--- ray/src/gen/gendaymtx.c 2013/04/06 00:44:59 2.10 +++ ray/src/gen/gendaymtx.c 2013/10/04 04:31:18 2.13 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaymtx.c,v 2.10 2013/04/06 00:44:59 greg Exp $"; +static const char RCSid[] = "$Id: gendaymtx.c,v 2.13 2013/10/04 04:31:18 greg Exp $"; #endif /* * gendaymtx.c @@ -108,6 +108,7 @@ double sky_clearness; /* Sky clearness */ double solar_rad; /* Solar radiance */ double sun_zenith; /* Sun zenith angle (radians) */ int input = 0; /* Input type */ +int output = 0; /* Output type */ extern double dmax( double, double ); extern double CalcAirMass(); @@ -208,7 +209,7 @@ static const CategoryBounds SkyClearCat[8] = { 1.950, 2.800 }, { 2.800, 4.500 }, { 4.500, 6.200 }, - { 6.200, 12.00 } /* Clear */ + { 6.200, 12.01 } /* Clear */ }; /* Luminous efficacy model coefficients */ @@ -330,6 +331,20 @@ main(int argc, char *argv[]) goto userr; } break; + case 'O': /* output type */ + switch (argv[i][2]) { + case '0': + output = 0; + break; + case '1': + output = 1; + break; + default: + goto userr; + } + if (argv[i][3]) + goto userr; + break; case 'm': /* Reinhart subdivisions */ rhsubdiv = atoi(argv[++i]); break; @@ -510,7 +525,7 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: done.\n", progname); exit(0); userr: - fprintf(stderr, "Usage: %s [-v][-d|-s][-r deg][-m N][-g r g b][-c r g b][-o{f|d}] [tape.wea]\n", + fprintf(stderr, "Usage: %s [-v][-d|-s][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", progname); exit(1); fmterr: @@ -569,7 +584,7 @@ ComputeSky(float *parr) /* Limit sky brightness */ if (sky_brightness < 0.01) - sky_brightness = 0.01; + sky_brightness = 0.01; /* Calculate illuminance */ index = GetCategoryIndex(); @@ -582,6 +597,11 @@ ComputeSky(float *parr) index = CalcSkyParamFromIllum(); } + if (output == 1) { /* hack for solar radiance */ + diff_illum = diff_irrad * WHTEFFICACY; + dir_illum = dir_irrad * WHTEFFICACY; + } + if (bright(skycolor) <= 1e-4) { /* 0 sky component? */ memset(parr, 0, sizeof(float)*3*nskypatch); return; @@ -602,6 +622,12 @@ ComputeSky(float *parr) /* Calculate relative horizontal illuminance */ norm_diff_illum = CalcRelHorzIllum(parr); + /* Check for zero sky -- make uniform in that case */ + if (norm_diff_illum <= FTINY) { + for (i = 1; i < nskypatch; i++) + setcolor(parr+3*i, 1., 1., 1.); + norm_diff_illum = PI; + } /* Normalization coefficient */ norm_diff_illum = diff_illum / norm_diff_illum; @@ -801,7 +827,7 @@ double CalcSkyClearness() double sz_cubed; /* Sun zenith angle cubed */ /* Calculate sun zenith angle cubed */ - sz_cubed = pow(sun_zenith, 3.0); + sz_cubed = sun_zenith*sun_zenith*sun_zenith; return ((diff_irrad + dir_irrad) / diff_irrad + 1.041 * sz_cubed) / (1.0 + 1.041 * sz_cubed); @@ -832,7 +858,7 @@ double CalcDiffuseIrradiance() double CalcDirectIrradiance() { return CalcDiffuseIrradiance() * ((sky_clearness - 1.0) * (1 + 1.041 - * pow(sun_zenith, 3.0))); + * sun_zenith*sun_zenith*sun_zenith)); } /* Calculate sky brightness and clearness from illuminance values */
