--- ray/src/gen/gendaymtx.c 2013/01/18 19:56:03 2.2 +++ ray/src/gen/gendaymtx.c 2013/01/25 23:17:31 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaymtx.c,v 2.2 2013/01/18 19:56:03 greg Exp $"; +static const char RCSid[] = "$Id: gendaymtx.c,v 2.6 2013/01/25 23:17:31 greg Exp $"; #endif /* * gendaymtx.c @@ -246,6 +246,10 @@ static const ModelCoeff DirectLumEff[8] = { 101.18, 1.58, -1.10, -8.29 } }; +#ifndef NSUNPATCH +#define NSUNPATCH 4 /* # patches to spread sun into */ +#endif + extern int jdate(int month, int day); extern double stadj(int jd); extern double sdec(int jd); @@ -256,18 +260,16 @@ extern double s_latitude; extern double s_longitude; extern double s_meridian; -double grefl = 0.2; /* diffuse ground reflectance */ - int verbose = 0; /* progress reports to stderr? */ int outfmt = 'a'; /* output format */ int rhsubdiv = 1; /* Reinhart sky subdivisions */ -float skycolor[3] = {.96, 1.004, 1.118}; /* sky coloration */ +COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */ +COLOR suncolor = {1., 1., 1.}; /* sun color */ +COLOR grefl = {.2, .2, .2}; /* ground reflectance */ -int do_sun = 1; /* output direct solar contribution? */ - int nskypatch; /* number of Reinhart patches */ float *rh_palt; /* sky patch altitudes (radians) */ float *rh_pazi; /* sky patch azimuths (radians) */ @@ -305,13 +307,15 @@ main(int argc, char *argv[]) /* get options */ for (i = 1; i < argc && argv[i][0] == '-'; i++) switch (argv[i][1]) { - case 'g': - grefl = atof(argv[++i]); + case 'g': /* ground reflectance */ + grefl[0] = atof(argv[++i]); + grefl[1] = atof(argv[++i]); + grefl[2] = atof(argv[++i]); break; - case 'v': + case 'v': /* verbose progress reports */ verbose++; break; - case 'o': + case 'o': /* output format */ switch (argv[i][2]) { case 'f': case 'd': @@ -322,20 +326,21 @@ main(int argc, char *argv[]) goto userr; } break; - case 'm': + case 'm': /* Reinhart subdivisions */ rhsubdiv = atoi(argv[++i]); break; - case 'c': + case 'c': /* sky color */ skycolor[0] = atof(argv[++i]); skycolor[1] = atof(argv[++i]); skycolor[2] = atof(argv[++i]); break; - case 'd': - do_sun = 1; + case 'd': /* solar (direct) only */ skycolor[0] = skycolor[1] = skycolor[2] = 0; + if (suncolor[1] <= 1e-4) + suncolor[0] = suncolor[1] = suncolor[2] = 1; break; - case 's': - do_sun = 0; + case 's': /* sky only (no direct) */ + suncolor[0] = suncolor[1] = suncolor[2] = 0; if (skycolor[1] <= 1e-4) skycolor[0] = skycolor[1] = skycolor[2] = 1; break; @@ -429,8 +434,7 @@ main(int argc, char *argv[]) } /* compute sky patch values */ ComputeSky(mtx_data+mtx_offset); - if (do_sun) - AddDirect(mtx_data+mtx_offset); + AddDirect(mtx_data+mtx_offset); } /* check for junk at end */ while ((i = fgetc(stdin)) != EOF) @@ -455,7 +459,7 @@ main(int argc, char *argv[]) switch (outfmt) { case 'a': for (j = 0; j < ntsteps; j++) { - printf("%.3e %.3e %.3e\n", mtx_data[mtx_offset], + printf("%.3g %.3g %.3g\n", mtx_data[mtx_offset], mtx_data[mtx_offset+1], mtx_data[mtx_offset+2]); mtx_offset += 3*nskypatch; @@ -490,7 +494,7 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: done.