root/radiance/ray/src/gen/gendaylit.c
Revision: 2.8
Committed: Wed Oct 5 17:33:36 2011 UTC (12 years, 8 months ago) by greg
Forgot to include rtmath.h
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.8 static const char RCSid[] = "$Id: gendaylit.c,v 2.7 2011/10/05 17:20:55 greg Exp $";
3 greg 2.1 #endif
4     /* Copyright (c) 1994 *Fraunhofer Institut for Solar Energy Systems
5     * Oltmannstr 5, D-79100 Freiburg, Germany
6     * *Agence de l'Environnement et de la Maitrise de l'Energie
7     * Centre de Valbonne, 500 route des Lucioles, 06565 Sophia Antipolis Cedex, France
8     * *BOUYGUES
9     * 1 Avenue Eugene Freyssinet, Saint-Quentin-Yvelines, France
10     */
11
12
13
14     /*
15     * gendaylit.c program to generate the angular distribution of the daylight.
16     * Our zenith is along the Z-axis, the X-axis
17     * points east, and the Y-axis points north.
18     */
19
20     #include <stdio.h>
21     #include <string.h>
22     #include <math.h>
23     #include <stdlib.h>
24 greg 2.2 #include <ctype.h>
25 greg 2.1
26 greg 2.8 #include "rtmath.h"
27 greg 2.1 #include "rtio.h"
28     #include "color.h"
29     #include "paths.h"
30
31     extern int jdate(int month, int day);
32     extern double stadj(int jd);
33     extern double sdec(int jd);
34     extern double salt(double sd, double st);
35     extern double sazi(double sd, double st);
36
37     double normsc();
38
39     #define DATFILE "coeff_perez.dat"
40
41
42
43     /* Perez sky parametrization : epsilon and delta calculations from the direct and diffuse irradiances */
44     double sky_brightness();
45     double sky_clearness();
46 greg 2.5 void computesky();
47 greg 2.1
48     /* calculation of the direct and diffuse components from the Perez parametrization */
49     double diffus_irradiance_from_sky_brightness();
50     double direct_irradiance_from_sky_clearness();
51
52
53     /* Perez global horizontal, diffuse horizontal and direct normal luminous efficacy models : input w(cm)=2cm, solar zenith angle(degrees); output efficacy(lm/W) */
54     double glob_h_effi_PEREZ();
55     double glob_h_diffuse_effi_PEREZ();
56     double direct_n_effi_PEREZ();
57     /*likelihood check of the epsilon, delta, direct and diffuse components*/
58     void check_parametrization();
59     void check_irradiances();
60     void check_illuminances();
61     void illu_to_irra_index();
62
63
64     /* Perez sky luminance model */
65     int lect_coeff_perez(char *filename,float **coeff_perez);
66     double calc_rel_lum_perez(double dzeta,double gamma,double Z,
67     double epsilon,double Delta,float *coeff_perez);
68     /* coefficients for the sky luminance perez model */
69     void coeff_lum_perez(double Z, double epsilon, double Delta, float *coeff_perez);
70     double radians(double degres);
71     double degres(double radians);
72     void theta_phi_to_dzeta_gamma(double theta,double phi,double *dzeta,double *gamma, double Z);
73     double integ_lv(float *lv,float *theta);
74     float *theta_ordered(char *filename);
75     float *phi_ordered(char *filename);
76 greg 2.2 void skip_comments(FILE *fp);
77 greg 2.1
78
79
80     /* astronomy and geometry*/
81     double get_eccentricity();
82     double air_mass();
83     double get_angle_sun_direction(double sun_zenith, double sun_azimut, double direction_zenith, double direction_azimut);
84
85
86     /* date*/
87     int jdate(int month, int day);
88
89
90
91
92
93     /* sun calculation constants */
94     extern double s_latitude;
95     extern double s_longitude;
96     extern double s_meridian;
97
98     const double AU = 149597890E3;
99     const double solar_constant_e = 1367; /* solar constant W/m^2 */
100     const double solar_constant_l = 127.5; /* solar constant klux */
101
102     const double half_sun_angle = 0.2665;
103     const double half_direct_angle = 2.85;
104
105     const double skyclearinf = 1.000; /* limitations for the variation of the Perez parameters */
106     const double skyclearsup = 12.1;
107     const double skybriginf = 0.01;
108     const double skybrigsup = 0.6;
109
110
111
112     /* required values */
113     int month, day; /* date */
114     double hour; /* time */
115     int tsolar; /* 0=standard, 1=solar */
116     double altitude, azimuth; /* or solar angles */
117
118
119
120     /* definition of the sky conditions through the Perez parametrization */
121     double skyclearness, skybrightness;
122     double solarradiance; /*radiance of the sun disk and of the circumsolar area*/
123     double diffusilluminance, directilluminance, diffusirradiance, directirradiance;
124     double sunzenith, daynumber=150, atm_preci_water=2;
125
126     double diffnormalization, dirnormalization;
127     double *c_perez;
128
129     int output=0; /*define the unit of the output (sky luminance or radiance): visible watt=0, solar watt=1, lumen=2*/
130     int input=0; /*define the input for the calulation*/
131
132     /* default values */
133     int cloudy = 0; /* 1=standard, 2=uniform */
134     int dosun = 1;
135     double zenithbr = -1.0;
136     double betaturbidity = 0.1;
137     double gprefl = 0.2;
