root/radiance/ray/src/gen/gendaymtx.c
Tue Jun 17 21:01:21 2014 UTC (9 years, 10 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Diff to previous 2.15 , to selected 2.7
Fixed operator precedence error
Tue Jun 17 18:51:47 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.14: +6 -2 lines
Diff to previous 2.14 , to selected 2.7
Hopeful fix to Windows realloc performance issue
Fri May 30 00:00:54 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.13: +36 -2 lines
Fri Oct 4 04:31:18 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.12: +7 -1 lines
Fixed problem case when computed sky is everywhere zero
Thu Jun 6 20:21:10 2013 UTC (10 years, 10 months ago) by greg
Fixed potential bug pointed out by Ian Ashdown
Tue Apr 30 17:05:27 2013 UTC (11 years ago) by greg
Changes since 2.10: +25 -5 lines
Added -O1 option to output total solar radiance
Sat Apr 6 00:44:59 2013 UTC (11 years ago) by greg
Changes since 2.9: +23 -10 lines
Added -5 option for 5-phase calculation (1 sun with fixed 0.533-deg dia.)
Sat Feb 9 00:20:24 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.8: +11 -3 lines
Fixed problem with sky clearness >= 12
Tue Feb 5 06:00:19 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.7: +12 -3 lines
Added -r option to gendaymtx for rotating the sky about the zenith
Sat Jan 26 00:59:08 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.6: +4 -11 lines
Fixed silly coding error that caused everything to be wrong
Fri Jan 25 23:17:31 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.5: +9 -7 lines
Fixed NaN output from non-zero illuminance before dawn or after sunset
Sun Jan 20 01:16:49 2013 UTC (11 years, 3 months ago) by greg
Fixed usage reporting
Sun Jan 20 01:16:15 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.3: +24 -23 lines
Changed -g option to accept color specification
Sat Jan 19 20:38:36 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.2: +20 -15 lines
More bug fixes -- seems to be working OK for the most part
Fri Jan 18 19:56:03 2013 UTC (11 years, 3 months ago) by greg
Changes since 2.1: +21 -12 lines
Fixed first major coding bugs in gendaymtx
Fri Jan 18 01:12:59 2013 UTC (11 years, 3 months ago) by greg
Diff to selected 2.7
Wrote gendaymtx based on Ian Ashdown's H32_gendaylit.c -- untested as yet
