--- ray/src/gen/gendaymtx.c 2013/01/19 20:38:36 2.3 +++ ray/src/gen/gendaymtx.c 2013/01/20 01:16:15 2.4 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaymtx.c,v 2.3 2013/01/19 20:38:36 greg Exp $"; +static const char RCSid[] = "$Id: gendaymtx.c,v 2.4 2013/01/20 01:16:15 greg Exp $"; #endif /* * gendaymtx.c @@ -260,18 +260,16 @@ extern double s_latitude; extern double s_longitude; extern double s_meridian; -double grefl = 0.2; /* diffuse ground reflectance */ - int verbose = 0; /* progress reports to stderr? */ int outfmt = 'a'; /* output format */ int rhsubdiv = 1; /* Reinhart sky subdivisions */ -float skycolor[3] = {.96, 1.004, 1.118}; /* sky coloration */ +COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */ +COLOR suncolor = {1., 1., 1.}; /* sun color */ +COLOR grefl = {.2, .2, .2}; /* ground reflectance */ -int do_sun = 1; /* output direct solar contribution? */ - int nskypatch; /* number of Reinhart patches */ float *rh_palt; /* sky patch altitudes (radians) */ float *rh_pazi; /* sky patch azimuths (radians) */ @@ -309,13 +307,15 @@ main(int argc, char *argv[]) /* get options */ for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { - case 'g': - grefl = atof(argv[++i]); + case 'g': /* ground reflectance */ + grefl[0] = atof(argv[++i]); + grefl[1] = atof(argv[++i]); + grefl[2] = atof(argv[++i]); break; - case 'v': + case 'v': /* verbose progress reports */ verbose++; break; - case 'o': + case 'o': /* output format */ switch (argv[i][2]) { case 'f': case 'd': @@ -326,20 +326,21 @@ main(int argc, char *argv[]) goto userr; } break; - case 'm': + case 'm': /* Reinhart subdivisions */ rhsubdiv = atoi(argv[++i]); break; - case 'c': + case 'c': /* sky color */ skycolor[0] = atof(argv[++i]); skycolor[1] = atof(argv[++i]); skycolor[2] = atof(argv[++i]); break; - case 'd': - do_sun = 1; + case 'd': /* solar (direct) only */ skycolor[0] = skycolor[1] = skycolor[2] = 0; + if (suncolor[1] <= 1e-4) + suncolor[0] = suncolor[1] = suncolor[2] = 1; break; - case 's': - do_sun = 0; + case 's': /* sky only (no direct) */ + suncolor[0] = suncolor[1] = suncolor[2] = 0; if (skycolor[1] <= 1e-4) skycolor[0] = skycolor[1] = skycolor[2] = 1; break; @@ -433,8 +434,7 @@ main(int argc, char *argv[]) } /* compute sky patch values */ ComputeSky(mtx_data+mtx_offset); - if (do_sun) - AddDirect(mtx_data+mtx_offset); + AddDirect(mtx_data+mtx_offset); } /* check for junk at end */ while ((i = fgetc(stdin)) != EOF) @@ -565,7 +565,8 @@ ComputeSky(float *parr) parr[0] = diff_illum; if (altitude > 0) parr[0] += dir_illum * sin(altitude); - parr[2] = parr[1] = parr[0] *= grefl*(1./PI/WHTEFFICACY); + parr[2] = parr[1] = parr[0] *= (1./PI/WHTEFFICACY); + multcolor(parr, grefl); /* Calculate Perez sky model parameters */ CalcPerezParam(sun_zenith, sky_clearness, sky_brightness, index); @@ -602,7 +603,7 @@ AddDirect(float *parr) double wta[NSUNPATCH], wtot; int i, j, p; - if (!do_sun || dir_illum < 1e-4) + if (dir_illum <= 1e-4 || bright(suncolor) <= 1e-4) return; /* identify NSUNPATCH closest patches */ for (i = NSUNPATCH; i--; ) @@ -632,9 +633,9 @@ AddDirect(float *parr) float *pdest = parr + 3*near_patch[i]; float val_add = wta[i] * dir_illum / (WHTEFFICACY * wtot * rh_dom[near_patch[i]]); - *pdest++ += val_add; - *pdest++ += val_add; - *pdest++ += val_add; + *pdest++ += val_add*suncolor[0]; + *pdest++ += val_add*suncolor[1]; + *pdest++ += val_add*suncolor[2]; } }