138     int S_INTER=0;
139
140     /* computed values */
141     double sundir[3];
142     double groundbr;
143     double F2;
144     double solarbr = 0.0;
145     int u_solar = 0; /* -1=irradiance, 1=radiance */
146
147     char *progname;
148     char errmsg[128];
149
150
151     main(argc, argv)
152     int argc;
153     char *argv[];
154     {
155     int i;
156
157     progname = argv[0];
158     if (argc == 2 && !strcmp(argv[1], "-defaults")) {
159     printdefaults();
160     exit(0);
161     }
162     if (argc < 4)
163     userror("arg count");
164     if (!strcmp(argv[1], "-ang")) {
165 greg 2.7 altitude = atof(argv[2]) * (PI/180);
166     azimuth = atof(argv[3]) * (PI/180);
167 greg 2.1 month = 0;
168     } else {
169     month = atoi(argv[1]);
170     if (month < 1 || month > 12)
171     userror("bad month");
172     day = atoi(argv[2]);
173     if (day < 1 || day > 31)
174     userror("bad day");
175     hour = atof(argv[3]);
176     if (hour < 0 || hour >= 24)
177     userror("bad hour");
178     tsolar = argv[3][0] == '+';
179     }
180     for (i = 4; i < argc; i++)
181     if (argv[i][0] == '-' || argv[i][0] == '+')
182     switch (argv[i][1]) {
183     case 's':
184     cloudy = 0;
185     dosun = argv[i][0] == '+';
186     break;
187     case 'r':
188     case 'R':
189     u_solar = argv[i][1] == 'R' ? -1 : 1;
190     solarbr = atof(argv[++i]);
191     break;
192     case 'c':
193     cloudy = argv[i][0] == '+' ? 2 : 1;
194     dosun = 0;
195     break;
196     case 't':
197     betaturbidity = atof(argv[++i]);
198     break;
199     case 'b':
200     zenithbr = atof(argv[++i]);
201     break;
202     case 'g':
203     gprefl = atof(argv[++i]);
204     break;
205     case 'a':
206 greg 2.7 s_latitude = atof(argv[++i]) * (PI/180);
207 greg 2.1 break;
208     case 'o':
209 greg 2.7 s_longitude = atof(argv[++i]) * (PI/180);
210 greg 2.1 break;
211     case 'm':
212 greg 2.7 s_meridian = atof(argv[++i]) * (PI/180);
213 greg 2.1 break;
214
215
216     case 'O':
217     output = atof(argv[++i]); /*define the unit of the output of the program :
218     sky and sun luminance/radiance (0==W visible, 1==W solar radiation, 2==lm)
219     default is set to 0*/
220     break;
221
222     case 'P':
223     input = 0; /* Perez parameters: epsilon, delta */
224     skyclearness = atof(argv[++i]);
225     skybrightness = atof(argv[++i]);
226     break;
227
228     case 'W': /* direct normal Irradiance [W/m^2] */
229     input = 1; /* diffuse horizontal Irrad. [W/m^2] */
230     directirradiance = atof(argv[++i]);
231     diffusirradiance = atof(argv[++i]);
232     break;
233
234     case 'L': /* direct normal Illuminance [Lux] */
235     input = 2; /* diffuse horizontal Ill. [Lux] */
236     directilluminance = atof(argv[++i]);
237     diffusilluminance = atof(argv[++i]);
238     break;
239
240     case 'G': /* direct horizontal Irradiance [W/m^2] */
241     input = 3; /* diffuse horizontal Irrad. [W/m^2] */
242     directirradiance = atof(argv[++i]);
243     diffusirradiance = atof(argv[++i]);
244     break;
245
246
247     default:
248     sprintf(errmsg, "unknown option: %s", argv[i]);
249     userror(errmsg);
250     }
251     else
252     userror("bad option");
253
254 greg 2.7 if (fabs(s_meridian-s_longitude) > 30*PI/180)
255 greg 2.1 fprintf(stderr,
256     "%s: warning: %.1f hours btwn. standard meridian and longitude\n",
257 greg 2.7 progname, (s_longitude-s_meridian)*12/PI);
258 greg 2.1
259
260     /* allocation dynamique de memoire pour les pointeurs */
261     if ( (c_perez = malloc(5*sizeof(double))) == NULL )
262     {
263     fprintf(stderr,"Out of memory error in function main !");
264     exit(1);
265     }
266
267
268     printhead(argc, argv);
269
270     computesky();
271     printsky();
272
273     exit(0);
274     }
275
276
277 greg 2.4 void
278 greg 2.1 computesky() /* compute sky parameters */
279     {
280
281     /* new variables */
282 greg 2.6 int j;
283 greg 2.1 float *lv_mod; /* 145 luminance values*/
284     /* 145 directions for the calculation of the normalization coefficient, coefficient Perez model */
285     float *theta_o, *phi_o, *coeff_perez;
286     double dzeta, gamma;
287     double normfactor;
288
289
290
291     /* compute solar direction */
292
293     if (month) { /* from date and time */
294     int jd;
295     double sd, st;
296
297     jd = jdate(month, day); /* Julian date */
298     sd = sdec(jd); /* solar declination */
299     if (tsolar) /* solar time */
300     st = hour;
301     else
302     st = hour + stadj(jd);
303     altitude = salt(sd, st);
304     azimuth = sazi(sd, st);
305
306     daynumber = (double)jdate(month, day);
307
308     }
309 greg 2.7 if (!cloudy && altitude > 87.*PI/180.) {
310 greg 2.1 fprintf(stderr,
311     "%s: warning - sun too close to zenith, reducing altitude to 87 degrees\n",
312     progname);
313     printf(
314     "# warning - sun too close to zenith, reducing altitude to 87 degrees\n");
315 greg 2.7 altitude = 87.*PI/180.;
316 greg 2.1 }
317     sundir[0] = -sin(azimuth)*cos(altitude);
318     sundir[1] = -cos(azimuth)*cos(altitude);
