--- ray/src/gen/gendaymtx.c 2020/04/13 17:12:19 2.36 +++ ray/src/gen/gendaymtx.c 2020/08/15 03:28:56 2.37 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaymtx.c,v 2.36 2020/04/13 17:12:19 greg Exp $"; +static const char RCSid[] = "$Id: gendaymtx.c,v 2.37 2020/08/15 03:28:56 greg Exp $"; #endif /* * gendaymtx.c @@ -135,7 +135,6 @@ extern void ComputeSky( float *parr ); /* Radiuans into degrees */ #define RadToDeg(rad) ((rad)*(180./PI)) - /* Perez sky model coefficients */ /* Reference: Perez, R., R. Seals, and J. Michalsky, 1993. "All- */ @@ -312,6 +311,7 @@ main(int argc, char *argv[]) double rotation = 0; /* site rotation (degrees) */ double elevation; /* site elevation (meters) */ int leap_day = 0; /* add leap day? */ + int sun_hours_only = 0; /* only output sun hours? */ int dir_is_horiz; /* direct is meas. on horizontal? */ FILE *sunsfp = NULL; /* output file for individual suns */ FILE *modsfp = NULL; /* modifier output file */ @@ -406,6 +406,9 @@ main(int argc, char *argv[]) case 's': /* sky only (no direct) */ suncolor[0] = suncolor[1] = suncolor[2] = 0; break; + case 'u': /* solar hours only */ + sun_hours_only = 1; + break; case 'r': /* rotate distribution */ if (argv[i][2] && argv[i][2] != 'z') goto userr; @@ -498,15 +501,7 @@ main(int argc, char *argv[]) /* process each time step in tape */ while (scanf("%d %d %lf %lf %lf\n", &mo, &da, &hr, &dir, &dif) == 5) { double sda, sta; - - mtx_offset = 3*nskypatch*nstored; - nstored += !avgSky | !nstored; - /* make space for next row */ - if (nstored > tstorage) { - tstorage += (tstorage>>1) + nstored + 7; - mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch); - } - ntsteps++; /* keep count of time steps */ + int sun_in_sky; /* compute solar position */ if ((mo == 2) & (da == 29)) { julian_date = 60; @@ -516,13 +511,26 @@ main(int argc, char *argv[]) sda = sdec(julian_date); sta = stadj(julian_date); altitude = salt(sda, hr+sta); + sun_in_sky = (altitude > -DegToRad(SUN_ANG_DEG/2.)); + if (sun_hours_only && !sun_in_sky) + continue; /* skipping nighttime points */ azimuth = sazi(sda, hr+sta) + PI - DegToRad(rotation); + mtx_offset = 3*nskypatch*nstored; + nstored += !avgSky | !nstored; + /* make space for next row */ + if (nstored > tstorage) { + tstorage += (tstorage>>1) + nstored + 7; + mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch); + } + ntsteps++; /* keep count of time steps */ + if (dir+dif <= 1e-4) { /* effectively nighttime? */ if (!avgSky | !mtx_offset) memset(mtx_data+mtx_offset, 0, sizeof(float)*3*nskypatch); - if (sunsfp) /* output black sun */ + /* output black sun? */ + if (sunsfp && sun_in_sky) OutputSun(solar_minute(julian_date,hr), 0, sunsfp, modsfp); continue; @@ -539,8 +547,8 @@ main(int argc, char *argv[]) } /* compute sky patch values */ ComputeSky(mtx_data+mtx_offset); - - if (sunsfp) /* output sun if requested */ + /* output sun if requested */ + if (sunsfp && sun_in_sky) OutputSun(solar_minute(julian_date,hr), 1, sunsfp, modsfp); @@ -642,7 +650,7 @@ alldone: fprintf(stderr, "%s: done.\n", progname); exit(0); userr: - fprintf(stderr, "Usage: %s [-v][-h][-A][-d|-s|-n][-D file][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", + fprintf(stderr, "Usage: %s [-v][-h][-A][-d|-s|-n][-u][-D file [-M modfile]][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", progname); exit(1); fmterr: @@ -814,10 +822,6 @@ OutputSun(int id, int goodsun, FILE *fp, FILE *mfp) FVECT sv; srad = DegToRad(SUN_ANG_DEG/2.); - - if (altitude < -srad) /* well below horizon? */ - return; - srad = goodsun ? dir_illum/(WHTEFFICACY * PI*srad*srad) : 0; vector(sv, altitude, azimuth); fprintf(fp, "\nvoid light solar%d\n0\n0\n", id);
