--- ray/src/gen/gendaylit.c 2013/09/06 16:54:06 2.14 +++ ray/src/gen/gendaylit.c 2018/08/31 16:01:45 2.17 @@ -4,8 +4,10 @@ * Centre de Valbonne, 500 route des Lucioles, 06565 Sophia Antipolis Cedex, France * *BOUYGUES * 1 Avenue Eugene Freyssinet, Saint-Quentin-Yvelines, France +* print colored output if activated in command line (-C). Based on model from A. Diakite, TU-Berlin. Implemented by J. Wienold, August 26 2018 */ +#define _USE_MATH_DEFINES #include #include #include @@ -16,11 +18,10 @@ #include "paths.h" #define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2]) -#define _USE_MATH_DEFINES double normsc(); -/*static char *rcsid="$Header: /usr/local/cvs/radiance/ray/src/gen/gendaylit.c,v 2.14 2013/09/06 16:54:06 greg Exp $";*/ +/*static char *rcsid="$Header: /usr/local/cvs/radiance/ray/src/gen/gendaylit.c,v 2.17 2018/08/31 16:01:45 greg Exp $";*/ float coeff_perez[] = { 1.3525,-0.2576,-0.2690,-1.4366,-0.7670,0.0007,1.2734,-0.1233,2.8000,0.6004,1.2375,1.000,1.8734,0.6297, @@ -53,6 +54,9 @@ float defangle_phi[] = { 90, 105, 120, 135, 150, 165, 180, 195, 210, 225, 240, 255, 270, 285, 300, 315, 330, 345, 0, 20, 40, 60, 80, 100, 120, 140, 160, 180, 200, 220, 240, 260, 280, 300, 320, 340, 0, 30, 60, 90, 120, 150, 180, 210, 240, 270, 300, 330, 0, 60, 120, 180, 240, 300, 0}; +/* default values for Berlin */ +float locus[] = { +-4.843e9,2.5568e6,0.24282e3,0.23258,-4.843e9,2.5568e6,0.24282e3,0.23258,-1.2848,1.7519,-0.093786}; @@ -103,12 +107,6 @@ double solar_sunrise(int month, int day); double stadj(); int jdate(int month, int day); - -/* sun calculation constants */ -extern double s_latitude; -extern double s_longitude; -extern double s_meridian; - const double AU = 149597890E3; const double solar_constant_e = 1367; /* solar constant W/m^2 */ const double solar_constant_l = 127500; /* solar constant lux */ @@ -146,7 +144,7 @@ double *c_perez; int output=0; /* define the unit of the output (sky luminance or radiance): */ /* visible watt=0, solar watt=1, lumen=2 */ int input=0; /* define the input for the calulation */ - +int color_output=0; int suppress_warnings=0; /* default values */ @@ -157,6 +155,7 @@ double betaturbidity = 0.1; double gprefl = 0.2; int S_INTER=0; + /* computed values */ double sundir[3]; double groundbr = 0; @@ -213,6 +212,36 @@ int main(int argc, char** argv) cloudy = argv[i][0] == '+' ? 2 : 1; dosun = 0; break; + case 'C': + if (argv[i][2] == 'I' && argv[i][3] == 'E' ) { + locus[0] = -4.607e9; + locus[1] = 2.9678e6; + locus[2] = 0.09911e3; + locus[3] = 0.244063; + locus[4] = -2.0064e9; + locus[5] = 1.9018e6; + locus[6] = 0.24748e3; + locus[7] = 0.23704; + locus[8] = -3.0; + locus[9] = 2.87; + locus[10] = -0.275; + }else{ color_output = 1; + } + break; + case 'l': + locus[0] = atof(argv[++i]); + locus[1] = atof(argv[++i]); + locus[2] = atof(argv[++i]); + locus[3] = atof(argv[++i]); + locus[4] = locus[0]; + locus[5] = locus[1]; + locus[6] = locus[2]; + locus[7] = locus[3]; + locus[8] = atof(argv[++i]); + locus[9] = atof(argv[++i]); + locus[10] = atof(argv[++i]); + break; + case 't': betaturbidity = atof(argv[++i]); break; @@ -682,14 +711,31 @@ void printsky() printf("0\n0\n"); printf("4 %f %f %f %f\n", sundir[0], sundir[1], sundir[2], 2*half_sun_angle); } - - - printf("\nvoid brightfunc skyfunc\n"); - printf("2 skybright perezlum.cal\n"); +/* print colored output if activated in command line (-C). Based on model from A. Diakite, TU-Berlin. Implemented by J. Wienold, August 26 2018 */ + if (color_output==1 && skyclearness < 4.5 && skyclearness >1.065 ) + { + fprintf(stderr, " warning: sky clearness(epsilon)= %f \n",skyclearness); + fprintf(stderr, " warning: intermediate sky!! \n"); + fprintf(stderr, " warning: color model for intermediate sky pending \n"); + fprintf(stderr, " warning: no color output ! \n"); + color_output=0; + } + if (color_output==1) + { + printf("\nvoid colorfunc skyfunc\n"); + printf("4 skybright_r skybright_g skybright_b perezlum_c.cal\n"); printf("0\n"); - printf("10 %.3e %.3e %lf %lf %lf %lf %lf %f %f %f \n", diffnormalization, groundbr, + printf("22 %.3e %.3e %lf %lf %lf %lf %lf %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f\n", diffnormalization, groundbr, *(c_perez+0),*(c_perez+1),*(c_perez+2),*(c_perez+3),*(c_perez+4), - sundir[0], sundir[1], sundir[2]); + sundir[0], sundir[1], sundir[2],skyclearness,locus[0],locus[1],locus[2],locus[3],locus[4],locus[5],locus[6],locus[7],locus[8],locus[9],locus[10]); + }else{ + printf("\nvoid brightfunc skyfunc\n"); + printf("2 skybright perezlum.cal\n"); + printf("0\n"); + printf("10 %.3e %.3e %lf %lf %lf %lf %lf %f %f %f \n", diffnormalization, groundbr, + *(c_perez+0),*(c_perez+1),*(c_perez+2),*(c_perez+3),*(c_perez+4), + sundir[0], sundir[1], sundir[2]); + } } @@ -748,7 +794,7 @@ void usage_error(char* msg) /* print usage error and fprintf(stderr, " -E global-horizontal-irradiance (W/m^2)\n\n"); fprintf(stderr, " Output specification with option:\n"); fprintf(stderr, " -O [0|1|2] (0=output in W/m^2/sr visible, 1=output in W/m^2/sr solar, 2=output in candela/m^2), default is 0 \n"); - fprintf(stderr, " gendaylit version 2.4 (2013/09/04) \n\n"); + fprintf(stderr, " gendaylit version 2.5 (2018/04/18) \n\n"); exit(1); }
