--- ray/src/gen/gendaymtx.c 2013/02/09 00:20:24 2.9 +++ ray/src/gen/gendaymtx.c 2013/04/30 17:05:27 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaymtx.c,v 2.9 2013/02/09 00:20:24 greg Exp $"; +static const char RCSid[] = "$Id: gendaymtx.c,v 2.11 2013/04/30 17:05:27 greg Exp $"; #endif /* * gendaymtx.c @@ -108,6 +108,7 @@ double sky_clearness; /* Sky clearness */ double solar_rad; /* Solar radiance */ double sun_zenith; /* Sun zenith angle (radians) */ int input = 0; /* Input type */ +int output = 0; /* Output type */ extern double dmax( double, double ); extern double CalcAirMass(); @@ -247,7 +248,7 @@ static const ModelCoeff DirectLumEff[8] = }; #ifndef NSUNPATCH -#define NSUNPATCH 4 /* # patches to spread sun into */ +#define NSUNPATCH 4 /* max. # patches to spread sun into */ #endif extern int jdate(int month, int day); @@ -260,6 +261,9 @@ extern double s_latitude; extern double s_longitude; extern double s_meridian; +int nsuns = NSUNPATCH; /* number of sun patches to use */ +double fixed_sun_sa = -1; /* fixed solid angle per sun? */ + int verbose = 0; /* progress reports to stderr? */ int outfmt = 'a'; /* output format */ @@ -327,6 +331,20 @@ main(int argc, char *argv[]) goto userr; } break; + case 'O': /* output type */ + switch (argv[i][2]) { + case '0': + output = 0; + break; + case '1': + output = 1; + break; + default: + goto userr; + } + if (argv[i][3]) + goto userr; + break; case 'm': /* Reinhart subdivisions */ rhsubdiv = atoi(argv[++i]); break; @@ -350,6 +368,10 @@ main(int argc, char *argv[]) goto userr; rotation = atof(argv[++i]); break; + case '5': /* 5-phase calculation */ + nsuns = 1; + fixed_sun_sa = 6.797e-05; + break; default: goto userr; } @@ -503,7 +525,7 @@ main(int argc, char *argv[]) fprintf(stderr, "%s: done.\n", progname); exit(0); userr: - fprintf(stderr, "Usage: %s [-v][-d|-s][-r deg][-m N][-g r g b][-c r g b][-o{f|d}] [tape.wea]\n", + fprintf(stderr, "Usage: %s [-v][-d|-s][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", progname); exit(1); fmterr: @@ -562,7 +584,7 @@ ComputeSky(float *parr) /* Limit sky brightness */ if (sky_brightness < 0.01) - sky_brightness = 0.01; + sky_brightness = 0.01; /* Calculate illuminance */ index = GetCategoryIndex(); @@ -575,6 +597,11 @@ ComputeSky(float *parr) index = CalcSkyParamFromIllum(); } + if (output == 1) { /* hack for solar radiance */ + diff_illum = diff_irrad * WHTEFFICACY; + dir_illum = dir_irrad * WHTEFFICACY; + } + if (bright(skycolor) <= 1e-4) { /* 0 sky component? */ memset(parr, 0, sizeof(float)*3*nskypatch); return; @@ -617,8 +644,12 @@ AddDirect(float *parr) if (dir_illum <= 1e-4 || bright(suncolor) <= 1e-4) return; - /* identify NSUNPATCH closest patches */ - for (i = NSUNPATCH; i--; ) + /* identify nsuns closest patches */ + if (nsuns > NSUNPATCH) + nsuns = NSUNPATCH; + else if (nsuns <= 0) + nsuns = 1; + for (i = nsuns; i--; ) near_dprod[i] = -1.; vector(svec, altitude, azimuth); for (p = 1; p < nskypatch; p++) { @@ -626,9 +657,9 @@ AddDirect(float *parr) double dprod; rh_vector(pvec, p); dprod = DOT(pvec, svec); - for (i = 0; i < NSUNPATCH; i++) + for (i = 0; i < nsuns; i++) if (dprod > near_dprod[i]) { - for (j = NSUNPATCH; --j > i; ) { + for (j = nsuns; --j > i; ) { near_dprod[j] = near_dprod[j-1]; near_patch[j] = near_patch[j-1]; } @@ -638,13 +669,15 @@ AddDirect(float *parr) } } wtot = 0; /* weight by proximity */ - for (i = NSUNPATCH; i--; ) + for (i = nsuns; i--; ) wtot += wta[i] = 1./(1.002 - near_dprod[i]); /* add to nearest patch radiances */ - for (i = NSUNPATCH; i--; ) { + for (i = nsuns; i--; ) { float *pdest = parr + 3*near_patch[i]; - float val_add = wta[i] * dir_illum / - (WHTEFFICACY * wtot * rh_dom[near_patch[i]]); + float val_add = wta[i] * dir_illum / (WHTEFFICACY * wtot); + + val_add /= (fixed_sun_sa > 0) ? fixed_sun_sa + : rh_dom[near_patch[i]] ; *pdest++ += val_add*suncolor[0]; *pdest++ += val_add*suncolor[1]; *pdest++ += val_add*suncolor[2]; @@ -788,7 +821,7 @@ double CalcSkyClearness() double sz_cubed; /* Sun zenith angle cubed */ /* Calculate sun zenith angle cubed */ - sz_cubed = pow(sun_zenith, 3.0); + sz_cubed = sun_zenith*sun_zenith*sun_zenith; return ((diff_irrad + dir_irrad) / diff_irrad + 1.041 * sz_cubed) / (1.0 + 1.041 * sz_cubed); @@ -819,7 +852,7 @@ double CalcDiffuseIrradiance() double CalcDirectIrradiance() { return CalcDiffuseIrradiance() * ((sky_clearness - 1.0) * (1 + 1.041 - * pow(sun_zenith, 3.0))); + * sun_zenith*sun_zenith*sun_zenith)); } /* Calculate sky brightness and clearness from illuminance values */