319     sundir[2] = sin(altitude);
320
321
322     /* calculation for the new functions */
323 greg 2.7 sunzenith = 90 - altitude*180/PI;
324 greg 2.1
325
326
327     /* compute the inputs for the calculation of the light distribution over the sky*/
328     if (input==0)
329     {
330     check_parametrization();
331     diffusirradiance = diffus_irradiance_from_sky_brightness(); /*diffuse horizontal irradiance*/
332     directirradiance = direct_irradiance_from_sky_clearness();
333     check_irradiances();
334
335     if (output==0 || output==2)
336     {
337     diffusilluminance = diffusirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/
338     directilluminance = directirradiance*direct_n_effi_PEREZ();
339     check_illuminances();
340     }
341     }
342
343
344     else if (input==1)
345     {
346     check_irradiances();
347     skybrightness = sky_brightness();
348     skyclearness = sky_clearness();
349     check_parametrization();
350
351     if (output==0 || output==2)
352     {
353     diffusilluminance = diffusirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/
354     directilluminance = directirradiance*direct_n_effi_PEREZ();
355     check_illuminances();
356     }
357
358     }
359
360
361     else if (input==2)
362     {
363     check_illuminances();
364     illu_to_irra_index();
365     check_parametrization();
366     }
367
368
369     else if (input==3)
370     {
371     if (altitude<=0)
372     {
373     fprintf(stderr, "solar zenith angle larger than 90� \n the models used are not more valid\n");
374     exit(1);
375     }
376
377     directirradiance=directirradiance/sin(altitude);
378     check_irradiances();
379     skybrightness = sky_brightness();
380     skyclearness = sky_clearness();
381     check_parametrization();
382
383     if (output==0 || output==2)
384     {
385     diffusilluminance = diffusirradiance*glob_h_diffuse_effi_PEREZ();/*diffuse horizontal illuminance*/
386     directilluminance = directirradiance*direct_n_effi_PEREZ();
387     check_illuminances();
388     }
389
390     }
391
392
393     else {fprintf(stderr,"error in giving the input arguments"); exit(1);}
394
395
396
397     /* normalization factor for the relative sky luminance distribution, diffuse part*/
398
399     /* allocation dynamique de memoire pour les pointeurs */
400     if ( (coeff_perez = malloc(8*20*sizeof(float))) == NULL )
401     {
402     fprintf(stderr,"Out of memory error in function main !");
403     exit(1);
404     }
405
406     /* read the coefficients for the Perez sky luminance model */
407     if (lect_coeff_perez(DATFILE, &coeff_perez) > 0)
408     {
409     fprintf(stderr,"lect_coeff_perez does not work\n");
410     exit(2);
411     }
412
413     if ( (lv_mod = malloc(145*sizeof(float))) == NULL)
414     {
415     fprintf(stderr,"Out of memory in function main");
416     exit(1);
417     }
418
419     /* read the angles */
420     theta_o = theta_ordered("defangle.dat");
421     phi_o = phi_ordered("defangle.dat");
422
423     /* parameters for the perez model */
424     coeff_lum_perez(radians(sunzenith), skyclearness, skybrightness, coeff_perez);
425
426     /*calculation of the modelled luminance */
427     for (j=0;j<145;j++)
428     {
429     theta_phi_to_dzeta_gamma(radians(*(theta_o+j)),radians(*(phi_o+j)),&dzeta,&gamma,radians(sunzenith));
430     *(lv_mod+j) = calc_rel_lum_perez(dzeta,gamma,radians(sunzenith),skyclearness,skybrightness,coeff_perez);
431     /*printf("theta, phi, lv_mod %lf\t %lf\t %lf\n", *(theta_o+j),*(phi_o+j),*(lv_mod+j));*/
432     }
433
434     /* integration of luminance for the normalization factor, diffuse part of the sky*/
435     diffnormalization = integ_lv(lv_mod, theta_o);
436     /*printf("perez integration %lf\n", diffnormalization);*/
437
438
439
440
441     /*normalization coefficient in lumen or in watt*/
442     if (output==0)
443     {
444     diffnormalization = diffusilluminance/diffnormalization/WHTEFFICACY;
445     }
446     else if (output==1)
447     {
448     diffnormalization = diffusirradiance/diffnormalization;
449     }
450     else if (output==2)
451     {
452     diffnormalization = diffusilluminance/diffnormalization;
453     }
454
455     else {fprintf(stderr,"output argument : wrong number"); exit(1);}
456
457
458
459
460     /* calculation for the solar source */
461     if (output==0)
462 greg 2.7 solarradiance = directilluminance/(2*PI*(1-cos(half_sun_angle*PI/180)))/WHTEFFICACY;
463 greg 2.1
464     else if (output==1)
465 greg 2.7 solarradiance = directirradiance/(2*PI*(1-cos(half_sun_angle*PI/180)));
466 greg 2.1
467     else
468 greg 2.7 solarradiance = directilluminance/(2*PI*(1-cos(half_sun_angle*PI/180)));
469 greg 2.1
470
471
472
473     /* Compute the ground radiance */
474     zenithbr=calc_rel_lum_perez(0.0,radians(sunzenith),radians(sunzenith),skyclearness,skybrightness,coeff_perez);
475     zenithbr*=diffnormalization;
476 greg 2.3 /*
477 greg 2.1 fprintf(stderr, "gendaylit : the actual zenith radiance(W/m^2/sr) or luminance(cd/m^2) is : %.0lf\n", zenithbr);
478 greg 2.3 */
479
480 greg 2.1 if (skyclearness==1)
481     normfactor = 0.777778;
482
