--- ray/src/gen/gendaymtx.c 2019/12/28 18:05:14 2.31 +++ ray/src/gen/gendaymtx.c 2020/01/06 21:22:46 2.33 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaymtx.c,v 2.31 2019/12/28 18:05:14 greg Exp $"; +static const char RCSid[] = "$Id: gendaymtx.c,v 2.33 2020/01/06 21:22:46 greg Exp $"; #endif /* * gendaymtx.c @@ -313,7 +313,6 @@ main(int argc, char *argv[]) int tstorage = 0; /* number of allocated time steps */ int nstored = 0; /* number of time steps in matrix */ int last_monthly = 0; /* month of last report */ - int inconsistent = 0; /* inconsistent options set? */ int mo, da; /* month (1-12) and day (1-31) */ double hr; /* hour (local standard time) */ double dir, dif; /* direct and diffuse values */ @@ -364,24 +363,16 @@ main(int argc, char *argv[]) rhsubdiv = atoi(argv[++i]); break; case 'c': /* sky color */ - inconsistent |= (skycolor[1] <= 1e-4); skycolor[0] = atof(argv[++i]); skycolor[1] = atof(argv[++i]); skycolor[2] = atof(argv[++i]); break; case 'd': /* solar (direct) only */ skycolor[0] = skycolor[1] = skycolor[2] = 0; - if (suncolor[1] <= 1e-4) { - inconsistent = 1; - suncolor[0] = suncolor[1] = suncolor[2] = 1; - } + grefl[0] = grefl[1] = grefl[2] = 0; break; case 's': /* sky only (no direct) */ suncolor[0] = suncolor[1] = suncolor[2] = 0; - if (skycolor[1] <= 1e-4) { - inconsistent = 1; - skycolor[0] = skycolor[1] = skycolor[2] = 1; - } break; case 'r': /* rotate distribution */ if (argv[i][2] && argv[i][2] != 'z') @@ -406,9 +397,6 @@ main(int argc, char *argv[]) } if (i < argc-1) goto userr; - if (inconsistent) - fprintf(stderr, "%s: WARNING: inconsistent -s, -d, -c options!\n", - progname); if (i == argc-1 && freopen(argv[i], "r", stdin) == NULL) { fprintf(stderr, "%s: cannot open '%s' for input\n", progname, argv[i]); @@ -667,11 +655,6 @@ ComputeSky(float *parr) diff_illum = diff_irrad * WHTEFFICACY; dir_illum = dir_irrad * WHTEFFICACY; } - - if (bright(skycolor) <= 1e-4) { /* 0 sky component? */ - memset(parr, 0, sizeof(float)*3*nskypatch); - return; - } /* Compute ground radiance (include solar contribution if any) */ parr[0] = diff_illum; if (altitude > 0) @@ -679,6 +662,10 @@ ComputeSky(float *parr) parr[2] = parr[1] = parr[0] *= (1./PI/WHTEFFICACY); multcolor(parr, grefl); + if (bright(skycolor) <= 1e-4) { /* 0 sky component? */ + memset(parr+3, 0, sizeof(float)*3*(nskypatch-1)); + return; + } /* Calculate Perez sky model parameters */ CalcPerezParam(sun_zenith, sky_clearness, sky_brightness, index);
