--- ray/src/gen/gendaylit.c 2011/10/05 17:33:36 2.8 +++ ray/src/gen/gendaylit.c 2013/08/14 17:11:43 2.13 @@ -1,99 +1,114 @@ -#ifndef lint -static const char RCSid[] = "$Id: gendaylit.c,v 2.8 2011/10/05 17:33:36 greg Exp $"; -#endif -/* Copyright (c) 1994 *Fraunhofer Institut for Solar Energy Systems - * Oltmannstr 5, D-79100 Freiburg, Germany +/* Copyright (c) 1994,2006 *Fraunhofer Institut for Solar Energy Systems + * Heidenhofstr. 2, D-79110 Freiburg, Germany * *Agence de l'Environnement et de la Maitrise de l'Energie * Centre de Valbonne, 500 route des Lucioles, 06565 Sophia Antipolis Cedex, France * *BOUYGUES * 1 Avenue Eugene Freyssinet, Saint-Quentin-Yvelines, France */ - - -/* - * gendaylit.c program to generate the angular distribution of the daylight. - * Our zenith is along the Z-axis, the X-axis - * points east, and the Y-axis points north. -*/ - +#define _USE_MATH_DEFINES #include #include #include #include -#include -#include "rtmath.h" -#include "rtio.h" #include "color.h" +#include "sun.h" #include "paths.h" -extern int jdate(int month, int day); -extern double stadj(int jd); -extern double sdec(int jd); -extern double salt(double sd, double st); -extern double sazi(double sd, double st); +#define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2]) double normsc(); -#define DATFILE "coeff_perez.dat" +/*static char *rcsid="$Header: /usr/local/cvs/radiance/ray/src/gen/gendaylit.c,v 2.13 2013/08/14 17:11:43 greg Exp $";*/ +float coeff_perez[] = { + 1.3525,-0.2576,-0.2690,-1.4366,-0.7670,0.0007,1.2734,-0.1233,2.8000,0.6004,1.2375,1.000,1.8734,0.6297, + 0.9738,0.2809,0.0356,-0.1246,-0.5718,0.9938,-1.2219,-0.7730,1.4148,1.1016,-0.2054,0.0367,-3.9128,0.9156, + 6.9750,0.1774,6.4477,-0.1239,-1.5798,-0.5081,-1.7812,0.1080,0.2624,0.0672,-0.2190,-0.4285,-1.1000,-0.2515, + 0.8952,0.0156,0.2782,-0.1812,-4.5000,1.1766,24.7219,-13.0812,-37.7000,34.8438,-5.0000,1.5218,3.9229, + -2.6204,-0.0156,0.1597,0.4199,-0.5562,-0.5484,-0.6654,-0.2672,0.7117,0.7234,-0.6219,-5.6812,2.6297, + 33.3389,-18.3000,-62.2500,52.0781,-3.5000,0.0016,1.1477,0.1062,0.4659,-0.3296,-0.0876,-0.0329,-0.6000, + -0.3566,-2.5000,2.3250,0.2937,0.0496,-5.6812,1.8415,21.0000,-4.7656,-21.5906,7.2492,-3.5000,-0.1554, + 1.4062,0.3988,0.0032,0.0766,-0.0656,-0.1294,-1.0156,-0.3670,1.0078,1.4051,0.2875,-0.5328,-3.8500,3.3750, + 14.0000,-0.9999,-7.1406,7.5469,-3.4000,-0.1078,-1.0750,1.5702,-0.0672,0.4016,0.3017,-0.4844,-1.0000, + 0.0211,0.5025,-0.5119,-0.3000,0.1922,0.7023,-1.6317,19.0000,-5.0000,1.2438,-1.9094,-4.0000,0.0250,0.3844, + 0.2656,1.0468,-0.3788,-2.4517,1.4656,-1.0500,0.0289,0.4260,0.3590,-0.3250,0.1156,0.7781,0.0025,31.0625, + -14.5000,-46.1148,55.3750,-7.2312,0.4050,13.3500,0.6234,1.5000,-0.6426,1.8564,0.5636}; +float defangle_theta[] = { + 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, 84, + 84, 84, 84, 84, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, 72, + 72, 72, 72, 72, 72, 72, 72, 72, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, 60, + 60, 60, 60, 60, 60, 60, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, 48, + 48, 48, 48, 48, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 36, 24, 24, 24, 24, + 24, 24, 24, 24, 24, 24, 24, 24, 12, 12, 12, 12, 12, 12, 0}; + +float defangle_phi[] = { + 0, 12, 24, 36, 48, 60, 72, 84, 96, 108, 120, 132, 144, 156, 168, 180, 192, 204, 216, 228, 240, 252, 264, + 276, 288, 300, 312, 324, 336, 348, 0, 12, 24, 36, 48, 60, 72, 84, 96, 108, 120, 132, 144, 156, 168, 180, + 192, 204, 216, 228, 240, 252, 264, 276, 288, 300, 312, 324, 336, 348, 0, 15, 30, 45, 60, 75, 90, 105, + 120, 135, 150, 165, 180, 195, 210, 225, 240, 255, 270, 285, 300, 315, 330, 345, 0, 15, 30, 45, 60, 75, + 90, 105, 120, 135, 150, 165, 180, 195, 210, 225, 240, 255, 270, 285, 300, 315, 330, 345, 0, 20, 40, 60, + 80, 100, 120, 140, 160, 180, 200, 220, 240, 260, 280, 300, 320, 340, 0, 30, 60, 90, 120, 150, 180, 210, + 240, 270, 300, 330, 0, 60, 120, 180, 240, 300, 0}; + + + /* Perez sky parametrization : epsilon and delta calculations from the direct and diffuse irradiances */ double sky_brightness(); double sky_clearness(); -void computesky(); /* calculation of the direct and diffuse components from the Perez parametrization */ -double diffus_irradiance_from_sky_brightness(); +double diffuse_irradiance_from_sky_brightness(); double direct_irradiance_from_sky_clearness(); +/* Perez global horizontal, diffuse horizontal and direct normal luminous efficacy models : */ +/* input w(cm)=2cm, solar zenith angle(degrees); output efficacy(lm/W) */ -/* Perez global horizontal, diffuse horizontal and direct normal luminous efficacy models : input w(cm)=2cm, solar zenith angle(degrees); output efficacy(lm/W) */ double glob_h_effi_PEREZ(); double glob_h_diffuse_effi_PEREZ(); double direct_n_effi_PEREZ(); + /*likelihood check of the epsilon, delta, direct and diffuse components*/ void check_parametrization(); void check_irradiances(); void check_illuminances(); void illu_to_irra_index(); +void print_error_sky(); - -/* Perez sky luminance model */ -int lect_coeff_perez(char *filename,float **coeff_perez); -double calc_rel_lum_perez(double dzeta,double gamma,double Z, - double epsilon,double Delta,float *coeff_perez); -/* coefficients for the sky luminance perez model */ -void coeff_lum_perez(double Z, double epsilon, double Delta, float *coeff_perez); +double calc_rel_lum_perez(double dzeta,double gamma,double Z,double epsilon,double Delta,float coeff_perez[]); +void coeff_lum_perez(double Z, double epsilon, double