483     if (skyclearness>=6)
484     {
485 greg 2.7 F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + 0.45*sundir[2]*sundir[2]);
486     normfactor = normsc()/F2/PI;
487 greg 2.1 }
488
489     if ( (skyclearness>1) && (skyclearness<6) )
490     {
491     S_INTER=1;
492 greg 2.7 F2 = (2.739 + .9891*sin(.3119+2.6*altitude)) * exp(-(PI/2.0-altitude)*(.4441+1.48*altitude));
493     normfactor = normsc()/F2/PI;
494 greg 2.1 }
495
496     groundbr = zenithbr*normfactor;
497     printf("# Ground ambient level: %.1f\n", groundbr);
498
499     if (dosun&&(skyclearness>1))
500 greg 2.7 groundbr += 6.8e-5/PI*solarradiance*sundir[2];
501 greg 2.1
502     groundbr *= gprefl;
503
504
505
506     return;
507     }
508
509
510
511
512
513
514
515     printsky() /* print out sky */
516     {
517     if (dosun&&(skyclearness>1))
518     {
519     printf("\nvoid light solar\n");
520     printf("0\n0\n");
521     printf("3 %.3e %.3e %.3e\n", solarradiance, solarradiance, solarradiance);
522     printf("\nsolar source sun\n");
523     printf("0\n0\n");
524     printf("4 %f %f %f %f\n", sundir[0], sundir[1], sundir[2], 2*half_sun_angle);
525     }
526
527     if (dosun&&(skyclearness==1))
528     {
529     printf("\nvoid light solar\n");
530     printf("0\n0\n");
531     printf("3 0.0 0.0 0.0\n");
532     printf("\nsolar source sun\n");
533     printf("0\n0\n");
534     printf("4 %f %f %f %f\n", sundir[0], sundir[1], sundir[2], 2*half_sun_angle);
535     }
536
537
538     printf("\nvoid brightfunc skyfunc\n");
539     printf("2 skybright perezlum.cal\n");
540     printf("0\n");
541     printf("10 %.3e %.3e %lf %lf %lf %lf %lf %f %f %f \n", diffnormalization, groundbr,
542     *(c_perez+0),*(c_perez+1),*(c_perez+2),*(c_perez+3),*(c_perez+4),
543     sundir[0], sundir[1], sundir[2]);
544     }
545
546
547     printdefaults() /* print default values */
548     {
549     printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl);
550     if (zenithbr > 0.0)
551     printf("-b %f\t\t\t# Zenith radiance (watts/ster/m^2\n", zenithbr);
552     else
553     printf("-t %f\t\t\t# Atmospheric betaturbidity\n", betaturbidity);
554 greg 2.7 printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI));
555     printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI));
556     printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI));
557 greg 2.1 }
558
559
560     userror(msg) /* print usage error and quit */
561     char *msg;
562     {
563     if (msg != NULL)
564     fprintf(stderr, "%s: Use error - %s\n", progname, msg);
565     fprintf(stderr, "Usage: %s month day hour [-P|-W|-L] direct_value diffus_value [options]\n", progname);
566     fprintf(stderr, "or : %s -ang altitude azimuth [-P|-W|-L] direct_value diffus_value [options]\n", progname);
567     fprintf(stderr, " -P epsilon delta (these are the Perez parameters) \n");
568     fprintf(stderr, " -W direct-normal-irradiance diffuse-horizontal-irradiance (W/m^2)\n");
569     fprintf(stderr, " -L direct-normal-illuminance diffuse-horizontal-illuminance (lux)\n");
570     fprintf(stderr, " -G direct-horizontal-irradiance diffuse-horizontal-irradiance (W/m^2)\n");
571     fprintf(stderr, " -O [0|1|2] (0=output in W/m^2/sr visible, 1=output in W/m^2/sr solar, 2=output in candela/m^2), default is 0 \n");
572     exit(1);
573     }
574
575
576
577     double
578     normsc() /* compute normalization factor (E0*F2/L0) */
579     {
580     static double nfc[2][5] = {
581     /* clear sky approx. */
582     {2.766521, 0.547665, -0.369832, 0.009237, 0.059229},
583     /* intermediate sky approx. */
584     {3.5556, -2.7152, -1.3081, 1.0660, 0.60227},
585     };
586     register double *nf;
587     double x, nsc;
588     register int i;
589     /* polynomial approximation */
590     nf = nfc[S_INTER];
591 greg 2.7 x = (altitude - PI/4.0)/(PI/4.0);
592 greg 2.1 nsc = nf[i=4];
593     while (i--)
594     nsc = nsc*x + nf[i];
595
596     return(nsc);
597     }
598
599
600
601     printhead(ac, av) /* print command header */
602     register int ac;
603     register char **av;
604     {
605     putchar('#');
606     while (ac--) {
607     putchar(' ');
608     fputs(*av++, stdout);
609     }
610     putchar('\n');
611     }
612
613
614
615
616 greg 2.2 void
617     skip_comments(FILE *fp) /* skip comments in file */
618     {
619     int c;
620
621     while ((c = getc(fp)) != EOF)
622     if (c == '#') {
623     while ((c = getc(fp)) != EOF)
624     if (c == '\n')
625     break;
626     } else if (!isspace(c)) {
627     ungetc(c, fp);
628     break;
629     }
630     }
631 greg 2.1
632
633
634     /* Perez models */
635
636     /* Perez global horizontal luminous efficacy model */
637     double glob_h_effi_PEREZ()
638     {
639
640     double value;
641     double category_bounds[10], a[10], b[10], c[10], d[10];
642     int category_total_number, category_number, i;
643
644
645     if (skyclearness<skyclearinf || skyclearness>skyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup)
646     fprintf(stderr, "Warning : skyclearness or skybrightness out of range ; \n Check your input parameters\n");
647
