root/radiance/ray/src/gen/gencat.c
Revision: 2.6
Committed: Thu Sep 20 21:28:35 2007 UTC (17 years, 10 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R1, rad4R0, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 2.5: +3 -2 lines
Fixed usage message
2 static const char RCSid[] = "$Id: gencat.c,v 2.5 2003/11/16 10:29:38 schorsch Exp $";
4 /*****************************************************************************
5 This program is to make series of right triangles forming hyperbolic cosin
6 (ie, cosh) curve in between of 2 points.
7 ^
8 f(h)|
9 |
10 | 0\ pc:(hc, fc)
11 | | \
12 | | \
13 | | \
14 | pa:(ha, fa) 0-------------0 pb:(hb, fb)
15 |
16 0------------------------------------------------> h
17
18 Given arguments:
19 material
20 name
21 (x0, y0, z0), (x1, y1, z1)
22 k const. value K
23 d distant length desired between 2 points
24
25 ******************************************************************************/
26
27 #include <stdio.h>
28 #include <stdlib.h>
29 #include <math.h>
30
31 char *cmtype, *cname;
32 double z0, z1;
33 double k, D;
34 double d;
35 double z, h;
36
37 #ifdef notdef
38 double Newton( b)
39 double b;
40 {
41 if (fabs(cosh(k*D+b)-cosh(b)-(z1-z0)/k) < .001)
42 return (b);
43 else {
44 b = b - (cosh(k*D+b)-cosh(b)-(z1-z0)/k)/(sinh(k*D+b)-sinh(b));
45 Newton (b);
46 }
47 }
48 #endif
49
50 double Newton(bl)
51 double bl;
52 {
53 double b;
54 int n = 10000;
55
56 while (n--) {
57 b = bl- (cosh(k*D+bl)-cosh(bl)-(z1-z0)/k)/(sinh(k*D+bl)-sinh(bl));
58 if (fabs(b-bl) < .00001)
59 return(b);
60 bl = b;
61 }
62 fprintf(stderr, "Interation limit exceeded -- invalid K value\n");
63 exit(1);
64 }
65
66
67 static void
68 printhead(ac, av) /* print command header */
69 register int ac;
70 register char **av;
71 {
72 putchar('#');
73 while (ac--) {
74 putchar(' ');
75 fputs(*av++, stdout);
76 }
77 putchar('\n');
78 }
79
80 int
81 main (argc, argv)
82 int argc;
83 char *argv[];
84 {
85 double x0, y0;
86 double x1, y1;
87 double b;
88 double delh;
89 double f, fprim;
90 double hb, hc, fb, fc;
91 int n;
92
93 if (argc != 11) {
94 fprintf(stderr, "Usage: %s material name x0 y0 z0 x1 y1 z1 k d\n",
95 argv[0]);
96 exit(1);
97 }
98
99 cmtype = argv[1];
100 cname = argv[2];
101 x0 = atof(argv[3]); y0 = atof(argv[4]); z0 = atof(argv[5]);
102 x1 = atof(argv[6]); y1 = atof(argv[7]); z1 = atof(argv[8]);
103 k = atof(argv[9]); d = atof(argv[10]);
104 D = sqrt((x1-x0)*(x1-x0) + (y1-y0)*(y1-y0));
105 b = Newton(0.0);
106 z = z0 - k * cosh(b);
107 printhead(argc, argv);
108
109 n = 0;
110 for (h=0; h<=D; ) {
111 f = k * cosh(k*h+b) + z;
112 fprim = k* k * sinh(k*h+b);
113 delh = d / sqrt(1+fprim*fprim);
114 fprim = k * k * sinh(k*(h+delh/2)+b);
115 hb = sqrt(.01*fprim*fprim/(1+fprim*fprim));
116 fb = sqrt(.01/(1+(fprim*fprim)));
117 hc = sqrt(.04/(1+fprim*fprim));
118 fc = sqrt(.04*fprim*fprim/(1+fprim*fprim));
119
120 printf("\n%s polygon %s.%d\n", cmtype, cname, ++n);
121 printf("0\n0\n9\n");
122 printf("%f %f %f\n", h*(x1-x0)/D+x0, h*(y1-y0)/D+y0, f);
123 if (fprim < 0)
124 {
125 printf("%f %f %f\n", (h+hc)*(x1-x0)/D+x0, (h+hc)*(y1-y0)/D+y0, f-fc);
126 printf("%f %f %f\n", (h+hb)*(x1-x0)/D+x0, (h+hb)*(y1-y0)/D+y0, f+fb);
127 }
128 else if (fprim > 0)
129 {
130 printf("%f %f %f\n", (h+hc)*(x1-x0)/D+x0, (h+hc)*(y1-y0)/D+y0, f+fc);
131 printf("%f %f %f\n", (h-hb)*(x1-x0)/D+x0, (h-hb)*(y1-y0)/D+y0, f+fb);
132 }
133 else
134 {
135 printf("%f %f %f\n", (h+.2)*(x1-x0)/D+x0, (h+.2)*(y1-y0)/D+y0, f);
136 printf("%f %f %f\n", h*(x1-x0)/D+x0, h*(y1-y0)/D+y0, f+.1);
137 }
138 h += delh;
139 }
140 return 0;
141 }
142
