; p < nskypatch; p++) {
613 FVECT pvec;
614 double dprod;
615 rh_vector(pvec, p);
616 dprod = DOT(pvec, svec);
617 for (i = 0; i < NSUNPATCH; i++)
618 if (dprod > near_dprod[i]) {
619 for (j = NSUNPATCH; --j > i; ) {
620 near_dprod[j] = near_dprod[j-1];
621 near_patch[j] = near_patch[j-1];
622 }
623 near_dprod[i] = dprod;
624 near_patch[i] = p;
625 break;
626 }
627 }
628 wtot = 0; /* weight by proximity */
629 for (i = NSUNPATCH; i--; )
630 wtot += wta[i] = 1./(1.002 - near_dprod[i]);
631 /* add to nearest patch radiances */
632 for (i = NSUNPATCH; i--; ) {
633 float *pdest = parr + 3*near_patch[i];
634 float val_add = wta[i] * dir_illum /
635 (WHTEFFICACY * wtot * rh_dom[near_patch[i]]);
636 *pdest++ += val_add*suncolor[0];
637 *pdest++ += val_add*suncolor[1];
638 *pdest++ += val_add*suncolor[2];
639 }
640 }
641
642 /* Initialize Reinhart sky patch positions (GW) */
643 int
644 rh_init(void)
645 {
646 #define NROW 7
647 static const int tnaz[NROW] = {30, 30, 24, 24, 18, 12, 6};
648 const double alpha = (PI/2.)/(NROW*rhsubdiv + .5);
649 int p, i, j;
650 /* allocate patch angle arrays */
651 nskypatch = 0;
652 for (p = 0; p < NROW; p++)
653 nskypatch += tnaz[p];
654 nskypatch *= rhsubdiv*rhsubdiv;
655 nskypatch += 2;
656 rh_palt = (float *)malloc(sizeof(float)*nskypatch);
657 rh_pazi = (float *)malloc(sizeof(float)*nskypatch);
658 rh_dom = (float *)malloc(sizeof(float)*nskypatch);
659 if ((rh_palt == NULL) | (rh_pazi == NULL) | (rh_dom == NULL)) {
660 fprintf(stderr, "%s: out of memory in rh_init()\n", progname);
661 exit(1);
662 }
663 rh_palt[0] = -PI/2.; /* ground & zenith patches */
664 rh_pazi[0] = 0.;
665 rh_dom[0] = 2.*PI;
666 rh_palt[nskypatch-1] = PI/2.;
667 rh_pazi[nskypatch-1] = 0.;
668 rh_dom[nskypatch-1] = 2.*PI*(1. - cos(alpha*.5));
669 p = 1; /* "normal" patches */
670 for (i = 0; i < NROW*rhsubdiv; i++) {
671 const float ralt = alpha*(i + .5);
672 const int ninrow = tnaz[i/rhsubdiv]*rhsubdiv;
673 const float dom = 2.*PI*(sin(alpha*(i+1)) - sin(alpha*i)) /
674 (double)ninrow;
675 for (j = 0; j < ninrow; j++) {
676 rh_palt[p] = ralt;
677 rh_pazi[p] = 2.*PI * j / (double)ninrow;
678 rh_dom[p++] = dom;
679 }
680 }
681 return nskypatch;
682 #undef NROW
683 }
684
685 /* Resize daylight matrix (GW) */
686 float *
687 resize_dmatrix(float *mtx_data, int nsteps, int npatch)
688 {
689 if (mtx_data == NULL)
690 mtx_data = (float *)malloc(sizeof(float)*3*nsteps*npatch);
691 else
692 mtx_data = (float *)realloc(mtx_data,
693 sizeof(float)*3*nsteps*npatch);
694 if (mtx_data == NULL) {
695 fprintf(stderr, "%s: out of memory in resize_dmatrix(%d,%d)\n",
696 progname, nsteps, npatch);
697 exit(1);
698 }
699 return(mtx_data);
700 }
701
702 /* Determine category index */
703 int GetCategoryIndex()
704 {
705 int index; /* Loop index */
706
707 for (index = 0; index < 8; index++)
708 if ((sky_clearness >= SkyClearCat[index].lower) &&
709 (sky_clearness < SkyClearCat[index].upper))
710 break;
711
712 return index;
713 }
714
715 /* Calculate diffuse illuminance to diffuse irradiance ratio */
716
717 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
718 /* Stewart. 1990. ìModeling Daylight Availability and */
719 /* Irradiance Components from Direct and Global */
720 /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 7. */
721
722 double CalcDiffuseIllumRatio( int index )
723 {
724 ModelCoeff const *pnle; /* Category coefficient pointer */
