root/radiance/ray/src/gen/gendaylit.c
Thu Jan 28 19:03:15 2021 UTC (3 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.20: +10 -2 lines
Diff to previous 2.20 , to selected 2.19
feat: Jan added -d option for setting dewpoint as requested by Zack Rogers
Wed Nov 18 17:18:41 2020 UTC (3 years, 5 months ago) by greg
Changes since 2.19: +4 -4 lines
Diff to previous 2.19
fix(gendaylit): correction to sky integration factor for solid angle
Revision 2.19 - (view) (download) (annotate) - [selected]
Wed Dec 4 18:11:57 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.18: +5 -5 lines
Diff to previous 2.18
Added -y option to usage
Thu Nov 7 23:15:06 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.17: +19 -12 lines
Diff to previous 2.17 , to selected 2.19
Added more accurate Michalsky solar position calculation and made correction to old IES handbook formula (thanks to Axel Jacobs)
Fri Aug 31 16:01:45 2018 UTC (5 years, 7 months ago) by greg
Changes since 2.16: +61 -9 lines
Diff to previous 2.16 , to selected 2.19
New versions of evalglare and gendaylit from Jan Wienold
Wed Jul 30 17:30:27 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.15: +1 -7 lines
Diff to previous 2.15 , to selected 2.19
Improved use of sun.h
Mon Nov 18 18:07:16 2013 UTC (10 years, 5 months ago) by greg
Diff to previous 2.14 , to selected 2.19
Fixes for Windows
Fri Sep 6 16:54:06 2013 UTC (10 years, 7 months ago) by greg
Changes since 2.13: +181 -155 lines
Diff to previous 2.13 , to selected 2.19
Latest updates and bug fixesx from Wendelin
Wed Aug 14 17:11:43 2013 UTC (10 years, 8 months ago) by greg
Diff to previous 2.12 , to selected 2.19
Inserted math definition macro
Fri Aug 9 16:44:19 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.11: +307 -152 lines
Diff to previous 2.11 , to selected 2.19
Bug fixes and new -E and -i options (from Wendelin Sprenger and Jan Wienold)
Tue Apr 30 17:05:27 2013 UTC (10 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 2.19
Added -O1 option to output total solar radiance
Wed Feb 13 18:30:22 2013 UTC (11 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 2.19
Added #define _USE_MATH_DEFINES
Wed Jan 30 01:02:42 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.8: +281 -368 lines
Diff to previous 2.8 , to selected 2.19
Replaced gendaylit with new version by Wendelin Sprenger and Jan Wienold
Wed Oct 5 17:33:36 2011 UTC (12 years, 6 months ago) by greg
Diff to previous 2.7 , to selected 2.19
Forgot to include rtmath.h
Wed Oct 5 17:20:55 2011 UTC (12 years, 6 months ago) by greg
Changes since 2.6: +35 -35 lines
Diff to previous 2.6 , to selected 2.19
Windows compatibility changes from Bill Hoffman
Tue Aug 16 18:09:53 2011 UTC (12 years, 8 months ago) by greg
Changes since 2.5: +2 -3 lines
Diff to previous 2.5 , to selected 2.19
Minor fixes
Wed Aug 10 22:30:31 2011 UTC (12 years, 8 months ago) by greg
Diff to previous 2.4 , to selected 2.19
Minor bug fix
Wed Aug 10 22:28:45 2011 UTC (12 years, 8 months ago) by greg
Diff to previous 2.3 , to selected 2.19
Minor bug fixes
Sat Jun 20 21:34:34 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.2: +4 -2 lines
Diff to previous 2.2 , to selected 2.19
Eliminated debug message
Mon Jun 15 22:27:21 2009 UTC (14 years, 10 months ago) by greg
Changes since 2.1: +24 -12 lines
Diff to previous 2.1 , to selected 2.19
Added missing library data files used by gendaylit
Sat Jun 6 20:18:32 2009 UTC (14 years, 10 months ago) by greg
Diff to selected 2.19
