root/radiance/ray/src/gen/gendaymtx.c
Thu Feb 27 19:00:00 2025 UTC (2 months ago) by greg
Changes since 2.41: +14 -12 lines
Diff to previous 2.41 , to selected 2.38
fix(gendaymtx): Issue with interpretation of minutes in EPW input
Wed Feb 26 20:39:28 2025 UTC (2 months, 1 week ago) by greg
Changes since 2.40: +57 -39 lines
Diff to previous 2.40 , to selected 2.38
feat(gendaymtx): Added ability to read dew point from EPW input data
Fri Apr 26 23:10:59 2024 UTC (12 months, 1 week ago) by greg
Changes since 2.39: +63 -3 lines
Diff to previous 2.39 , to selected 2.38
fix(gendaymtx): Added -i option and improved consistency with gendaylit, thanks to Yongqing
Fri Mar 11 18:04:39 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.38: +3 -3 lines
Diff to previous 2.38
feat(gendaymtx): Minor improvement in verbose output
Revision 2.38 - (view) (download) (annotate) - [selected]
Fri Sep 11 16:50:50 2020 UTC (4 years, 7 months ago) by greg
Changes since 2.37: +7 -4 lines
Diff to previous 2.37
feat(gendaymtx): added warning when solar direct is unexpectedly high at night
Sat Aug 15 03:28:56 2020 UTC (4 years, 8 months ago) by greg
Changes since 2.36: +23 -19 lines
Diff to previous 2.36 , to selected 2.38
feat(gendaymtx): added -u option for daylight hours only
Mon Apr 13 17:12:19 2020 UTC (5 years ago) by greg
Changes since 2.35: +55 -21 lines
Diff to previous 2.35 , to selected 2.38
Updates to gendaymtx requested by Ladybug Tools
Tue Jan 7 18:26:55 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.34: +36 -18 lines
Diff to previous 2.34 , to selected 2.38
Code clean-up from last change
Tue Jan 7 01:42:30 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.33: +46 -11 lines
Diff to previous 2.33 , to selected 2.38
Added -n and -D options to gendaymtx
Mon Jan 6 21:22:46 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.32: +2 -14 lines
Diff to previous 2.32 , to selected 2.38
Made sure -d option works as before
Mon Jan 6 21:02:57 2020 UTC (5 years, 3 months ago) by greg
Changes since 2.31: +5 -6 lines
Diff to previous 2.31 , to selected 2.38
Fixed unreported issue of zero ground radiance when sky color is zero
Sat Dec 28 18:05:14 2019 UTC (5 years, 4 months ago) by greg
Changes since 2.30: +1 -3 lines
Diff to previous 2.30 , to selected 2.38
Thu Nov 7 23:15:07 2019 UTC (5 years, 5 months ago) by greg
Changes since 2.29: +3 -14 lines
Diff to previous 2.29 , to selected 2.38
Added more accurate Michalsky solar position calculation and made correction to old IES handbook formula (thanks to Axel Jacobs)
Wed Aug 14 21:00:14 2019 UTC (5 years, 8 months ago) by greg
Diff to previous 2.28 , to selected 2.38
Added byte order to gendaymtx, rsplit, dctimestep, rcode_depth, and rcode_normal
Tue Jun 25 17:06:36 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.27: +17 -17 lines
Diff to previous 2.27 , to selected 2.38
Fixed bug for first data being zero and renamed variables
Tue Jun 25 00:09:45 2019 UTC (5 years, 10 months ago) by greg
Changes since 2.26: +37 -16 lines
Diff to previous 2.26 , to selected 2.38
Added gendaymtx -A option to efficiently compute average skies
Fri Apr 28 16:07:34 2017 UTC (8 years ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.25: +4 -2 lines
Diff to previous 2.25 , to selected 2.38
Eliminated NaN error pointed out by David Geisler-Moroder
Sat Aug 20 15:42:38 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.24: +1 -3 lines
Diff to previous 2.24 , to selected 2.38
Mussed up last change
Fri Aug 19 15:13:40 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.23: +1 -4 lines
Diff to previous 2.23 , to selected 2.38
Removed fprintf(stderr, statements from accidental check-in
Thu Aug 18 00:52:48 2016 UTC (8 years, 8 months ago) by greg
Changes since 2.22: +9 -3 lines