725
726 /* Get category coefficient pointer */
727 pnle = &(DiffuseLumEff[index]);
728
729 return pnle->a + pnle->b * apwc + pnle->c * cos(sun_zenith) +
730 pnle->d * log(sky_brightness);
731 }
732
733 /* Calculate direct illuminance to direct irradiance ratio */
734
735 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
736 /* Stewart. 1990. ìModeling Daylight Availability and */
737 /* Irradiance Components from Direct and Global */
738 /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 8. */
739
740 double CalcDirectIllumRatio( int index )
741 {
742 ModelCoeff const *pnle; /* Category coefficient pointer */
743
744 /* Get category coefficient pointer */
745 pnle = &(DirectLumEff[index]);
746
747 /* Calculate direct illuminance from direct irradiance */
748
749 return dmax((pnle->a + pnle->b * apwc + pnle->c * exp(5.73 *
750 sun_zenith - 5.0) + pnle->d * sky_brightness),
751 0.0);
752 }
753
754 /* Calculate sky brightness */
755
756 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
757 /* Stewart. 1990. ìModeling Daylight Availability and */
758 /* Irradiance Components from Direct and Global */
759 /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 2. */
760
761 double CalcSkyBrightness()
762 {
763 return diff_irrad * CalcAirMass() / (DC_SolarConstantE *
764 CalcEccentricity());
765 }
766
767 /* Calculate sky clearness */
768
769 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
770 /* Stewart. 1990. ìModeling Daylight Availability and */
771 /* Irradiance Components from Direct and Global */
772 /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 1. */
773
774 double CalcSkyClearness()
775 {
776 double sz_cubed; /* Sun zenith angle cubed */
777
778 /* Calculate sun zenith angle cubed */
779 sz_cubed = pow(sun_zenith, 3.0);
780
781 return ((diff_irrad + dir_irrad) / diff_irrad + 1.041 *
782 sz_cubed) / (1.0 + 1.041 * sz_cubed);
783 }
784
785 /* Calculate diffuse horizontal irradiance from Perez sky brightness */
786
787 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
788 /* Stewart. 1990. ìModeling Daylight Availability and */
789 /* Irradiance Components from Direct and Global */
790 /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 2 */
791 /* (inverse). */
792
793 double CalcDiffuseIrradiance()
794 {
795 return sky_brightness * DC_SolarConstantE * CalcEccentricity() /
796 CalcAirMass();
797 }
798
799 /* Calculate direct normal irradiance from Perez sky clearness */
800
801 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
802 /* Stewart. 1990. ìModeling Daylight Availability and */
803 /* Irradiance Components from Direct and Global */
804 /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 1 */
805 /* (inverse). */
806
807 double CalcDirectIrradiance()
808 {
809 return CalcDiffuseIrradiance() * ((sky_clearness - 1.0) * (1 + 1.041
810 * pow(sun_zenith, 3.0)));
811 }
812
813 /* Calculate sky brightness and clearness from illuminance values */
814 int CalcSkyParamFromIllum()
815 {
816 double test1 = 0.1;
817 double test2 = 0.1;
818 int counter = 0;
819 int index = 0; /* Category index */
820
821 /* Convert illuminance to irradiance */
822 diff_irrad = diff_illum * DC_SolarConstantE /
823 (DC_SolarConstantL * 1000.0);
824 dir_irrad = dir_illum * DC_SolarConstantE /
825 (DC_SolarConstantL * 1000.0);
826
827 /* Calculate sky brightness and clearness */
828 sky_brightness = CalcSkyBrightness();
