--- ray/src/gen/gendaylit.c 2009/06/15 22:27:21 2.2 +++ ray/src/gen/gendaylit.c 2011/10/05 17:20:55 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gendaylit.c,v 2.2 2009/06/15 22:27:21 greg Exp $"; +static const char RCSid[] = "$Id: gendaylit.c,v 2.7 2011/10/05 17:20:55 greg Exp $"; #endif /* Copyright (c) 1994 *Fraunhofer Institut for Solar Energy Systems * Oltmannstr 5, D-79100 Freiburg, Germany @@ -43,6 +43,7 @@ double normsc(); /* Perez sky parametrization : epsilon and delta calculations from the direct and diffuse irradiances */ double sky_brightness(); double sky_clearness(); +void computesky(); /* calculation of the direct and diffuse components from the Perez parametrization */ double diffus_irradiance_from_sky_brightness(); @@ -161,8 +162,8 @@ char *argv[]; if (argc < 4) userror("arg count"); if (!strcmp(argv[1], "-ang")) { - altitude = atof(argv[2]) * (M_PI/180); - azimuth = atof(argv[3]) * (M_PI/180); + altitude = atof(argv[2]) * (PI/180); + azimuth = atof(argv[3]) * (PI/180); month = 0; } else { month = atoi(argv[1]); @@ -202,13 +203,13 @@ char *argv[]; gprefl = atof(argv[++i]); break; case 'a': - s_latitude = atof(argv[++i]) * (M_PI/180); + s_latitude = atof(argv[++i]) * (PI/180); break; case 'o': - s_longitude = atof(argv[++i]) * (M_PI/180); + s_longitude = atof(argv[++i]) * (PI/180); break; case 'm': - s_meridian = atof(argv[++i]) * (M_PI/180); + s_meridian = atof(argv[++i]) * (PI/180); break; @@ -250,10 +251,10 @@ char *argv[]; else userror("bad option"); - if (fabs(s_meridian-s_longitude) > 30*M_PI/180) + if (fabs(s_meridian-s_longitude) > 30*PI/180) fprintf(stderr, "%s: warning: %.1f hours btwn. standard meridian and longitude\n", - progname, (s_longitude-s_meridian)*12/M_PI); + progname, (s_longitude-s_meridian)*12/PI); /* allocation dynamique de memoire pour les pointeurs */ @@ -273,16 +274,16 @@ char *argv[]; } +void computesky() /* compute sky parameters */ { /* new variables */ - int j, i; + int j; float *lv_mod; /* 145 luminance values*/ /* 145 directions for the calculation of the normalization coefficient, coefficient Perez model */ float *theta_o, *phi_o, *coeff_perez; double dzeta, gamma; - double diffusion; double normfactor; @@ -305,13 +306,13 @@ computesky() /* compute sky parameters */ daynumber = (double)jdate(month, day); } - if (!cloudy && altitude > 87.*M_PI/180.) { + if (!cloudy && altitude > 87.*PI/180.) { fprintf(stderr, "%s: warning - sun too close to zenith, reducing altitude to 87 degrees\n", progname); printf( "# warning - sun too close to zenith, reducing altitude to 87 degrees\n"); - altitude = 87.*M_PI/180.; + altitude = 87.*PI/180.; } sundir[0] = -sin(azimuth)*cos(altitude); sundir[1] = -cos(azimuth)*cos(altitude); @@ -319,7 +320,7 @@ computesky() /* compute sky parameters */ /* calculation for the new functions */ - sunzenith = 90 - altitude*180/M_PI; + sunzenith = 90 - altitude*180/PI; @@ -458,13 +459,13 @@ computesky() /* compute sky parameters */ /* calculation for the solar source */ if (output==0) - solarradiance = directilluminance/(2*M_PI*(1-cos(half_sun_angle*M_PI/180)))/WHTEFFICACY; + solarradiance = directilluminance/(2*PI*(1-cos(half_sun_angle*PI/180)))/WHTEFFICACY; else if (output==1) - solarradiance = directirradiance/(2*M_PI*(1-cos(half_sun_angle*M_PI/180))); + solarradiance = directirradiance/(2*PI*(1-cos(half_sun_angle*PI/180))); else - solarradiance = directilluminance/(2*M_PI*(1-cos(half_sun_angle*M_PI/180))); + solarradiance = directilluminance/(2*PI*(1-cos(half_sun_angle*PI/180))); @@ -472,29 +473,31 @@ computesky() /* compute sky parameters */ /* Compute the ground radiance */ zenithbr=calc_rel_lum_perez(0.0,radians(sunzenith),radians(sunzenith),skyclearness,skybrightness,coeff_perez); zenithbr*=diffnormalization; +/* fprintf(stderr, "gendaylit : the actual zenith radiance(W/m^2/sr) or luminance(cd/m^2) is : %.0lf\n", zenithbr); - +*/ + if (skyclearness==1) normfactor = 0.777778; if (skyclearness>=6) { - F2 = 0.274*(0.91 + 10.0*exp(-3.0*(M_PI/2.0-altitude)) + 0.45*sundir[2]*sundir[2]); - normfactor = normsc()/F2/M_PI; + F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + 0.45*sundir[2]*sundir[2]); + normfactor = normsc()/F2/PI; } if ( (skyclearness>1) && (skyclearness<6) ) { S_INTER=1; - F2 = (2.739 + .9891*sin(.3119+2.6*altitude)) * exp(-(M_PI/2.0-altitude)*(.4441+1.48*altitude)); - normfactor = normsc()/F2/M_PI; + F2 = (2.739 + .9891*sin(.3119+2.6*altitude)) * exp(-(PI/2.0-altitude)*(.4441+1.48*altitude)); + normfactor = normsc()/F2/PI; } groundbr = zenithbr*normfactor; printf("# Ground ambient level: %.1f\n", groundbr); if (dosun&&(skyclearness>1)) -groundbr += 6.8e-5/M_PI*solarradiance*sundir[2]; +groundbr += 6.8e-5/PI*solarradiance*sundir[2]; groundbr *= gprefl; @@ -548,9 +551,9 @@ printdefaults() /* print default values */ printf("-b %f\t\t\t# Zenith radiance (watts/ster/m^2\n", zenithbr); else printf("-t %f\t\t\t# Atmospheric betaturbidity\n", betaturbidity); - printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/M_PI)); - printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/M_PI)); - printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/M_PI)); + printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI)); + printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI)); + printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI)); } @@ -585,7 +588,7 @@ normsc() /* compute normalization factor (E0*F2/L0) register int i; /* polynomial approximation */ nf = nfc[S_INTER]; - x = (altitude - M_PI/4.0)/(M_PI/4.0); + x = (altitude - PI/4.0)/(PI/4.0); nsc = nf[i=4]; while (i--) nsc = nsc*x + nf[i]; @@ -704,7 +707,7 @@ fprintf(stderr, "Warning : skyclearness or skybrightne } value = a[category_number] + b[category_number]*atm_preci_water + - c[category_number]*cos(sunzenith*M_PI/180) + d[category_number]*log(skybrightness); + c[category_number]*cos(sunzenith*PI/180) + d[category_number]*log(skybrightness); return(value); } @@ -782,7 +785,7 @@ fprintf(stderr, "Warning : skyclearness or skybrightne category_number = i; } - value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*cos(sunzenith*M_PI/180) + + value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*cos(sunzenith*PI/180) + d[category_number]*log(skybrightness); return(value); @@ -863,7 +866,7 @@ if ( (skyclearness >= category_bounds[i]) && (skyclear category_number = i; } -value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*exp(5.73*sunzenith*M_PI/180 - 5) + d[category_number]*skybrightness; +value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*exp(5.73*sunzenith*PI/180 - 5) + d[category_number]*skybrightness; if (value < 0) value = 0; @@ -923,7 +926,7 @@ double sky_clearness() { double value; -value = ( (diffusirradiance + directirradiance)/(diffusirradiance) + 1.041*sunzenith*M_PI/180*sunzenith*M_PI/180*sunzenith*M_PI/180 ) / (1 + 1.041*sunzenith*M_PI/180*sunzenith*M_PI/180*sunzenith*M_PI/180) ; +value = ( (diffusirradiance + directirradiance)/(diffusirradiance) + 1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180 ) / (1 + 1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180) ; return(value); } @@ -947,7 +950,7 @@ double direct_irradiance_from_sky_clearness() double value; value = diffus_irradiance_from_sky_brightness(); - value = value * ( (skyclearness-1) * (1+1.041*sunzenith*M_PI/180*sunzenith*M_PI/180*sunzenith*M_PI/180) ); + value = value * ( (skyclearness-1) * (1+1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180) ); return(value); } @@ -1145,13 +1148,13 @@ void coeff_lum_perez(double Z, double epsilon, double /* degrees into radians */ double radians(double degres) { - return degres*M_PI/180.0; + return degres*PI/180.0; } /* radian into degrees */ double degres(double radians) { - return radians/M_PI*180.0; + return radians/PI*180.0; } /* calculation of the angles dzeta and gamma */ @@ -1285,7 +1288,7 @@ double integ_lv(float *lv,float *theta) for (i=0;i<145;i++) buffer += (*(lv+i))*cos(radians(*(theta+i))); - return buffer*2*M_PI/144; + return buffer*2*PI/144; } @@ -1301,7 +1304,7 @@ double get_eccentricity() double day_angle; double E0; - day_angle = 2*M_PI*(daynumber - 1)/365; + day_angle = 2*PI*(daynumber - 1)/365; E0 = 1.00011+0.034221*cos(day_angle)+0.00128*sin(day_angle)+ 0.000719*cos(2*day_angle)+0.000077*sin(2*day_angle); @@ -1321,7 +1324,7 @@ if (sunzenith>90) exit(1); } -m = 1/( cos(sunzenith*M_PI/180)+0.15*exp( log(93.885-sunzenith)*(-1.253) ) ); +m = 1/( cos(sunzenith*PI/180)+0.15*exp( log(93.885-sunzenith)*(-1.253) ) ); return(m); } @@ -1336,8 +1339,8 @@ double angle; if (sun_zenith == 0) puts("WARNING: zenith_angle = 0 in function get_angle_sun_vert_plan"); -angle = acos( cos(sun_zenith*M_PI/180)*cos(direction_zenith*M_PI/180) + sin(sun_zenith*M_PI/180)*sin(direction_zenith*M_PI/180)*cos((sun_azimut-direction_azimut)*M_PI/180) ); -angle = angle*180/M_PI; +angle = acos( cos(sun_zenith*PI/180)*cos(direction_zenith*PI/180) + sin(sun_zenith*PI/180)*sin(direction_zenith*PI/180)*cos((sun_azimut-direction_azimut)*PI/180) ); +angle = angle*180/PI; return(angle); }