\n", progname); exit(0); userr: - fprintf(stderr, "Usage: %s [-v][-d|-s][-m N][-g refl][-c r g b][-o{f|d}] [tape.wea]\n", + fprintf(stderr, "Usage: %s [-v][-d|-s][-m N][-g r g b][-c r g b][-o{f|d}] [tape.wea]\n", progname); exit(1); fmterr: @@ -517,13 +521,15 @@ ComputeSky(float *parr) /* Calculate atmospheric precipitable water content */ apwc = CalcPrecipWater(dew_point); - /* Limit solar altitude to keep circumsolar off zenith */ - if (altitude > DegToRad(87.0)) - altitude = DegToRad(87.0); + /* Calculate sun zenith angle (don't let it dip below horizon) */ + /* Also limit minimum angle to keep circumsolar off zenith */ + if (altitude <= 0.0) + sun_zenith = DegToRad(90.0); + else if (altitude >= DegToRad(87.0)) + sun_zenith = DegToRad(3.0); + else + sun_zenith = DegToRad(90.0) - altitude; - /* Calculate sun zenith angle */ - sun_zenith = DegToRad(90.0) - altitude; - /* Compute the inputs for the calculation of the sky distribution */ if (input == 0) /* XXX never used */ @@ -558,10 +564,11 @@ ComputeSky(float *parr) return; } /* Compute ground radiance (include solar contribution if any) */ - parr[0] = diff_illum * (1./PI/WHTEFFICACY); + parr[0] = diff_illum; if (altitude > 0) - parr[0] += dir_illum * sin(altitude) * (1./PI/WHTEFFICACY); - parr[2] = parr[1] = parr[0]; + parr[0] += dir_illum * sin(altitude); + parr[2] = parr[1] = parr[0] *= (1./PI/WHTEFFICACY); + multcolor(parr, grefl); /* Calculate Perez sky model parameters */ CalcPerezParam(sun_zenith, sky_clearness, sky_brightness, index); @@ -593,15 +600,15 @@ void AddDirect(float *parr) { FVECT svec; - double near_dprod[4]; - int near_patch[4]; - double wta[4], wtot; + double near_dprod[NSUNPATCH]; + int near_patch[NSUNPATCH]; + double wta[NSUNPATCH], wtot; int i, j, p; - if (!do_sun || dir_illum < 1e-4) + if (dir_illum <= 1e-4 || bright(suncolor) <= 1e-4) return; - /* identify 4 closest patches */ - for (i = 4; i--; ) + /* identify NSUNPATCH closest patches */ + for (i = NSUNPATCH; i--; ) near_dprod[i] = -1.; vector(svec, altitude, azimuth); for (p = 1; p < nskypatch; p++) { @@ -609,9 +616,9 @@ AddDirect(float *parr) double dprod; rh_vector(pvec, p); dprod = DOT(pvec, svec); - for (i = 0; i < 4; i++) + for (i = 0; i < NSUNPATCH; i++) if (dprod > near_dprod[i]) { - for (j = 4; --j > i; ) { + for (j = NSUNPATCH; --j > i; ) { near_dprod[j] = near_dprod[j-1]; near_patch[j] = near_patch[j-1]; } @@ -621,16 +628,16 @@ AddDirect(float *parr) } } wtot = 0; /* weight by proximity */ - for (i = 4; i--; ) + for (i = NSUNPATCH; i--; ) wtot += wta[i] = 1./(1.002 - near_dprod[i]); /* add to nearest patch radiances */ - for (i = 4; i--; ) { + for (i = NSUNPATCH; i--; ) { float *pdest = parr + 3*near_patch[i]; float val_add = wta[i] * dir_illum / (WHTEFFICACY * wtot * rh_dom[near_patch[i]]); - *pdest++ += val_add; - *pdest++ += val_add; - *pdest++ += val_add; + *pdest++ += val_add*suncolor[0]; + *pdest++ += val_add*suncolor[1]; + *pdest++ += val_add*suncolor[2]; } } @@ -665,7 +672,8 @@ rh_init(void) for (i = 0; i < NROW*rhsubdiv; i++) { const float ralt = alpha*(i + .5); const int ninrow = tnaz[i/rhsubdiv]*rhsubdiv; - const float dom = (sin(alpha*(i+1)) - sin(alpha*i))/ninrow; + const float dom = 2.*PI*(sin(alpha*(i+1)) - sin(alpha*i)) / + (double)ninrow; for (j = 0; j < ninrow; j++) { rh_palt[p] = ralt; rh_pazi[p] = 2.*PI * j / (double)ninrow;