Delta, float coeff_perez[]); double radians(double degres); double degres(double radians); void theta_phi_to_dzeta_gamma(double theta,double phi,double *dzeta,double *gamma, double Z); double integ_lv(float *lv,float *theta); -float *theta_ordered(char *filename); -float *phi_ordered(char *filename); -void skip_comments(FILE *fp); +void printdefaults(); +void check_sun_position(); +void computesky(); +void printhead(int ac, char** av); +void userror(char* msg); +void printsky(); +FILE * frlibopen(char* fname); /* astronomy and geometry*/ double get_eccentricity(); double air_mass(); -double get_angle_sun_direction(double sun_zenith, double sun_azimut, double direction_zenith, double direction_azimut); - -/* date*/ +double solar_sunset(); +double solar_sunrise(); +double stadj(); int jdate(int month, int day); - - /* sun calculation constants */ -extern double s_latitude; -extern double s_longitude; -extern double s_meridian; +extern double s_latitude; +extern double s_longitude; +extern double s_meridian; const double AU = 149597890E3; const double solar_constant_e = 1367; /* solar constant W/m^2 */ @@ -102,7 +117,7 @@ const double solar_constant_l = 127.5; /* solar co const double half_sun_angle = 0.2665; const double half_direct_angle = 2.85; -const double skyclearinf = 1.000; /* limitations for the variation of the Perez parameters */ +const double skyclearinf = 1.0; /* limitations for the variation of the Perez parameters */ const double skyclearsup = 12.1; const double skybriginf = 0.01; const double skybrigsup = 0.6; @@ -118,20 +133,26 @@ double altitude, azimuth; /* or solar angles */ /* definition of the sky conditions through the Perez parametrization */ -double skyclearness, skybrightness; -double solarradiance; /*radiance of the sun disk and of the circumsolar area*/ -double diffusilluminance, directilluminance, diffusirradiance, directirradiance; -double sunzenith, daynumber=150, atm_preci_water=2; +double skyclearness = 0; +double skybrightness = 0; +double solarradiance; +double diffuseilluminance, directilluminance, diffuseirradiance, directirradiance, globalirradiance; +double sunzenith, daynumber, atm_preci_water=2; -double diffnormalization, dirnormalization; +/*double sunaltitude_border = 0;*/ +double diffnormalization = 0; +double dirnormalization = 0; double *c_perez; -int output=0; /*define the unit of the output (sky luminance or radiance): visible watt=0, solar watt=1, lumen=2*/ -int input=0; /*define the input for the calulation*/ +int output=0; /* define the unit of the output (sky luminance or radiance): */ + /* visible watt=0, solar watt=1, lumen=2 */ +int input=0; /* define the input for the calulation */ +int suppress_warnings=0; + /* default values */ -int cloudy = 0; /* 1=standard, 2=uniform */ -int dosun = 1; +int cloudy = 0; /* 1=standard, 2=uniform */ +int dosun = 1; double zenithbr = -1.0; double betaturbidity = 0.1; double gprefl = 0.2; @@ -139,31 +160,32 @@ int S_INTER=0; /* computed values */ double sundir[3]; -double groundbr; +double groundbr = 0; double F2; double solarbr = 0.0; int u_solar = 0; /* -1=irradiance, 1=radiance */ +float timeinterval = 0; -char *progname; -char errmsg[128]; +char *progname; +char errmsg[128]; -main(argc, argv) -int argc; -char *argv[]; + + +int main(int argc, char** argv) { int i; progname = argv[0]; if (argc == 2 && !strcmp(argv[1], "-defaults")) { printdefaults(); - exit(0); + return 0; } if (argc < 4) userror("arg count"); if (!strcmp(argv[1], "-ang")) { - altitude = atof(argv[2]) * (PI/180); - azimuth = atof(argv[3]) * (PI/180); + altitude = atof(argv[2]) * (M_PI/180); + azimuth = atof(argv[3]) * (M_PI/180); month = 0; } else { month = atoi(argv[1]); @@ -184,7 +206,6 @@ char *argv[]; cloudy = 0; dosun = argv[i][0] == '+'; break; - case 'r': case 'R': u_solar = argv[i][1] == 'R' ? -1 : 1; solarbr = atof(argv[++i]); @@ -196,6 +217,9 @@ char *argv[]; case 't': betaturbidity = atof(argv[++i]); break; + case 'w': + suppress_warnings = 1; + break; case 'b': zenithbr = atof(argv[++i]); break; @@ -203,20 +227,18 @@ char *argv[]; gprefl = atof(argv[++i]); break; case 'a': - s_latitude = atof(argv[++i]) * (PI/180); + s_latitude = atof(argv[++i]) * (M_PI/180); break; case 'o': - s_longitude = atof(argv[++i]) * (PI/180); + s_longitude = atof(argv[++i]) * (M_PI/180); break; case 'm': - s_meridian = atof(argv[++i]) * (PI/180); + s_meridian = atof(argv[++i]) * (M_PI/180); break; - case 'O': output = atof(argv[++i]); /*define the unit of the output of the program : - sky and sun luminance/radiance (0==W visible, 1==W solar radiation, 2==lm) - default is set to 0*/ + sky and sun luminance/radiance (0==W visible, 1==W solar radiation, 2==lm) */ break; case 'P': @@ -228,22 +250,37 @@ char *argv[]; case 'W': /* direct normal Irradiance [W/m^2] */ input = 1; /* diffuse horizontal Irrad. [W/m^2] */ directirradiance = atof(argv[++i]); - diffusirradiance = atof(argv[++i]); + diffuseirradiance = atof(argv[++i]); break; case 'L': /* direct normal Illuminance [Lux] */ input = 2; /* diffuse horizontal Ill. [Lux] */ directilluminance = atof(argv[++i]); - diffusilluminance = atof(argv[++i]); + diffuseilluminance = atof(argv[++i]); break; case 'G': /* direct horizontal Irradiance [W/m^2] */ input = 3; /* diffuse horizontal Irrad. [W/m^2] */ directirradiance = atof(argv[++i]); - diffusirradiance = atof(argv[++i]); + diffuseirradiance = atof(argv[++i]); break; + + case 'E': /* Erbs model based on the */ + input = 4; /* global-horizontal irradiance [W/m^2] */ + globalirradiance = atof(argv[++i]); + break; + + /* + case 'l': + sunaltitude_border = atof(argv[++i]); + break; + */ + case 'i': + timeinterval = atof(argv[++i]); + break; + default: sprintf(errmsg, "unknown option: %s", argv[i]); userror(errmsg); @@ -251,45 +288,55 @@ char *argv[]; else userror("bad option"); - if (fabs(s_meridian-s_longitude) > 30*PI/180) + if (fabs(s_meridian-s_longitude) > 30*M_PI/180) fprintf(stderr, "%s: warning: %.1f hours btwn. standard meridian and longitude\n", - progname, (s_longitude-s_meridian)*12/PI); + progname, (s_longitude-s_meridian)*12/M_PI); - /* allocation dynamique de memoire pour les pointeurs */ - if ( (c_perez = malloc(5*sizeof(double))) == NULL ) + /* dynamic memory allocation for the pointers */ + + if ( (c_perez = calloc(5, sizeof(double))) == NULL ) { - fprintf(stderr,"Out of memory error in function main !"); - exit(1); + fprintf(stderr,"Out of memory error in function main"); + return 1; } - printhead(argc, argv); - computesky(); + + if(*(c_perez+1)>0) + { + fprintf(stderr, "Warning: positive Perez parameter B (= %lf), printing error sky\n",*(c_perez+1)); + print_error_sky(); + exit(1); + } + printsky(); - - exit(0); + return 0; } -void -computesky() /* compute sky parameters */ + + + + + + +void computesky() { - /* new variables */ int j; - float *lv_mod; /* 145 luminance values*/ - /* 145 directions for the calculation of the normalization coefficient, coefficient Perez model */ - float *theta_o, *phi_o, *coeff_perez; + + float *lv_mod; /* 145 luminance values */ + float *theta_o, *phi_o; double dzeta, gamma; double normfactor; + double erbs_s0, erbs_kt; - /* compute solar direction */ - + if (month) { /* from date and time */ int jd; double sd, st; @@ -300,48 +347,95 @@ computesky() /* compute sky parameters */ st = hour; else st = hour + stadj(jd); + + + if(stsolar_sunset(month,day)) { + print_error_sky(); + exit(1); + } + + + if(timeinterval) { + + if(timeinterval<0) { + fprintf(stderr, "time interval negative\n"); + exit(1); + } + + if(fabs(solar_sunrise(month,day)-st) 87.*PI/180.) { - fprintf(stderr, + */ + + + if (!cloudy && altitude > 87.*M_PI/180.) { + + if (suppress_warnings==0) { + fprintf(stderr, "%s: warning - sun too close to zenith, reducing altitude to 87 degrees\n", progname); - printf( - "# warning - sun too close to zenith, reducing altitude to 87 degrees\n"); - altitude = 87.*PI/180.; + } + altitude = 87.*M_PI/180.; } + sundir[0] = -sin(azimuth)*cos(altitude); sundir[1] = -cos(azimuth)*cos(altitude); sundir[2] = sin(altitude); /* calculation for the new functions */ - sunzenith = 90 - altitude*180/PI; + sunzenith = 90 - altitude*180/M_PI; -/* compute the inputs for the calculation of the light distribution over the sky*/ - if (input==0) + /* compute the inputs for the calculation of the light distribution over the sky*/ + if (input==0) /* P */ { check_parametrization(); - diffusirradiance = diffus_irradiance_from_sky_brightness(); /*diffuse horizontal irradiance*/ + diffuseirradiance = diffuse_irradiance_from_sky_brightness(); /*diffuse horizontal irradiance*/ directirradiance = direct_irradiance_from_sky_clearness(); check_irradiances(); if (output==0 || output==2) { - diffusilluminance = diffusirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/ + diffuseilluminance = diffuseirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/ directilluminance = directirradiance*direct_n_effi_PEREZ(); check_illuminances(); } } - else if (input==1) + else if (input==1) /* W */ { check_irradiances(); skybrightness = sky_brightness(); @@ -350,7 +444,7 @@ computesky() /* compute sky parameters */ if (output==0 || output==2) { - diffusilluminance = diffusirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/ + diffuseilluminance = diffuseirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/ directilluminance = directirradiance*direct_n_effi_PEREZ(); check_illuminances(); } @@ -358,7 +452,7 @@ computesky() /* compute sky parameters */ } - else if (input==2) + else if (input==2) /* L */ { check_illuminances(); illu_to_irra_index(); @@ -366,15 +460,19 @@ computesky() /* compute sky parameters */ } - else if (input==3) + else if (input==3) /* G */ { if (altitude<=0) { - fprintf(stderr, "solar zenith angle larger than 90³ \n the models used are not more valid\n"); - exit(1); + if (suppress_warnings==0) + fprintf(stderr, "Warning: solar zenith angle larger than 90 degrees; using zero irradiance to proceed\n"); + directirradiance = 0; + diffuseirradiance = 0; + } else { + + directirradiance=directirradiance/sin(altitude); } - - directirradiance=directirradiance/sin(altitude); + check_irradiances(); skybrightness = sky_brightness(); skyclearness = sky_clearness(); @@ -382,34 +480,73 @@ computesky() /* compute sky parameters */ if (output==0 || output==2) { - diffusilluminance = diffusirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/ + diffuseilluminance = diffuseirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/ directilluminance = directirradiance*direct_n_effi_PEREZ(); check_illuminances(); } } - - else {fprintf(stderr,"error in giving the input arguments"); exit(1);} + else if (input==4) /* E */ /* Implementation of the Erbs model. W.Sprenger (04/13) */ + { + + if (altitude<=0) + { + if (suppress_warnings==0 && globalirradiance > 50) + fprintf(stderr, "Warning: global irradiance higher than 50 W/m^2 while the sun altitude is lower than zero\n"); + globalirradiance = 0; diffuseirradiance = 0; directirradiance = 0; + + } else { + + erbs_s0 = solar_constant_e*get_eccentricity()*sin(altitude); + + if (globalirradiance>erbs_s0) + { + if (suppress_warnings==0) + fprintf(stderr, "Warning: global irradiance is higher than the time-dependent solar constant s0\n"); + + globalirradiance=erbs_s0*0.999; + } + + erbs_kt=globalirradiance/erbs_s0; + + if (erbs_kt<=0.22) diffuseirradiance=globalirradiance*(1-0.09*erbs_kt); + else if (erbs_kt<=0.8) diffuseirradiance=globalirradiance*(0.9511-0.1604*erbs_kt+4.388*pow(erbs_kt,2)-16.638*pow(erbs_kt,3)+12.336*pow(erbs_kt,4)); + else if (erbs_kt<1) diffuseirradiance=globalirradiance*(0.165); + + directirradiance=globalirradiance-diffuseirradiance; + + printf("# erbs_s0, erbs_kt, irr_dir_h, irr_diff: %.3f %.3f %.3f %.3f\n", erbs_s0, erbs_kt, directirradiance, diffuseirradiance); + printf("# WARNING: the -E option is only recommended for a rough estimation!"); + + directirradiance=directirradiance/sin(altitude); + + } + + check_irradiances(); + skybrightness = sky_brightness(); + skyclearness = sky_clearness(); + check_parametrization(); + if (output==0 || output==2) + { + diffuseilluminance = diffuseirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/ + directilluminance = directirradiance*direct_n_effi_PEREZ(); + check_illuminances(); + } + + } + + + -/* normalization factor for the relative sky luminance distribution, diffuse part*/ + else {fprintf(stderr,"error at the input arguments"); exit(1);} - /* allocation dynamique de memoire pour les pointeurs */ - if ( (coeff_perez = malloc(8*20*sizeof(float))) == NULL ) - { - fprintf(stderr,"Out of memory error in function main !"); - exit(1); - } -/* read the coefficients for the Perez sky luminance model */ - if (lect_coeff_perez(DATFILE, &coeff_perez) > 0) - { - fprintf(stderr,"lect_coeff_perez does not work\n"); - exit(2); - } - + + /* normalization factor for the relative sky luminance distribution, diffuse part*/ + if ( (lv_mod = malloc(145*sizeof(float))) == NULL) { fprintf(stderr,"Out of memory in function main"); @@ -417,55 +554,61 @@ computesky() /* compute sky parameters */ } /* read the angles */ - theta_o = theta_ordered("defangle.dat"); - phi_o = phi_ordered("defangle.dat"); + theta_o = defangle_theta; + phi_o = defangle_phi; + -/* parameters for the perez model */ + /* parameters for the perez model */ coeff_lum_perez(radians(sunzenith), skyclearness, skybrightness, coeff_perez); -/*calculation of the modelled luminance */ + + + + + /*calculation of the modelled luminance */ for (j=0;j<145;j++) { theta_phi_to_dzeta_gamma(radians(*(theta_o+j)),radians(*(phi_o+j)),&dzeta,&gamma,radians(sunzenith)); + *(lv_mod+j) = calc_rel_lum_perez(dzeta,gamma,radians(sunzenith),skyclearness,skybrightness,coeff_perez); - /*printf("theta, phi, lv_mod %lf\t %lf\t %lf\n", *(theta_o+j),*(phi_o+j),*(lv_mod+j));*/ + + /* fprintf(stderr,"theta, phi, lv_mod %f\t %f\t %f\n", *(theta_o+j),*(phi_o+j),*(lv_mod+j)); */ } - + /* integration of luminance for the normalization factor, diffuse part of the sky*/ + diffnormalization = integ_lv(lv_mod, theta_o); - /*printf("perez integration %lf\n", diffnormalization);*/ - -/*normalization coefficient in lumen or in watt*/ + /*normalization coefficient in lumen or in watt*/ if (output==0) { - diffnormalization = diffusilluminance/diffnormalization/WHTEFFICACY; + diffnormalization = diffuseilluminance/diffnormalization/WHTEFFICACY; } else if (output==1) { - diffnormalization = diffusirradiance/diffnormalization; + diffnormalization = diffuseirradiance/diffnormalization; } else if (output==2) { - diffnormalization = diffusilluminance/diffnormalization; + diffnormalization = diffuseilluminance/diffnormalization; } - else {fprintf(stderr,"output argument : wrong number"); exit(1);} + else {fprintf(stderr,"Wrong output specification.\n"); exit(1);} -/* calculation for the solar source */ + /* calculation for the solar source */ if (output==0) - solarradiance = directilluminance/(2*PI*(1-cos(half_sun_angle*PI/180)))/WHTEFFICACY; + solarradiance = directilluminance/(2*M_PI*(1-cos(half_sun_angle*M_PI/180)))/WHTEFFICACY; else if (output==1) - solarradiance = directirradiance/(2*PI*(1-cos(half_sun_angle*PI/180))); + solarradiance = directirradiance/(2*M_PI*(1-cos(half_sun_angle*M_PI/180))); else - solarradiance = directilluminance/(2*PI*(1-cos(half_sun_angle*PI/180))); + solarradiance = directilluminance/(2*M_PI*(1-cos(half_sun_angle*M_PI/180))); @@ -473,31 +616,27 @@ computesky() /* compute sky parameters */ /* Compute the ground radiance */ zenithbr=calc_rel_lum_perez(0.0,radians(sunzenith),radians(sunzenith),skyclearness,skybrightness,coeff_perez); zenithbr*=diffnormalization; -/* -fprintf(stderr, "gendaylit : the actual zenith radiance(W/m^2/sr) or luminance(cd/m^2) is : %.0lf\n", zenithbr); -*/ - + if (skyclearness==1) normfactor = 0.777778; if (skyclearness>=6) { - F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + 0.45*sundir[2]*sundir[2]); - normfactor = normsc()/F2/PI; + F2 = 0.274*(0.91 + 10.0*exp(-3.0*(M_PI/2.0-altitude)) + 0.45*sundir[2]*sundir[2]); + normfactor = normsc()/F2/M_PI; } if ( (skyclearness>1) && (skyclearness<6) ) { S_INTER=1; - F2 = (2.739 + .9891*sin(.3119+2.6*altitude)) * exp(-(PI/2.0-altitude)*(.4441+1.48*altitude)); - normfactor = normsc()/F2/PI; + F2 = (2.739 + .9891*sin(.3119+2.6*altitude)) * exp(-(M_PI/2.0-altitude)*(.4441+1.48*altitude)); + normfactor = normsc()/F2/M_PI; } groundbr = zenithbr*normfactor; -printf("# Ground ambient level: %.1f\n", groundbr); if (dosun&&(skyclearness>1)) -groundbr += 6.8e-5/PI*solarradiance*sundir[2]; + groundbr += 6.8e-5/M_PI*solarradiance*sundir[2]; groundbr *= gprefl; @@ -509,73 +648,118 @@ return; +void print_error_sky() +{ + sundir[0] = -sin(azimuth)*cos(altitude); + sundir[1] = -cos(azimuth)*cos(altitude); + sundir[2] = sin(altitude); + + printf("\nvoid brightfunc skyfunc\n"); + printf("2 skybright perezlum.cal\n"); + printf("0\n"); + printf("10 0.00 0.00 0.000 0.000 0.000 0.000 0.000 %f %f %f \n", sundir[0], sundir[1], sundir[2]); +} + -printsky() /* print out sky */ + + + +double solar_sunset(int month,int day) { + float W; + extern double s_latitude; + W=-1*(tan(s_latitude)*tan(sdec(jdate(month, day)))); + return(12+(M_PI/2 - atan2(W,sqrt(1-W*W)))*180/(M_PI*15)); +} + + +double solar_sunrise(int month,int day) +{ + float W; + extern double s_latitude; + W=-1*(tan(s_latitude)*tan(sdec(jdate(month, day)))); + return(12-(M_PI/2 - atan2(W,sqrt(1-W*W)))*180/(M_PI*15)); +} + + + + + + + + + + + +void printsky() /* print out sky */ +{ if (dosun&&(skyclearness>1)) - { + { printf("\nvoid light solar\n"); printf("0\n0\n"); printf("3 %.3e %.3e %.3e\n", solarradiance, solarradiance, solarradiance); printf("\nsolar source sun\n"); printf("0\n0\n"); printf("4 %f %f %f %f\n", sundir[0], sundir[1], sundir[2], 2*half_sun_angle); - } - - if (dosun&&(skyclearness==1)) - { + } else if (dosun) { printf("\nvoid light solar\n"); printf("0\n0\n"); printf("3 0.0 0.0 0.0\n"); printf("\nsolar source sun\n"); printf("0\n0\n"); printf("4 %f %f %f %f\n", sundir[0], sundir[1], sundir[2], 2*half_sun_angle); - } + } printf("\nvoid brightfunc skyfunc\n"); printf("2 skybright perezlum.cal\n"); printf("0\n"); printf("10 %.3e %.3e %lf %lf %lf %lf %lf %f %f %f \n", diffnormalization, groundbr, - *(c_perez+0),*(c_perez+1),*(c_perez+2),*(c_perez+3),*(c_perez+4), - sundir[0], sundir[1], sundir[2]); + *(c_perez+0),*(c_perez+1),*(c_perez+2),*(c_perez+3),*(c_perez+4), + sundir[0], sundir[1], sundir[2]); + } -printdefaults() /* print default values */ +void printdefaults() /* print default values */ { printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl); if (zenithbr > 0.0) printf("-b %f\t\t\t# Zenith radiance (watts/ster/m^2\n", zenithbr); else printf("-t %f\t\t\t# Atmospheric betaturbidity\n", betaturbidity); - printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI)); - printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI)); - printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI)); + printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/M_PI)); + printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/M_PI)); + printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/M_PI)); } -userror(msg) /* print usage error and quit */ -char *msg; +void userror(char* msg) /* print usage error and quit */ { if (msg != NULL) - fprintf(stderr, "%s: Use error - %s\n", progname, msg); - fprintf(stderr, "Usage: %s month day hour [-P|-W|-L] direct_value diffus_value [options]\n", progname); - fprintf(stderr, "or : %s -ang altitude azimuth [-P|-W|-L] direct_value diffus_value [options]\n", progname); + fprintf(stderr, "%s: Use error - %s\n\n", progname, msg); + fprintf(stderr, "Usage: %s month day hour [...]\n", progname); + fprintf(stderr, " or: %s -ang altitude azimuth [...]\n", progname); + fprintf(stderr, " followed by: -P epsilon delta [options]\n"); + fprintf(stderr, " or: [-W|-L|-G] direct_value diffuse_value [options]\n"); + fprintf(stderr, " or: -E global_irradiance [options]\n\n"); + fprintf(stderr, " Description:\n"); fprintf(stderr, " -P epsilon delta (these are the Perez parameters) \n"); fprintf(stderr, " -W direct-normal-irradiance diffuse-horizontal-irradiance (W/m^2)\n"); fprintf(stderr, " -L direct-normal-illuminance diffuse-horizontal-illuminance (lux)\n"); fprintf(stderr, " -G direct-horizontal-irradiance diffuse-horizontal-irradiance (W/m^2)\n"); + fprintf(stderr, " -E global-horizontal-irradiance (W/m^2)\n\n"); + fprintf(stderr, " Output specification with option:\n"); fprintf(stderr, " -O [0|1|2] (0=output in W/m^2/sr visible, 1=output in W/m^2/sr solar, 2=output in candela/m^2), default is 0 \n"); + fprintf(stderr, " gendaylit version 2.3 (2013/08/08) \n\n"); exit(1); } -double -normsc() /* compute normalization factor (E0*F2/L0) */ +double normsc() /* compute normalization factor (E0*F2/L0) */ { static double nfc[2][5] = { /* clear sky approx. */ @@ -588,7 +772,7 @@ normsc() /* compute normalization factor (E0*F2/L0) register int i; /* polynomial approximation */ nf = nfc[S_INTER]; - x = (altitude - PI/4.0)/(PI/4.0); + x = (altitude - M_PI/4.0)/(M_PI/4.0); nsc = nf[i=4]; while (i--) nsc = nsc*x + nf[i]; @@ -598,9 +782,7 @@ normsc() /* compute normalization factor (E0*F2/L0) -printhead(ac, av) /* print command header */ -register int ac; -register char **av; +void printhead(int ac, char** av) /* print command header */ { putchar('#'); while (ac--) { @@ -613,24 +795,6 @@ register char **av; -void -skip_comments(FILE *fp) /* skip comments in file */ -{ - int c; - - while ((c = getc(fp)) != EOF) - if (c == '#') { - while ((c = getc(fp)) != EOF) - if (c == '\n') - break; - } else if (!isspace(c)) { - ungetc(c, fp); - break; - } -} - - - /* Perez models */ /* Perez global horizontal luminous efficacy model */ @@ -640,11 +804,14 @@ double glob_h_effi_PEREZ() double value; double category_bounds[10], a[10], b[10], c[10], d[10]; int category_total_number, category_number, i; - - -if (skyclearnessskyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup) -fprintf(stderr, "Warning : skyclearness or skybrightness out of range ; \n Check your input parameters\n"); - + + check_parametrization(); + + +/*if ((skyclearnessskyclearsup || skybrightnessskybrigsup) && suppress_warnings==0) + fprintf(stderr, "Warning: skyclearness or skybrightness out of range in function glob_h_effi_PEREZ \n"); */ + + /* initialize category bounds (clearness index bounds) */ category_total_number = 8; @@ -707,7 +874,7 @@ fprintf(stderr, "Warning : skyclearness or skybrightne } value = a[category_number] + b[category_number]*atm_preci_water + - c[category_number]*cos(sunzenith*PI/180) + d[category_number]*log(skybrightness); + c[category_number]*cos(sunzenith*M_PI/180) + d[category_number]*log(skybrightness); return(value); } @@ -720,14 +887,22 @@ double glob_h_diffuse_effi_PEREZ() double category_bounds[10], a[10], b[10], c[10], d[10]; int category_total_number, category_number, i; + + -if (skyclearnessskyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup) -fprintf(stderr, "Warning : skyclearness or skybrightness out of range ; \n Check your input parameters\n"); + check_parametrization(); + + +/*if ((skyclearnessskyclearsup || skybrightnessskybrigsup) && suppress_warnings==0) + fprintf(stderr, "Warning: skyclearness or skybrightness out of range in function glob_h_diffuse_PEREZ \n"); */ + + /* initialize category bounds (clearness index bounds) */ category_total_number = 8; +//XXX: category_bounds > 0.1 category_bounds[1] = 1; category_bounds[2] = 1.065; category_bounds[3] = 1.230; @@ -779,19 +954,30 @@ fprintf(stderr, "Warning : skyclearness or skybrightne + category_number = -1; for (i=1; i<=category_total_number; i++) { if ( (skyclearness >= category_bounds[i]) && (skyclearness < category_bounds[i+1]) ) category_number = i; } - value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*cos(sunzenith*PI/180) + + if (category_number == -1) { + if (suppress_warnings==0) + fprintf(stderr, "ERROR: Model parameters out of range, skyclearness = %lf \n", skyclearness); + print_error_sky(); + exit(1); + } + + + value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*cos(sunzenith*M_PI/180) + d[category_number]*log(skybrightness); return(value); + } + /* direct normal efficacy model, according to PEREZ */ double direct_n_effi_PEREZ() @@ -802,8 +988,8 @@ double category_bounds[10], a[10], b[10], c[10], d[10 int category_total_number, category_number, i; -if (skyclearnessskyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup) -fprintf(stderr, "Warning : skyclearness or skybrightness out of range ; \n Check your input parameters\n"); +if ((skyclearnessskyclearsup || skybrightnessskybrigsup) && suppress_warnings==0) + fprintf(stderr, "Warning: skyclearness or skybrightness out of range in function direct_n_effi_PEREZ \n"); /* initialize category bounds (clearness index bounds) */ @@ -866,7 +1052,7 @@ if ( (skyclearness >= category_bounds[i]) && (skyclear category_number = i; } -value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*exp(5.73*sunzenith*PI/180 - 5) + d[category_number]*skybrightness; +value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*exp(5.73*sunzenith*M_PI/180 - 5) + d[category_number]*skybrightness; if (value < 0) value = 0; @@ -877,35 +1063,68 @@ return(value); /*check the range of epsilon and delta indexes of the perez parametrization*/ void check_parametrization() { -if (skyclearnessskyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup) +if (skyclearnessskyclearsup || skybrightnessskybrigsup) { - fprintf(stderr,"sky clearness or sky brightness out of range %lf\t %lf\n", skyclearness, skybrightness); - exit(1); + +/* limit sky clearness or sky brightness, 2009 11 13 by J. Wienold */ + if (skyclearnessskyclearsup){ + if (suppress_warnings==0) + /* fprintf(stderr,"Range warning: sky clearness too high (%lf)\n", skyclearness); */ + skyclearness=skyclearsup-0.1; + } + if (skybrightnessskybrigsup){ + if (suppress_warnings==0) + /* fprintf(stderr,"Range warning: sky brightness too high (%lf)\n", skybrightness); */ + skybrightness=skybrigsup; + } + + return; } else return; } -/* likelihood of the direct and diffuse components */ +/* validity of the direct and diffuse components */ void check_illuminances() { - if (!( (directilluminance>=0) && (directilluminance<=solar_constant_l*1000) && (diffusilluminance>0) )) - { - fprintf(stderr,"direct or diffuse illuminances out of range\n"); - exit(1); + if (directilluminance < 0) { + fprintf(stderr,"WARNING: direct illuminance < 0. Using 0.0\n"); + directilluminance = 0.0; } -return; + if (diffuseilluminance < 0) { + fprintf(stderr,"WARNING: diffuse illuminance < 0. Using 0.0\n"); + diffuseilluminance = 0.0; + } + if (directilluminance > solar_constant_l*1000.0) { + fprintf(stderr,"ERROR: direct illuminance exceeds solar constant\n"); + exit(1); + } } void check_irradiances() { - if (!