648     /* initialize category bounds (clearness index bounds) */
649
650     category_total_number = 8;
651
652     category_bounds[1] = 1;
653     category_bounds[2] = 1.065;
654     category_bounds[3] = 1.230;
655     category_bounds[4] = 1.500;
656     category_bounds[5] = 1.950;
657     category_bounds[6] = 2.800;
658     category_bounds[7] = 4.500;
659     category_bounds[8] = 6.200;
660     category_bounds[9] = 12.01;
661
662
663     /* initialize model coefficients */
664     a[1] = 96.63;
665     a[2] = 107.54;
666     a[3] = 98.73;
667     a[4] = 92.72;
668     a[5] = 86.73;
669     a[6] = 88.34;
670     a[7] = 78.63;
671     a[8] = 99.65;
672
673     b[1] = -0.47;
674     b[2] = 0.79;
675     b[3] = 0.70;
676     b[4] = 0.56;
677     b[5] = 0.98;
678     b[6] = 1.39;
679     b[7] = 1.47;
680     b[8] = 1.86;
681
682     c[1] = 11.50;
683     c[2] = 1.79;
684     c[3] = 4.40;
685     c[4] = 8.36;
686     c[5] = 7.10;
687     c[6] = 6.06;
688     c[7] = 4.93;
689     c[8] = -4.46;
690
691     d[1] = -9.16;
692     d[2] = -1.19;
693     d[3] = -6.95;
694     d[4] = -8.31;
695     d[5] = -10.94;
696     d[6] = -7.60;
697     d[7] = -11.37;
698     d[8] = -3.15;
699
700
701
702
703     for (i=1; i<=category_total_number; i++)
704     {
705     if ( (skyclearness >= category_bounds[i]) && (skyclearness < category_bounds[i+1]) )
706     category_number = i;
707     }
708
709     value = a[category_number] + b[category_number]*atm_preci_water +
710 greg 2.7 c[category_number]*cos(sunzenith*PI/180) + d[category_number]*log(skybrightness);
711 greg 2.1
712     return(value);
713     }
714
715
716     /* global horizontal diffuse efficacy model, according to PEREZ */
717     double glob_h_diffuse_effi_PEREZ()
718     {
719     double value;
720     double category_bounds[10], a[10], b[10], c[10], d[10];
721     int category_total_number, category_number, i;
722
723
724     if (skyclearness<skyclearinf || skyclearness>skyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup)
725     fprintf(stderr, "Warning : skyclearness or skybrightness out of range ; \n Check your input parameters\n");
726
727     /* initialize category bounds (clearness index bounds) */
728
729     category_total_number = 8;
730
731     category_bounds[1] = 1;
732     category_bounds[2] = 1.065;
733     category_bounds[3] = 1.230;
734     category_bounds[4] = 1.500;
735     category_bounds[5] = 1.950;
736     category_bounds[6] = 2.800;
737     category_bounds[7] = 4.500;
738     category_bounds[8] = 6.200;
739     category_bounds[9] = 12.01;
740
741
742     /* initialize model coefficients */
743     a[1] = 97.24;
744     a[2] = 107.22;
745     a[3] = 104.97;
746     a[4] = 102.39;
747     a[5] = 100.71;
748     a[6] = 106.42;
749     a[7] = 141.88;
750     a[8] = 152.23;
751
752     b[1] = -0.46;
753     b[2] = 1.15;
754     b[3] = 2.96;
755     b[4] = 5.59;
756     b[5] = 5.94;
757     b[6] = 3.83;
758     b[7] = 1.90;
759     b[8] = 0.35;
760
761     c[1] = 12.00;
762     c[2] = 0.59;
763     c[3] = -5.53;
764     c[4] = -13.95;
765     c[5] = -22.75;
766     c[6] = -36.15;
767     c[7] = -53.24;
768     c[8] = -45.27;
769
770     d[1] = -8.91;
771     d[2] = -3.95;
772     d[3] = -8.77;
773     d[4] = -13.90;
774     d[5] = -23.74;
775     d[6] = -28.83;
776     d[7] = -14.03;
777     d[8] = -7.98;
778
779
780
781
782     for (i=1; i<=category_total_number; i++)
783     {
784     if ( (skyclearness >= category_bounds[i]) && (skyclearness < category_bounds[i+1]) )
785     category_number = i;
786     }
787
788 greg 2.7 value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*cos(sunzenith*PI/180) +
789 greg 2.1 d[category_number]*log(skybrightness);
790
791     return(value);
792     }
793
794
795     /* direct normal efficacy model, according to PEREZ */
796
797     double direct_n_effi_PEREZ()
798
799     {
800     double value;
801     double category_bounds[10], a[10], b[10], c[10], d[10];
802     int category_total_number, category_number, i;
803
804
805     if (skyclearness<skyclearinf || skyclearness>skyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup)
806     fprintf(stderr, "Warning : skyclearness or skybrightness out of range ; \n Check your input parameters\n");
807
808
809     /* initialize category bounds (clearness index bounds) */
810
811     category_total_number = 8;
812
813     category_bounds[1] = 1;
814     category_bounds[2] = 1.065;
815     category_bounds[3] = 1.230;
816     category_bounds[4] = 1.500;
817     category_bounds[5] = 1.950;
818     category_bounds[6] = 2.800;
819     category_bounds[7] = 4.500;
820     category_bounds[8] = 6.200;
821     category_bounds[9] = 12.1;
822
823
824     /* initialize model coefficients */
825     a[1] = 57.20;
826     a[2] = 98.99;
827     a[3] = 109.83;
828     a[4] = 110.34;
829     a[5] = 106.36;
830     a[6] = 107.19;
831     a[7] = 105.75;
832     a[8] = 101.18;
833
834     b[1] = -4.55;
835     b[2] = -3.46;
836     b[3] = -4.90;
837     b[4] = -5.84;
838     b[5] = -3.97;
839     b[6] = -1.25;
840     b[7] = 0.77;
841     b[8] = 1.58;
842
843     c[1] = -2.98;
844     c[2] = -1.21;
845     c[3] = -1.71;
846     c[4] = -1.99;
