root/radiance/ray/src/gen/gencat.c
Revision: 2.5
Committed: Sun Nov 16 10:29:38 2003 UTC (21 years, 6 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
2 static const char RCSid[] = "$Id: gencat.c,v 2.4 2003/06/08 12:03:09 schorsch Exp $";
4 /*****************************************************************************
5 This program is to make series of right triangles forming hyperbolic cosin
6 (ie, cosh) curve in between of 2 points.
7 ^
8 f(h)|
9 |
10 | 0\ pc:(hc, fc)
11 | | \
12 | | \
13 | | \
14 | pa:(ha, fa) 0-------------0 pb:(hb, fb)
15 |
16 0------------------------------------------------> h
17
18 Given arguments:
19 material
20 name
21 (x0, y0, z0), (x1, y1, z1)
22 k const. value K
23 d distant length desired between 2 points
24
25 ******************************************************************************/
26
27 #include <stdio.h>
28 #include <stdlib.h>
29 #include <math.h>
30
31 char *cmtype, *cname;
32 double z0, z1;
33 double k, D;
34 double d;
35 double z, h;
36
37 #ifdef notdef
38 double Newton( b)
39 double b;
40 {
41 if (fabs(cosh(k*D+b)-cosh(b)-(z1-z0)/k) < .001)
42 return (b);
43 else {
44 b = b - (cosh(k*D+b)-cosh(b)-(z1-z0)/k)/(sinh(k*D+b)-sinh(b));
45 Newton (b);
46 }
47 }
48 #endif
49
50 double Newton(bl)
51 double bl;
52 {
53 double b;
54 int n = 10000;
55
56 while (n--) {
57 b = bl- (cosh(k*D+bl)-cosh(bl)-(z1-z0)/k)/(sinh(k*D+bl)-sinh(bl));
58 if (fabs(b-bl) < .00001)
59 return(b);
60 bl = b;
61 }
62 fprintf(stderr, "Interation limit exceeded -- invalid K value\n");
63 exit(1);
64 }
65
66
67 static void
68 printhead(ac, av) /* print command header */
69 register int ac;
70 register char **av;
71 {
72 putchar('#');
73 while (ac--) {
74 putchar(' ');
75 fputs(*av++, stdout);
76 }
77 putchar('\n');
78 }
79
80 int
81 main (argc, argv)
82 int argc;
83 char *argv[];
84 {
85 double x0, y0;
86 double x1, y1;
87 double b;
88 double delh;
89 double f, fprim;
90 double hb, hc, fb, fc;
91 int n;
92
93 if (argc != 11) {
94 fprintf(stderr, "Usage: gencat material name x0 y0 z0 x1 y1 z1 k d\n");
95 exit(1);
96 }
97
98 cmtype = argv[1];
99 cname = argv[2];
100 x0 = atof(argv[3]); y0 = atof(argv[4]); z0 = atof(argv[5]);
101 x1 = atof(argv[6]); y1 = atof(argv[7]); z1 = atof(argv[8]);
102 k = atof(argv[9]); d = atof(argv[10]);
103 D = sqrt((x1-x0)*(x1-x0) + (y1-y0)*(y1-y0));
104 b = Newton(0.0);
105 z = z0 - k * cosh(b);
106 printhead(argc, argv);
107
108 n = 0;
109 for (h=0; h<=D; ) {
110 f = k * cosh(k*h+b) + z;
111 fprim = k* k * sinh(k*h+b);
112 delh = d / sqrt(1+fprim*fprim);
113 fprim = k * k * sinh(k*(h+delh/2)+b);
114 hb = sqrt(.01*fprim*fprim/(1+fprim*fprim));
115 fb = sqrt(.01/(1+(fprim*fprim)));
116 hc = sqrt(.04/(1+fprim*fprim));
117 fc = sqrt(.04*fprim*fprim/(1+fprim*fprim));
118
119 printf("\n%s polygon %s.%d\n", cmtype, cname, ++n);
120 printf("0\n0\n9\n");
121 printf("%f %f %f\n", h*(x1-x0)/D+x0, h*(y1-y0)/D+y0, f);
122 if (fprim < 0)
123 {
124 printf("%f %f %f\n", (h+hc)*(x1-x0)/D+x0, (h+hc)*(y1-y0)/D+y0, f-fc);
125 printf("%f %f %f\n", (h+hb)*(x1-x0)/D+x0, (h+hb)*(y1-y0)/D+y0, f+fb);
126 }
127 else if (fprim > 0)
128 {
129 printf("%f %f %f\n", (h+hc)*(x1-x0)/D+x0, (h+hc)*(y1-y0)/D+y0, f+fc);
130 printf("%f %f %f\n", (h-hb)*(x1-x0)/D+x0, (h-hb)*(y1-y0)/D+y0, f+fb);
131 }
132 else
133 {
134 printf("%f %f %f\n", (h+.2)*(x1-x0)/D+x0, (h+.2)*(y1-y0)/D+y0, f);
135 printf("%f %f %f\n", h*(x1-x0)/D+x0, h*(y1-y0)/D+y0, f+.1);
136 }
137 h += delh;
138 }
139 return 0;
140 }
141