Diff to previous 2.22 , to selected 2.38
Fri Oct 30 17:06:34 2015 UTC (9 years, 6 months ago) by greg
Changes since 2.21: +12 -3 lines
Diff to previous 2.21 , to selected 2.38
Added warning about inconsistent option settings
Wed Sep 2 22:52:04 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.20: +6 -1 lines
Diff to previous 2.20 , to selected 2.38
Added error message to gendaymtx with -5 option used without argument
Sat Aug 1 23:27:04 2015 UTC (9 years, 9 months ago) by greg
Changes since 2.19: +2 -1 lines
Diff to previous 2.19 , to selected 2.38
Tue Dec 30 20:35:34 2014 UTC (10 years, 4 months ago) by greg
Diff to previous 2.18 , to selected 2.38
Changed "secret" -5 option so it now takes sun diameter (in degrees) as arg
Sun Oct 26 17:37:34 2014 UTC (10 years, 6 months ago) by greg
CVS Tags: rad4R2P2
Diff to previous 2.17 , to selected 2.38
Fixed another warning
Sun Oct 26 17:35:53 2014 UTC (10 years, 6 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.38
Tue Jun 17 21:01:21 2014 UTC (10 years, 10 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Diff to previous 2.15 , to selected 2.38
Fixed operator precedence error
Tue Jun 17 18:51:47 2014 UTC (10 years, 10 months ago) by greg
Changes since 2.14: +6 -2 lines
Diff to previous 2.14 , to selected 2.38
Hopeful fix to Windows realloc performance issue
Fri May 30 00:00:54 2014 UTC (10 years, 11 months ago) by greg
Changes since 2.13: +36 -2 lines
Diff to previous 2.13 , to selected 2.38
Fri Oct 4 04:31:18 2013 UTC (11 years, 7 months ago) by greg
Changes since 2.12: +7 -1 lines
Diff to previous 2.12 , to selected 2.38
Fixed problem case when computed sky is everywhere zero
Thu Jun 6 20:21:10 2013 UTC (11 years, 11 months ago) by greg
Diff to previous 2.11 , to selected 2.38
Fixed potential bug pointed out by Ian Ashdown
Tue Apr 30 17:05:27 2013 UTC (12 years ago) by greg
Changes since 2.10: +25 -5 lines
Diff to previous 2.10 , to selected 2.38
Added -O1 option to output total solar radiance
Sat Apr 6 00:44:59 2013 UTC (12 years, 1 month ago) by greg
Changes since 2.9: +23 -10 lines
Diff to previous 2.9 , to selected 2.38
Added -5 option for 5-phase calculation (1 sun with fixed 0.533-deg dia.)
Sat Feb 9 00:20:24 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.8: +11 -3 lines
Diff to previous 2.8 , to selected 2.38
Fixed problem with sky clearness >= 12
Tue Feb 5 06:00:19 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.7: +12 -3 lines
Diff to previous 2.7 , to selected 2.38
Added -r option to gendaymtx for rotating the sky about the zenith
Sat Jan 26 00:59:08 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.6: +4 -11 lines
Diff to previous 2.6 , to selected 2.38
Fixed silly coding error that caused everything to be wrong
Fri Jan 25 23:17:31 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.5: +9 -7 lines
Diff to previous 2.5 , to selected 2.38
Fixed NaN output from non-zero illuminance before dawn or after sunset
Sun Jan 20 01:16:49 2013 UTC (12 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 2.38
Fixed usage reporting
Sun Jan 20 01:16:15 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.3: +24 -23 lines
Diff to previous 2.3 , to selected 2.38
Changed -g option to accept color specification
Sat Jan 19 20:38:36 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.2: +20 -15 lines
Diff to previous 2.2 , to selected 2.38
More bug fixes -- seems to be working OK for the most part
Fri Jan 18 19:56:03 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.1: +21 -12 lines
Diff to previous 2.1 , to selected 2.38
Fixed first major coding bugs in gendaymtx
Fri Jan 18 01:12:59 2013 UTC (12 years, 3 months ago) by greg
Diff to selected 2.38
Wrote gendaymtx based on Ian Ashdown's H32_gendaylit.c -- untested as yet