847     c[5] = -1.75;
848     c[6] = -1.51;
849     c[7] = -1.26;
850     c[8] = -1.10;
851
852     d[1] = 117.12;
853     d[2] = 12.38;
854     d[3] = -8.81;
855     d[4] = -4.56;
856     d[5] = -6.16;
857     d[6] = -26.73;
858     d[7] = -34.44;
859     d[8] = -8.29;
860
861
862
863     for (i=1; i<=category_total_number; i++)
864     {
865     if ( (skyclearness >= category_bounds[i]) && (skyclearness < category_bounds[i+1]) )
866     category_number = i;
867     }
868
869 greg 2.7 value = a[category_number] + b[category_number]*atm_preci_water + c[category_number]*exp(5.73*sunzenith*PI/180 - 5) + d[category_number]*skybrightness;
870 greg 2.1
871     if (value < 0) value = 0;
872
873     return(value);
874     }
875
876
877     /*check the range of epsilon and delta indexes of the perez parametrization*/
878     void check_parametrization()
879     {
880     if (skyclearness<skyclearinf || skyclearness>skyclearsup || skybrightness<=skybriginf || skybrightness>skybrigsup)
881     {
882     fprintf(stderr,"sky clearness or sky brightness out of range %lf\t %lf\n", skyclearness, skybrightness);
883     exit(1);
884     }
885     else return;
886     }
887
888
889     /* likelihood of the direct and diffuse components */
890     void check_illuminances()
891     {
892     if (!( (directilluminance>=0) && (directilluminance<=solar_constant_l*1000) && (diffusilluminance>0) ))
893     {
894     fprintf(stderr,"direct or diffuse illuminances out of range\n");
895     exit(1);
896     }
897     return;
898     }
899
900
901     void check_irradiances()
902     {
903     if (!( (directirradiance>=0) && (directirradiance<=solar_constant_e) && (diffusirradiance>0) ))
904     {
905     fprintf(stderr,"direct or diffuse irradiances out of range\n");
906     exit(1);
907     }
908     return;
909     }
910
911
912
913     /* Perez sky's brightness */
914     double sky_brightness()
915     {
916     double value;
917
918     value = diffusirradiance * air_mass() / ( solar_constant_e*get_eccentricity());
919
920     return(value);
921     }
922
923
924     /* Perez sky's clearness */
925     double sky_clearness()
926     {
927     double value;
928
929 greg 2.7 value = ( (diffusirradiance + directirradiance)/(diffusirradiance) + 1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180 ) / (1 + 1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180) ;
930 greg 2.1
931     return(value);
932     }
933
934
935
936     /* diffus horizontal irradiance from Perez sky's brightness */
937     double diffus_irradiance_from_sky_brightness()
938     {
939     double value;
940
941     value = skybrightness / air_mass() * ( solar_constant_e*get_eccentricity());
942
943     return(value);
944     }
945
946
947     /* direct normal irradiance from Perez sky's clearness */
948     double direct_irradiance_from_sky_clearness()
949     {
950     double value;
951
952     value = diffus_irradiance_from_sky_brightness();
953 greg 2.7 value = value * ( (skyclearness-1) * (1+1.041*sunzenith*PI/180*sunzenith*PI/180*sunzenith*PI/180) );
954 greg 2.1
955     return(value);
956     }
957
958
959     void illu_to_irra_index(void)
960     {
961     double test1=0.1, test2=0.1;
962     int counter=0;
963
964     diffusirradiance = diffusilluminance*solar_constant_e/(solar_constant_l*1000);
965     directirradiance = directilluminance*solar_constant_e/(solar_constant_l*1000);
966     skyclearness = sky_clearness();
967     skybrightness = sky_brightness();
968     if (skyclearness>12) skyclearness=12;
969     if (skybrightness<0.05) skybrightness=0.01;
970
971
972     while ( ((fabs(diffusirradiance-test1)>10) || (fabs(directirradiance-test2)>10)
973     || skyclearness>skyclearinf || skyclearness<skyclearsup
974     || skybrightness>skybriginf || skybrightness<skybrigsup )
975     && !(counter==5) )
976     {
977     /*fprintf(stderr, "conversion illuminance into irradiance %lf\t %lf\n", diffusirradiance, directirradiance);*/
978
979     test1=diffusirradiance;
980     test2=directirradiance;
981     counter++;
982
983     diffusirradiance = diffusilluminance/glob_h_diffuse_effi_PEREZ();
984     directirradiance = directilluminance/direct_n_effi_PEREZ();
985     /*fprintf(stderr, "conversion illuminance into irradiance %lf\t %lf\n", diffusirradiance, directirradiance);*/
986
987     skybrightness = sky_brightness();
988     skyclearness = sky_clearness();
989     if (skyclearness>12) skyclearness=12;
990     if (skybrightness<0.05) skybrightness=0.01;
991
992     /*fprintf(stderr, "%lf\t %lf\n", skybrightness, skyclearness);*/
993
994     }
995
996
997     return;
998     }
999
1000
1001     int lect_coeff_perez(char *filename,float **coeff_perez)
1002     {
1003     FILE *fcoeff_perez;
1004     float temp;
1005     int i,j;
1006
1007     if ((fcoeff_perez = frlibopen(filename)) == NULL)
1008     {
1009     fprintf(stderr,"file %s cannot be opened\n", filename);
1010     return 1; /* il y a un probleme de fichier */
1011     }
1012     else
1013     {
1014     /*printf("file %s open\n", filename);*/
1015     }
1016 greg 2.2
1017     skip_comments(fcoeff_perez);
1018 greg 2.1