829 sky_clearness = CalcSkyClearness();
830
831 /* Limit sky clearness */
832 if (sky_clearness > 12.0)
833 sky_clearness = 12.0;
834
835 /* Limit sky brightness */
836 if (sky_brightness < 0.05)
837 sky_brightness = 0.01;
838
839 while (((fabs(diff_irrad - test1) > 10.0) ||
840 (fabs(dir_irrad - test2) > 10.0)) && !(counter == 5))
841 {
842 test1 = diff_irrad;
843 test2 = dir_irrad;
844 counter++;
845
846 /* Convert illuminance to irradiance */
847 index = GetCategoryIndex();
848 diff_irrad = diff_illum / CalcDiffuseIllumRatio(index);
849 dir_irrad = dir_illum / CalcDirectIllumRatio(index);
850
851 /* Calculate sky brightness and clearness */
852 sky_brightness = CalcSkyBrightness();
853 sky_clearness = CalcSkyClearness();
854
855 /* Limit sky clearness */
856 if (sky_clearness > 12.0)
857 sky_clearness = 12.0;
858
859 /* Limit sky brightness */
860 if (sky_brightness < 0.05)
861 sky_brightness = 0.01;
862 }
863
864 return GetCategoryIndex();
865 }
866
867 /* Calculate relative luminance */
868
869 /* Reference: Perez, R., R. Seals, and J. Michalsky. 1993. */
870 /* ìAll-Weather Model for Sky Luminance Distribution - */
871 /* Preliminary Configuration and Validation,î Solar Energy */
872 /* 50(3):235-245, Eqn. 1. */
873
874 double CalcRelLuminance( double gamma, double zeta )
875 {
876 return (1.0 + perez_param[0] * exp(perez_param[1] / cos(zeta))) *
877 (1.0 + perez_param[2] * exp(perez_param[3] * gamma) +
878 perez_param[4] * cos(gamma) * cos(gamma));
879 }
880
881 /* Calculate Perez sky model parameters */
882
883 /* Reference: Perez, R., R. Seals, and J. Michalsky. 1993. */
884 /* ìAll-Weather Model for Sky Luminance Distribution - */
885 /* Preliminary Configuration and Validation,î Solar Energy */
886 /* 50(3):235-245, Eqns. 6 - 8. */
887
888 void CalcPerezParam( double sz, double epsilon, double delta,
889 int index )
890 {
891 double x[5][4]; /* Coefficents a, b, c, d, e */
892 int i, j; /* Loop indices */
893
894 /* Limit sky brightness */
895 if (epsilon > 1.065 && epsilon < 2.8)
896 {
897 if (delta < 0.2)
898 delta = 0.2;
899 }
900
901 /* Get Perez coefficients */
902 for (i = 0; i < 5; i++)
903 for (j = 0; j < 4; j++)
904 x[i][j] = PerezCoeff[index][4 * i + j];
905
906 if (index != 0)
907 {
908 /* Calculate parameter a, b, c, d and e (Eqn. 6) */
909 for (i = 0; i < 5; i++)
910 perez_param[i] = x[i][0] + x[i][1] * sz + delta * (x[i][2] +
911 x[i][3] * sz);
912 }
913 else
914 {
915 /* Parameters a, b and e (Eqn. 6) */
916 perez_param[0] = x[0][0] + x[0][1] * sz + delta * (x[0][2] +
917 x[0][3] * sz);
918 perez_param[1] = x[1][0] + x[1][1] * sz + delta * (x[1][2] +
919 x[1][3] * sz);
920 perez_param[4] = x[4][0] + x[4][1] * sz + delta * (x[4][2] +
921 x[4][3] * sz);
922
923 /* Parameter c (Eqn. 7) */
924 perez_param[2] = exp(pow(delta * (x[2][0] + x[2][1] * sz),
925 x[2][2])) - x[2][3];
926
927 /* Parameter d (Eqn. 8) */
928 perez_param[3] = -exp(delta * (x[3][0] + x[3][1] * sz)) +
929 x[3][2] + delta * x[3][3];
930 }
931 }
932
933 /* Calculate relative horizontal illuminance (modified by GW) */
934
935 /* Reference: Perez, R., R. Seals, and J. Michalsky. 1993. */
936 /* ìAll-Weather Model for Sky Luminance Distribution - */
937 /* Preliminary Configuration and Validation,î Solar Energy */
938 /* 50(3):235-245, Eqn. 3. */
939
940 double CalcRelHorzIllum( float *parr )
941 {
942 int i;
943 double rh_illum = 0.0; /* Relative horizontal illuminance */
