root/radiance/ray/src/gen/genbox.c
Thu Apr 15 23:51:04 2021 UTC (3 years ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.12: +8 -2 lines
Diff to previous 2.12
Fri Apr 9 18:52:57 2021 UTC (3 years ago) by greg
perf: removed unnecessary call for non-round edges and .OBJ output
Fri Apr 9 01:48:20 2021 UTC (3 years ago) by greg
Changes since 2.10: +246 -38 lines
feat(genbox): Added polygonal modeling of rounded edges and -o option for .OBJ
Thu Apr 8 15:13:08 2021 UTC (3 years ago) by greg
Changes since 2.9: +10 -24 lines
perf(genbox): Simplified method for normal inversion
Wed Apr 7 21:13:52 2021 UTC (3 years ago) by greg
Changes since 2.8: +20 -14 lines
fix(genbox): minor changes and fixing "rounde" in comments and usage
Sat Jul 25 19:18:01 2020 UTC (3 years, 9 months ago) by greg
Changes since 2.7: +13 -35 lines
fix(genbox, genprism, gensky): normalizing headers for Windows
Sun Nov 16 10:29:38 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 2.6: +4 -1 lines
Sun Jun 8 12:03:09 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.5: +94 -88 lines
Changes since 2.4: +10 -15 lines
Mon Aug 2 14:22:59 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.3: +4 -0 lines
added conditional declaration of atof()
Fri Jun 4 14:29:58 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.2: +2 -3 lines
Removed unnecessary declaration of atof()
Thu Dec 19 15:08:16 1991 UTC (32 years, 4 months ago) by greg
Tue Nov 12 17:04:38 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.1: +0 -0 lines
Diff to previous 1.1
Thu Feb 2 11:16:26 1989 UTC (35 years, 3 months ago) by greg