1019     for (i=0;i<8;i++)
1020     for (j=0;j<20;j++)
1021     {
1022     fscanf(fcoeff_perez,"%f",&temp);
1023     *(*coeff_perez+i*20+j) = temp;
1024     }
1025     fclose(fcoeff_perez);
1026
1027     return 0; /* tout est OK */
1028     }
1029
1030
1031
1032     /* sky luminance perez model */
1033     double calc_rel_lum_perez(double dzeta,double gamma,double Z,
1034     double epsilon,double Delta,float *coeff_perez)
1035     {
1036     float x[5][4];
1037     int i,j,num_lin;
1038     double c_perez[5];
1039
1040     if ( (epsilon < skyclearinf) || (epsilon >= skyclearsup) )
1041     {
1042     fprintf(stderr,"Epsilon out of range in function calc_rel_lum_perez !\n");
1043     exit(1);
1044     }
1045
1046     /* correction de modele de Perez solar energy ...*/
1047     if ( (epsilon > 1.065) && (epsilon < 2.8) )
1048     {
1049     if ( Delta < 0.2 ) Delta = 0.2;
1050     }
1051
1052     if ( (epsilon >= 1.000) && (epsilon < 1.065) ) num_lin = 0;
1053     if ( (epsilon >= 1.065) && (epsilon < 1.230) ) num_lin = 1;
1054     if ( (epsilon >= 1.230) && (epsilon < 1.500) ) num_lin = 2;
1055     if ( (epsilon >= 1.500) && (epsilon < 1.950) ) num_lin = 3;
1056     if ( (epsilon >= 1.950) && (epsilon < 2.800) ) num_lin = 4;
1057     if ( (epsilon >= 2.800) && (epsilon < 4.500) ) num_lin = 5;
1058     if ( (epsilon >= 4.500) && (epsilon < 6.200) ) num_lin = 6;
1059     if ( (epsilon >= 6.200) && (epsilon < 14.00) ) num_lin = 7;
1060
1061     for (i=0;i<5;i++)
1062     for (j=0;j<4;j++)
1063     {
1064     x[i][j] = *(coeff_perez + 20*num_lin + 4*i +j);
1065     /* printf("x %d %d vaut %f\n",i,j,x[i][j]); */
1066     }
1067
1068
1069     if (num_lin)
1070     {
1071     for (i=0;i<5;i++)
1072     c_perez[i] = x[i][0] + x[i][1]*Z + Delta * (x[i][2] + x[i][3]*Z);
1073     }
1074     else
1075     {
1076     c_perez[0] = x[0][0] + x[0][1]*Z + Delta * (x[0][2] + x[0][3]*Z);
1077     c_perez[1] = x[1][0] + x[1][1]*Z + Delta * (x[1][2] + x[1][3]*Z);
1078     c_perez[4] = x[4][0] + x[4][1]*Z + Delta * (x[4][2] + x[4][3]*Z);
1079     c_perez[2] = exp( pow(Delta*(x[2][0]+x[2][1]*Z),x[2][2])) - x[2][3];
1080     c_perez[3] = -exp( Delta*(x[3][0]+x[3][1]*Z) )+x[3][2]+Delta*x[3][3];
1081     }
1082
1083
1084     return (1 + c_perez[0]*exp(c_perez[1]/cos(dzeta)) ) *
1085     (1 + c_perez[2]*exp(c_perez[3]*gamma) +
1086     c_perez[4]*cos(gamma)*cos(gamma) );
1087     }
1088
1089
1090
1091     /* coefficients for the sky luminance perez model */
1092     void coeff_lum_perez(double Z, double epsilon, double Delta, float *coeff_perez)
1093     {
1094     float x[5][4];
1095     int i,j,num_lin;
1096
1097     if ( (epsilon < skyclearinf) || (epsilon >= skyclearsup) )
1098     {
1099     fprintf(stderr,"Epsilon out of range in function calc_rel_lum_perez !\n");
1100     exit(1);
1101     }
1102
1103     /* correction du modele de Perez solar energy ...*/
1104     if ( (epsilon > 1.065) && (epsilon < 2.8) )
1105     {
1106     if ( Delta < 0.2 ) Delta = 0.2;
1107     }
1108
1109     if ( (epsilon >= 1.000) && (epsilon < 1.065) ) num_lin = 0;
1110     if ( (epsilon >= 1.065) && (epsilon < 1.230) ) num_lin = 1;
1111     if ( (epsilon >= 1.230) && (epsilon < 1.500) ) num_lin = 2;
1112     if ( (epsilon >= 1.500) && (epsilon < 1.950) ) num_lin = 3;
1113     if ( (epsilon >= 1.950) && (epsilon < 2.800) ) num_lin = 4;
1114     if ( (epsilon >= 2.800) && (epsilon < 4.500) ) num_lin = 5;
1115     if ( (epsilon >= 4.500) && (epsilon < 6.200) ) num_lin = 6;
1116     if ( (epsilon >= 6.200) && (epsilon < 14.00) ) num_lin = 7;
1117
1118     for (i=0;i<5;i++)
1119     for (j=0;j<4;j++)
1120     {
1121     x[i][j] = *(coeff_perez + 20*num_lin + 4*i +j);
1122     /* printf("x %d %d vaut %f\n",i,j,x[i][j]); */
1123     }
1124
1125
1126     if (num_lin)
1127     {
1128     for (i=0;i<5;i++)
1129     *(c_perez+i) = x[i][0] + x[i][1]*Z + Delta * (x[i][2] + x[i][3]*Z);
1130
1131     }
1132     else
1133     {
1134     *(c_perez+0) = x[0][0] + x[0][1]*Z + Delta * (x[0][2] + x[0][3]*Z);
1135     *(c_perez+1) = x[1][0] + x[1][1]*Z + Delta * (x[1][2] + x[1][3]*Z);
1136     *(c_perez+4) = x[4][0] + x[4][1]*Z + Delta * (x[4][2] + x[4][3]*Z);
1137     *(c_perez+2) = exp( pow(Delta*(x[2][0]+x[2][1]*Z),x[2][2])) - x[2][3];
1138     *(c_perez+3) = -exp( Delta*(x[3][0]+x[3][1]*Z) )+x[3][2]+Delta*x[3][3];
1139
1140
1141     }
1142
1143
1144     return;
1145     }
1146
1147
1148     /* degrees into radians */
1149     double radians(double degres)
1150     {
1151 greg 2.7 return degres*PI/180.0;
1152 greg 2.1 }
1153
1154     /* radian into degrees */
1155     double degres(double radians)
1156     {
1157 greg 2.7 return radians/PI*180.0;
1158 greg 2.1 }
1159
1160     /* calculation of the angles dzeta and gamma */
1161     void theta_phi_to_dzeta_gamma(double theta,double phi,double *dzeta,double *gamma, double Z)
1162     {
1163     *dzeta = theta; /* dzeta = phi */
1164     if ( (cos(Z)*cos(theta)+sin(Z)*sin(theta)*cos(phi)) > 1 && (cos(Z)*cos(theta)+sin(Z)*sin(theta)*cos(phi) < 1.1 ) )
1165     *gamma = 0;
1166     else if ( (cos(Z)*cos(theta)+sin(Z)*sin(theta)*cos(phi)) > 1.1 )
1167     {