( (directirradiance>=0) && (directirradiance<=solar_constant_e) && (diffusirradiance>0) )) - { - fprintf(stderr,"direct or diffuse irradiances out of range\n"); - exit(1); - } -return; + if (directirradiance < 0) { + fprintf(stderr,"WARNING: direct irradiance < 0. Using 0.0\n"); + directirradiance = 0.0; + } + if (diffuseirradiance < 0) { + fprintf(stderr,"WARNING: diffuse irradiance < 0. Using 0.0\n"); + diffuseirradiance = 0.0; + } + if (directirradiance > solar_constant_e) { + fprintf(stderr,"ERROR: direct irradiance exceeds solar constant\n"); + exit(1); + } } @@ -915,7 +1134,7 @@ double sky_brightness() { double value; -value = diffusirradiance * air_mass() / ( solar_constant_e*get_eccentricity()); +value = diffuseirradiance * air_mass() / ( solar_constant_e*get_eccentricity()); return(value); } @@ -924,17 +1143,17 @@ return(value); /* Perez sky's clearness */ double sky_clearness() { -double value; + double value; -value = ( (diffusirradiance + directirradiance)/(diffusirradiance) + 1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180 ) / (1 + 1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180) ; + value = ( (diffuseirradiance + directirradiance)/(diffuseirradiance) + 1.041*sunzenith*M_PI/180*sunzenith*M_PI/180*sunzenith*M_PI/180 ) / (1 + 1.041*sunzenith*M_PI/180*sunzenith*M_PI/180*sunzenith*M_PI/180) ; -return(value); + return(value); } /* diffus horizontal irradiance from Perez sky's brightness */ -double diffus_irradiance_from_sky_brightness() +double diffuse_irradiance_from_sky_brightness() { double value; @@ -949,97 +1168,88 @@ double direct_irradiance_from_sky_clearness() { double value; - value = diffus_irradiance_from_sky_brightness(); - value = value * ( (skyclearness-1) * (1+1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180) ); + value = diffuse_irradiance_from_sky_brightness(); + value = value * ( (skyclearness-1) * (1+1.041*sunzenith*M_PI/180*sunzenith*M_PI/180*sunzenith*M_PI/180) ); return(value); } -void illu_to_irra_index(void) + + +void illu_to_irra_index() { -double test1=0.1, test2=0.1; +double test1=0.1, test2=0.1, d_eff; int counter=0; -diffusirradiance = diffusilluminance*solar_constant_e/(solar_constant_l*1000); +diffuseirradiance = diffuseilluminance*solar_constant_e/(solar_constant_l*1000); directirradiance = directilluminance*solar_constant_e/(solar_constant_l*1000); skyclearness = sky_clearness(); skybrightness = sky_brightness(); -if (skyclearness>12) skyclearness=12; -if (skybrightness<0.05) skybrightness=0.01; - - -while ( ((fabs(diffusirradiance-test1)>10) || (fabs(directirradiance-test2)>10) - || skyclearness>skyclearinf || skyclearnessskybriginf || skybrightness10) || (fabs(directirradiance-test2)>10) + || (!(skyclearnessskyclearsup)) + || (!(skybrightnessskybrigsup)) ) + && !(counter==9) ) + { + + test1=diffuseirradiance; test2=directirradiance; counter++; - diffusirradiance = diffusilluminance/glob_h_diffuse_effi_PEREZ(); - directirradiance = directilluminance/direct_n_effi_PEREZ(); - /*fprintf(stderr, "conversion illuminance into irradiance %lf\t %lf\n", diffusirradiance, directirradiance);*/ + diffuseirradiance = diffuseilluminance/glob_h_diffuse_effi_PEREZ(); + d_eff = direct_n_effi_PEREZ(); + + if (d_eff < 0.1) + directirradiance = 0; + else + directirradiance = directilluminance/d_eff; + skybrightness = sky_brightness(); skyclearness = sky_clearness(); - if (skyclearness>12) skyclearness=12; - if (skybrightness<0.05) skybrightness=0.01; - - /*fprintf(stderr, "%lf\t %lf\n", skybrightness, skyclearness);*/ - + check_parametrization(); + + /*fprintf(stderr,"skyclearness = %lf, skybrightness = %lf, directirradiance = %lf, diffuseirradiance = %lf\n",skyclearness, skybrightness, directirradiance, diffuseirradiance);*/ + } return; } - -int lect_coeff_perez(char *filename,float **coeff_perez) +static int get_numlin(float epsilon) { - FILE *fcoeff_perez; - float temp; - int i,j; - - if ((fcoeff_perez = frlibopen(filename)) == NULL) - { - fprintf(stderr,"file %s cannot be opened\n", filename); - return 1; /* il y a un probleme de fichier */ - } - else - { - /*printf("file %s open\n", filename);*/ - } - - skip_comments(fcoeff_perez); - - for (i=0;i<8;i++) - for (j=0;j<20;j++) - { - fscanf(fcoeff_perez,"%f",&temp); - *(*coeff_perez+i*20+j) = temp; - } - fclose(fcoeff_perez); - - return 0; /* tout est OK */ + if (epsilon < 1.065) + return 0; + else if (epsilon < 1.230) + return 1; + else if (epsilon < 1.500) + return 2; + else if (epsilon < 1.950) + return 3; + else if (epsilon < 2.800) + return 4; + else if (epsilon < 4.500) + return 5; + else if (epsilon < 6.200) + return 6; + return 7; } - - /* sky luminance perez model */ -double calc_rel_lum_perez(double dzeta,double gamma,double Z, -double epsilon,double Delta,float *coeff_perez) +double calc_rel_lum_perez(double dzeta,double gamma,double Z,double epsilon,double Delta,float coeff_perez[]) { + float x[5][4]; int i,j,num_lin; double c_perez[5]; if ( (epsilon < skyclearinf) || (epsilon >= skyclearsup) ) { - fprintf(stderr,"Epsilon out of range in function calc_rel_lum_perez !\n"); + fprintf(stderr,"Epsilon out of range in function calc_rel_lum_perez!\n"); exit(1); } @@ -1048,21 +1258,15 @@ double epsilon,double Delta,float *coeff_perez) { if ( Delta < 0.2 ) Delta = 0.2; } - - if ( (epsilon >= 1.000) && (epsilon < 1.065) ) num_lin = 0; - if ( (epsilon >= 1.065) && (epsilon < 1.230) ) num_lin = 1; - if ( (epsilon >= 1.230) && (epsilon < 1.500) ) num_lin = 2; - if ( (epsilon >= 1.500) && (epsilon < 1.950) ) num_lin = 3; - if ( (epsilon >= 1.950) && (epsilon < 2.800) ) num_lin = 4; - if ( (epsilon >= 2.800) && (epsilon < 4.500) ) num_lin = 5; - if ( (epsilon >= 4.500) && (epsilon < 6.200) ) num_lin = 6; - if ( (epsilon >= 6.200) && (epsilon < 14.00) ) num_lin = 7; - + + + num_lin = get_numlin(epsilon); + for (i=0;i<5;i++) for (j=0;j<4;j++) { x[i][j] = *(coeff_perez + 20*num_lin + 4*i +j); - /* printf("x %d %d vaut %f\n",i,j,x[i][j]); */ + /* fprintf(stderr,"x %d %d vaut %f\n",i,j,x[i][j]); */ } @@ -1089,7 +1293,7 @@ double epsilon,double Delta,float *coeff_perez) /* coefficients for the sky luminance perez model */ -void coeff_lum_perez(double Z, double epsilon, double Delta, float *coeff_perez) +void coeff_lum_perez(double Z, double epsilon, double Delta, float coeff_perez[]) { float x[5][4]; int i,j,num_lin; @@ -1105,15 +1309,11 @@ void coeff_lum_perez(double Z, double epsilon, double { if ( Delta < 0.2 ) Delta = 0.2; } + + + num_lin = get_numlin(epsilon); - if ( (epsilon >= 1.000) && (epsilon < 1.065) ) num_lin = 0; - if ( (epsilon >= 1.065) && (epsilon < 1.230) ) num_lin = 1; - if ( (epsilon >= 1.230) && (epsilon < 1.500) ) num_lin = 2; - if ( (epsilon >= 1.500) && (epsilon < 1.950) ) num_lin = 3; - if ( (epsilon >= 1.950) && (epsilon < 2.800) ) num_lin = 4; - if ( (epsilon >= 2.800) && (epsilon < 4.500) ) num_lin = 5; - if ( (epsilon >= 4.500) && (epsilon < 6.200) ) num_lin = 6; - if ( (epsilon >= 6.200) && (epsilon < 14.00) ) num_lin = 7; + /*fprintf(stderr,"numlin %d\n", num_lin);*/ for (i=0;i<5;i++) for (j=0;j<4;j++) @@ -1145,18 +1345,21 @@ void coeff_lum_perez(double Z, double epsilon, double } + /* degrees into radians */ double radians(double degres) { - return degres*PI/180.0; + return degres*M_PI/180.0; } + /* radian into degrees */ double degres(double radians) { - return radians/PI*180.0; + return radians/M_PI*180.0; } + /* calculation of the angles dzeta and gamma */ void theta_phi_to_dzeta_gamma(double theta,double phi,double *dzeta,double *gamma, double Z) { @@ -1173,130 +1376,22 @@ void theta_phi_to_dzeta_gamma(double theta,double phi, } -/********************************************************************************/ -/* Fonction: theta_ordered */ -/* */ -/* In: char *filename */ -/* */ -/* Out: float * */ -/* */ -/* Update: 29/08/93 */ -/* */ -/* Rem: theta en degres */ -/* */ -/* But: fournit les valeurs de theta du fichier d'entree a la memoire */ -/* */ -/********************************************************************************/ -float *theta_ordered(char *filename) -{ - int i; - float buffer,*ptr; - FILE *file_in; - if ( (file_in = frlibopen(filename)) == NULL ) - { - fprintf(stderr,"Cannot open file %s in function theta_ordered\n",filename); - exit(1); - } - - skip_comments(file_in); - - if ( (ptr = malloc(145*sizeof(float))) == NULL ) - { - fprintf(stderr,"Out of memory in function theta_ordered\n"); - exit(1); - } - - for (i=0;i<145;i++) - { - fscanf(file_in,"%f",&buffer); - *(ptr+i) = buffer; - fscanf(file_in,"%f",&buffer); - } - - fclose(file_in); - return ptr; -} - - -/********************************************************************************/ -/* Fonction: phi_ordered */ -/* */ -/* In: char *filename */ -/* */ -/* Out: float * */ -/* */ -/* Update: 29/08/93 */ -/* */ -/* Rem: valeurs de Phi en DEGRES */ -/* */ -/* But: mettre les angles contenus dans le fichier d'entree dans la memoire */ -/* */ -/********************************************************************************/ -float *phi_ordered(char *filename) +double integ_lv(float *lv,float *theta) { int i; - float buffer,*ptr; - FILE *file_in; - - if ( (file_in = frlibopen(filename)) == NULL ) - { - fprintf(stderr,"Cannot open file %s in function phi_ordered\n",filename); - exit(1); - } + double buffer=0.0; - skip_comments(file_in); - - if ( (ptr = malloc(145*sizeof(float))) == NULL ) - { - fprintf(stderr,"Out of memory in function phi_ordered"); - exit(1); - } - for (i=0;i<145;i++) { - fscanf(file_in,"%f",&buffer); - fscanf(file_in,"%f",&buffer); - *(ptr+i) = buffer; + buffer += (*(lv+i))*cos(radians(*(theta+i))); } - - fclose(file_in); - return ptr; + + return buffer*2*M_PI/144; } -/********************************************************************************/ -/* Fonction: integ_lv */ -/* */ -/* In: float *lv,*theta */ -/* int sun_pos */ -/* */ -/* Out: double */ -/* */ -/* Update: 29/08/93 */ -/* */ -/* Rem: */ -/* */ -/* But: calcul l'integrale de luminance relative sans la dir. du soleil */ -/* */ -/********************************************************************************/ -double integ_lv(float *lv,float *theta) -{ - int i; - double buffer=0.0; - for (i=0;i<145;i++) - buffer += (*(lv+i))*cos(radians(*(theta+i))); - - return buffer*2*PI/144; - -} - - - - - - /* enter day number(double), return E0 = square(R0/R): eccentricity correction factor */ double get_eccentricity() @@ -1304,12 +1399,11 @@ double get_eccentricity() double day_angle; double E0; - day_angle = 2*PI*(daynumber - 1)/365; + day_angle = 2*M_PI*(daynumber - 1)/365; E0 = 1.00011+0.034221*cos(day_angle)+0.00128*sin(day_angle)+ 0.000719*cos(2*day_angle)+0.000077*sin(2*day_angle); return (E0); - } @@ -1317,37 +1411,14 @@ double get_eccentricity() double air_mass() { double m; - if (sunzenith>90) { - fprintf(stderr, "solar zenith angle larger than 90³ in fuction air_mass():\n the models used are not more valid\n"); + fprintf(stderr, "Solar zenith angle larger than 90 degrees in function air_mass()\n"); exit(1); } - -m = 1/( cos(sunzenith*PI/180)+0.15*exp( log(93.885-sunzenith)*(-1.253) ) ); +m = 1/( cos(sunzenith*M_PI/180)+0.15*exp( log(93.885-sunzenith)*(-1.253) ) ); return(m); } - - -double get_angle_sun_direction(double sun_zenith, double sun_azimut, double direction_zenith, double direction_azimut) - -{ - -double angle; - - -if (sun_zenith == 0) - puts("WARNING: zenith_angle = 0 in function get_angle_sun_vert_plan"); - -angle = acos( cos(sun_zenith*PI/180)*cos(direction_zenith*PI/180) + sin(sun_zenith*PI/180)*sin(direction_zenith*PI/180)*cos((sun_azimut-direction_azimut)*PI/180) ); -angle = angle*180/PI; -return(angle); -} - - - - -
