Eliminated NaN error pointed out by David Geisler-Moroder
Mussed up last change
Removed fprintf(stderr, statements from accidental check-in
Added warning about inconsistent option settings
Added error message to gendaymtx with -5 option used without argument
Changed "secret" -5 option so it now takes sun diameter (in degrees) as arg
Fixed another warning
Fixed operator precedence error
Hopeful fix to Windows realloc performance issue
Fixed problem case when computed sky is everywhere zero
Fixed potential bug pointed out by Ian Ashdown
Added -O1 option to output total solar radiance
Added -5 option for 5-phase calculation (1 sun with fixed 0.533-deg dia.)
Fixed problem with sky clearness >= 12
Added -r option to gendaymtx for rotating the sky about the zenith
Fixed silly coding error that caused everything to be wrong
Fixed NaN output from non-zero illuminance before dawn or after sunset
Fixed usage reporting
Changed -g option to accept color specification
More bug fixes -- seems to be working OK for the most part
Fixed first major coding bugs in gendaymtx