1168     printf("error in calculation of gamma (angle between point and sun");
1169     exit(3);
1170     }
1171     else
1172     *gamma = acos(cos(Z)*cos(theta)+sin(Z)*sin(theta)*cos(phi));
1173     }
1174
1175
1176     /********************************************************************************/
1177     /* Fonction: theta_ordered */
1178     /* */
1179     /* In: char *filename */
1180     /* */
1181     /* Out: float * */
1182     /* */
1183     /* Update: 29/08/93 */
1184     /* */
1185     /* Rem: theta en degres */
1186     /* */
1187     /* But: fournit les valeurs de theta du fichier d'entree a la memoire */
1188     /* */
1189     /********************************************************************************/
1190     float *theta_ordered(char *filename)
1191     {
1192     int i;
1193     float buffer,*ptr;
1194     FILE *file_in;
1195
1196     if ( (file_in = frlibopen(filename)) == NULL )
1197     {
1198     fprintf(stderr,"Cannot open file %s in function theta_ordered\n",filename);
1199     exit(1);
1200     }
1201 greg 2.2
1202     skip_comments(file_in);
1203 greg 2.1
1204     if ( (ptr = malloc(145*sizeof(float))) == NULL )
1205     {
1206     fprintf(stderr,"Out of memory in function theta_ordered\n");
1207     exit(1);
1208     }
1209
1210     for (i=0;i<145;i++)
1211     {
1212     fscanf(file_in,"%f",&buffer);
1213     *(ptr+i) = buffer;
1214     fscanf(file_in,"%f",&buffer);
1215     }
1216
1217     fclose(file_in);
1218     return ptr;
1219     }
1220
1221
1222     /********************************************************************************/
1223     /* Fonction: phi_ordered */
1224     /* */
1225     /* In: char *filename */
1226     /* */
1227     /* Out: float * */
1228     /* */
1229     /* Update: 29/08/93 */
1230     /* */
1231     /* Rem: valeurs de Phi en DEGRES */
1232     /* */
1233     /* But: mettre les angles contenus dans le fichier d'entree dans la memoire */
1234     /* */
1235     /********************************************************************************/
1236     float *phi_ordered(char *filename)
1237     {
1238     int i;
1239     float buffer,*ptr;
1240     FILE *file_in;
1241
1242     if ( (file_in = frlibopen(filename)) == NULL )
1243     {
1244     fprintf(stderr,"Cannot open file %s in function phi_ordered\n",filename);
1245     exit(1);
1246     }
1247 greg 2.2
1248     skip_comments(file_in);
1249 greg 2.1
1250     if ( (ptr = malloc(145*sizeof(float))) == NULL )
1251     {
1252     fprintf(stderr,"Out of memory in function phi_ordered");
1253     exit(1);
1254     }
1255
1256     for (i=0;i<145;i++)
1257     {
1258     fscanf(file_in,"%f",&buffer);
1259     fscanf(file_in,"%f",&buffer);
1260     *(ptr+i) = buffer;
1261     }
1262
1263     fclose(file_in);
1264     return ptr;
1265     }
1266
1267
1268     /********************************************************************************/
1269     /* Fonction: integ_lv */
1270     /* */
1271     /* In: float *lv,*theta */
1272     /* int sun_pos */
1273     /* */
1274     /* Out: double */
1275     /* */
1276     /* Update: 29/08/93 */
1277     /* */
1278     /* Rem: */
1279     /* */
1280     /* But: calcul l'integrale de luminance relative sans la dir. du soleil */
1281     /* */
1282     /********************************************************************************/
1283     double integ_lv(float *lv,float *theta)
1284     {
1285     int i;
1286     double buffer=0.0;
1287
1288     for (i=0;i<145;i++)
1289     buffer += (*(lv+i))*cos(radians(*(theta+i)));
1290
1291 greg 2.7 return buffer*2*PI/144;
1292 greg 2.1
1293     }
1294
1295
1296
1297
1298
1299
1300     /* enter day number(double), return E0 = square(R0/R): eccentricity correction factor */
1301
1302     double get_eccentricity()
1303     {
1304     double day_angle;
1305     double E0;
1306
1307 greg 2.7 day_angle = 2*PI*(daynumber - 1)/365;
1308 greg 2.1 E0 = 1.00011+0.034221*cos(day_angle)+0.00128*sin(day_angle)+
1309     0.000719*cos(2*day_angle)+0.000077*sin(2*day_angle);
1310
1311     return (E0);
1312
1313     }
1314
1315
1316     /* enter sunzenith angle (degrees) return relative air mass (double) */
1317     double air_mass()
1318     {
1319     double m;
1320
1321     if (sunzenith>90)
1322     {
1323     fprintf(stderr, "solar zenith angle larger than 90� in fuction air_mass():\n the models used are not more valid\n");
1324     exit(1);
1325     }
1326
1327 greg 2.7 m = 1/( cos(sunzenith*PI/180)+0.15*exp( log(93.885-sunzenith)*(-1.253) ) );
1328 greg 2.1 return(m);
1329     }
1330
1331
1332     double get_angle_sun_direction(double sun_zenith, double sun_azimut, double direction_zenith, double direction_azimut)
1333
1334     {
1335
1336     double angle;
1337
1338
1339     if (sun_zenith == 0)
1340     puts("WARNING: zenith_angle = 0 in function get_angle_sun_vert_plan");
1341
1342 greg 2.7 angle = acos( cos(sun_zenith*PI/180)*cos(direction_zenith*PI/180) + sin(sun_zenith*PI/180)*sin(direction_zenith*PI/180)*cos((sun_azimut-direction_azimut)*PI/180) );
1343     angle = angle*180/PI;
1344 greg 2.1 return(angle);
1345     }
1346
1347
1348
1349
1350
1351
1352
1353