944
945 for (i = 1; i < nskypatch; i++)
946 rh_illum += parr[3*i+1] * rh_cos(i);
947
948 return rh_illum * (2.0 * PI / (nskypatch-1));
949 }
950
951 /* Calculate earth orbit eccentricity correction factor */
952
953 /* Reference: Sen, Z. 2008. Solar Energy Fundamental and Modeling */
954 /* Techniques. Springer, p. 72. */
955
956 double CalcEccentricity()
957 {
958 double day_angle; /* Day angle (radians) */
959 double E0; /* Eccentricity */
960
961 /* Calculate day angle */
962 day_angle = (julian_date - 1.0) * (2.0 * PI / 365.0);
963
964 /* Calculate eccentricity */
965 E0 = 1.00011 + 0.034221 * cos(day_angle) + 0.00128 * sin(day_angle)
966 + 0.000719 * cos(2.0 * day_angle) + 0.000077 * sin(2.0 *
967 day_angle);
968
969 return E0;
970 }
971
972 /* Calculate atmospheric precipitable water content */
973
974 /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
975 /* Stewart. 1990. ìModeling Daylight Availability and */
976 /* Irradiance Components from Direct and Global */
977 /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 3. */
978
979 /* Note: The default surface dew point temperature is 11 deg. C */
980 /* (52 deg. F). Typical values are: */
981
982 /* Celsius Fahrenheit Human Perception */
983 /* > 24 > 75 Extremely uncomfortable */
984 /* 21 - 24 70 - 74 Very humid */
985 /* 18 - 21 65 - 69 Somewhat uncomfortable */
986 /* 16 - 18 60 - 64 OK for most people */
987 /* 13 - 16 55 - 59 Comfortable */
988 /* 10 - 12 50 - 54 Very comfortable */
989 /* < 10 < 49 A bit dry for some */
990
991 double CalcPrecipWater( double dpt )
992 { return exp(0.07 * dpt - 0.075); }
993
994 /* Calculate relative air mass */
995
996 /* Reference: Kasten, F. 1966. "A New Table and Approximation Formula */
997 /* for the Relative Optical Air Mass," Arch. Meteorol. */
998 /* Geophys. Bioklimataol. Ser. B14, pp. 206-233. */
999
1000 /* Note: More sophisticated relative air mass models are */
1001 /* available, but they differ significantly only for */
1002 /* sun zenith angles greater than 80 degrees. */
1003
1004 double CalcAirMass()
1005 {
1006 return (1.0 / (cos(sun_zenith) + 0.15 * pow(93.885 -
1007 RadToDeg(sun_zenith), -1.253)));
1008 }
1009
1010 /* Calculate Perez All-Weather sky patch luminances (modified by GW) */
1011
1012 /* NOTE: The sky patches centers are determined in accordance with the */
1013 /* BRE-IDMP sky luminance measurement procedures. (See for example */
1014 /* Mardaljevic, J. 2001. "The BRE-IDMP Dataset: A New Benchmark */
1015 /* for the Validation of Illuminance Prediction Techniques," */
1016 /* Lighting Research & Technology 33(2):117-136.) */
1017
1018 void CalcSkyPatchLumin( float *parr )
1019 {
1020 int i;
1021 double aas; /* Sun-sky point azimuthal angle */
1022 double sspa; /* Sun-sky point angle */
1023 double zsa; /* Zenithal sun angle */
1024
1025 for (i = 1; i < nskypatch; i++)
1026 {
1027 /* Calculate sun-sky point azimuthal angle */
1028 aas = fabs(rh_pazi[i] - azimuth);
1029
1030 /* Calculate zenithal sun angle */
1031 zsa = PI * 0.5 - rh_palt[i];
1032
1033 /* Calculate sun-sky point angle (Equation 8-20) */
1034 sspa = acos(cos(sun_zenith) * cos(zsa) + sin(sun_zenith) *
1035 sin(zsa) * cos(aas));
1036
1037 /* Calculate patch luminance */
1038 parr[3*i] = CalcRelLuminance(sspa, zsa);
1039 if (parr[3*i] < 0) parr[3*i] = 0;
1040 parr[3*i+2] = parr[3*i+1] = parr[3*i];
1041 }
1042 }
