--- ray/src/gen/gendaymtx.c 2016/08/20 15:42:38 2.25 +++ ray/src/gen/gendaymtx.c 2019/12/28 18:05:14 2.31 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaymtx.c,v 2.25 2016/08/20 15:42:38 greg Exp $"; +static const char RCSid[] = "$Id: gendaymtx.c,v 2.31 2019/12/28 18:05:14 greg Exp $"; #endif /* * gendaymtx.c @@ -81,16 +81,13 @@ static const char RCSid[] = "$Id: gendaymtx.c,v 2.25 2 /* Include files */ #define _USE_MATH_DEFINES -#include #include -#include #include +#include "platform.h" #include "rtmath.h" #include "rtio.h" -#include "resolu.h" -#include "platform.h" #include "color.h" -#include "resolu.h" +#include "sun.h" char *progname; /* Program name */ char errmsg[128]; /* Error message buffer */ @@ -255,16 +252,6 @@ static const ModelCoeff DirectLumEff[8] = #define NSUNPATCH 4 /* max. # patches to spread sun into */ #endif -extern int jdate(int month, int day); -extern double stadj(int jd); -extern double sdec(int jd); -extern double salt(double sd, double st); -extern double sazi(double sd, double st); - /* sun calculation constants */ -extern double s_latitude; -extern double s_longitude; -extern double s_meridian; - int nsuns = NSUNPATCH; /* number of sun patches to use */ double fixed_sun_sa = -1; /* fixed solid angle per sun? */ @@ -321,8 +308,10 @@ main(int argc, char *argv[]) double elevation; /* site elevation (meters) */ int dir_is_horiz; /* direct is meas. on horizontal? */ float *mtx_data = NULL; /* our matrix data */ - int ntsteps = 0; /* number of rows in matrix */ - int step_alloc = 0; + int avgSky = 0; /* compute average sky r.t. matrix? */ + int ntsteps = 0; /* number of time steps */ + int tstorage = 0; /* number of allocated time steps */ + int nstored = 0; /* number of time steps in matrix */ int last_monthly = 0; /* month of last report */ int inconsistent = 0; /* inconsistent options set? */ int mo, da; /* month (1-12) and day (1-31) */ @@ -409,6 +398,9 @@ main(int argc, char *argv[]) } fixed_sun_sa *= fixed_sun_sa*PI; break; + case 'A': /* compute average sky */ + avgSky = 1; + break; default: goto userr; } @@ -474,17 +466,23 @@ main(int argc, char *argv[]) s_latitude = DegToRad(s_latitude); s_longitude = DegToRad(s_longitude); s_meridian = DegToRad(s_meridian); + /* initial allocation */ + mtx_data = resize_dmatrix(mtx_data, tstorage=2, nskypatch); /* process each time step in tape */ while (scanf("%d %d %lf %lf %lf\n", &mo, &da, &hr, &dir, &dif) == 5) { double sda, sta; - /* make space for next time step */ - mtx_offset = 3*nskypatch*ntsteps++; - if (ntsteps > step_alloc) { - step_alloc += (step_alloc>>1) + ntsteps + 7; - mtx_data = resize_dmatrix(mtx_data, step_alloc, nskypatch); + + mtx_offset = 3*nskypatch*nstored; + nstored += !avgSky | !nstored; + /* make space for next row */ + if (nstored > tstorage) { + tstorage += (tstorage>>1) + nstored + 7; + mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch); } + ntsteps++; /* keep count of time steps */ if (dif <= 1e-4) { - memset(mtx_data+mtx_offset, 0, sizeof(float)*3*nskypatch); + if (!avgSky | !mtx_offset) + memset(mtx_data+mtx_offset, 0, sizeof(float)*3*nskypatch); continue; } if (verbose && mo != last_monthly) @@ -509,6 +507,9 @@ main(int argc, char *argv[]) /* compute sky patch values */ ComputeSky(mtx_data+mtx_offset); AddDirect(mtx_data+mtx_offset); + /* update cumulative sky? */ + for (i = 3*nskypatch*(avgSky&(ntsteps>1)); i--; ) + mtx_data[i] += mtx_data[mtx_offset+i]; } /* check for junk at end */ while ((i = fgetc(stdin)) != EOF) @@ -520,6 +521,13 @@ main(int argc, char *argv[]) fputs(buf, stderr); fputc('\n', stderr); break; } + if (!ntsteps) { + fprintf(stderr, "%s: no valid time steps on input\n", progname); + exit(1); + } + dif = 1./(double)ntsteps; /* average sky? */ + for (i = 3*nskypatch*(avgSky&(ntsteps>1)); i--; ) + mtx_data[i] *= dif; /* write out matrix */ if (outfmt != 'a') SET_FILE_BINARY(stdout); @@ -528,15 +536,17 @@ main(int argc, char *argv[]) #endif if (verbose) fprintf(stderr, "%s: writing %smatrix with %d time steps...\n", - progname, outfmt=='a' ? "" : "binary ", ntsteps); + progname, outfmt=='a' ? "" : "binary ", nstored); if (doheader) { newheader("RADIANCE", stdout); printargs(argc, argv, stdout); printf("LATLONG= %.8f %.8f\n", RadToDeg(s_latitude), -RadToDeg(s_longitude)); printf("NROWS=%d\n", nskypatch); - printf("NCOLS=%d\n", ntsteps); + printf("NCOLS=%d\n", nstored); printf("NCOMP=3\n"); + if ((outfmt == 'f') | (outfmt == 'd')) + fputendian(stdout); fputformat((char *)getfmtname(outfmt), stdout); putchar('\n'); } @@ -545,24 +555,24 @@ main(int argc, char *argv[]) mtx_offset = 3*i; switch (outfmt) { case 'a': - for (j = 0; j < ntsteps; j++) { + for (j = 0; j < nstored; j++) { printf("%.3g %.3g %.3g\n", mtx_data[mtx_offset], mtx_data[mtx_offset+1], mtx_data[mtx_offset+2]); mtx_offset += 3*nskypatch; } - if (ntsteps > 1) + if (nstored > 1) fputc('\n', stdout); break; case 'f': - for (j = 0; j < ntsteps; j++) { + for (j = 0; j < nstored; j++) { putbinary(mtx_data+mtx_offset, sizeof(float), 3, stdout); mtx_offset += 3*nskypatch; } break; case 'd': - for (j = 0; j < ntsteps; j++) { + for (j = 0; j < nstored; j++) { double ment[3]; ment[0] = mtx_data[mtx_offset]; ment[1] = mtx_data[mtx_offset+1]; @@ -581,7 +591,7 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: done.\n", progname); exit(0); userr: - fprintf(stderr, "Usage: %s [-v][-h][-d|-s][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", + fprintf(stderr, "Usage: %s [-v][-h][-A][-d|-s][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", progname); exit(1); fmterr: @@ -953,7 +963,9 @@ int CalcSkyParamFromIllum() /* Convert illuminance to irradiance */ index = GetCategoryIndex(); diff_irrad = diff_illum / CalcDiffuseIllumRatio(index); - dir_irrad = dir_illum / CalcDirectIllumRatio(index); + dir_irrad = CalcDirectIllumRatio(index); + if (dir_irrad > 0.1) + dir_irrad = dir_illum / dir_irrad; /* Calculate sky brightness and clearness */ sky_brightness = CalcSkyBrightness();
