| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: genbox.c,v 2.7 2003/11/16 10:29:38 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* genbox.c - generate a parallelepiped.
| 6 |
| 7 |
* 1/8/86
| 8 |
| 9 |
| 10 |
#include "rtio.h"
| 11 |
#include <stdlib.h>
| 12 |
#include <math.h>
| 13 |
| 14 |
| 15 |
char let[]="0123456789._ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz";
| 16 |
| 17 |
char *cmtype; /* ppd material type */
| 18 |
| 19 |
char *cname; /* ppd name */
| 20 |
| 21 |
double size[3]; /* ppd size */
| 22 |
| 23 |
double bevel = 0.0; /* bevel amount */
| 24 |
| 25 |
int rounde = 0; /* boolean true for rounde edges */
| 26 |
| 27 |
int reverse = 0; /* boolean true for reversed normals */
| 28 |
| 29 |
| 30 |
| 31 |
static void
| 32 |
vertex(int v)
| 33 |
| 34 |
register int i;
| 35 |
| 36 |
for (i = 0; i < 3; i++) {
| 37 |
if (v & 010)
| 38 |
printf("\t%18.12g", v & 01 ? size[i]-bevel : bevel);
| 39 |
else
| 40 |
printf("\t%18.12g", v & 01 ? size[i] : 0.0);
| 41 |
v >>= 1;
| 42 |
| 43 |
printf("\n");
| 44 |
| 45 |
| 46 |
| 47 |
static void
| 48 |
side(int a, int b, int c, int d) /* generate a rectangular face */
| 49 |
| 50 |
printf("\n%s polygon %s.%c%c%c%c\n", cmtype, cname,
| 51 |
let[a], let[b], let[c], let[d]);
| 52 |
printf("0\n0\n12\n");
| 53 |
if (reverse) {
| 54 |
vertex(d);
| 55 |
vertex(c);
| 56 |
vertex(b);
| 57 |
vertex(a);
| 58 |
} else {
| 59 |
vertex(a);
| 60 |
vertex(b);
| 61 |
vertex(c);
| 62 |
vertex(d);
| 63 |
| 64 |
| 65 |
| 66 |
| 67 |
static void
| 68 |
corner(int a, int b, int c) /* generate a triangular face */
| 69 |
| 70 |
printf("\n%s polygon %s.%c%c%c\n", cmtype, cname,
| 71 |
let[a], let[b], let[c]);
| 72 |
printf("0\n0\n9\n");
| 73 |
if (reverse) {
| 74 |
vertex(c);
| 75 |
vertex(b);
| 76 |
vertex(a);
| 77 |
} else {
| 78 |
vertex(a);
| 79 |
vertex(b);
| 80 |
vertex(c);
| 81 |
| 82 |
| 83 |
| 84 |
| 85 |
static void
| 86 |
cylinder(int v0, int v1) /* generate a cylinder */
| 87 |
| 88 |
printf("\n%s cylinder %s.%c%c\n", cmtype, cname, v0+'0', v1+'0');
| 89 |
printf("0\n0\n7\n");
| 90 |
vertex(v0);
| 91 |
vertex(v1);
| 92 |
printf("\t%18.12g\n", bevel);
| 93 |
| 94 |
| 95 |
| 96 |
static void
| 97 |
sphere(int v0) /* generate a sphere */
| 98 |
| 99 |
printf("\n%s sphere %s.%c\n", cmtype, cname, v0+'0');
| 100 |
printf("0\n0\n4\n");
| 101 |
vertex(v0);
| 102 |
| 103 |
| 104 |
| 105 |
| 106 |
int
| 107 |
main(int argc, char **argv)
| 108 |
| 109 |
int i;
| 110 |
| 111 |
if (argc < 6)
| 112 |
goto userr;
| 113 |
| 114 |
cmtype = argv[1];
| 115 |
cname = argv[2];
| 116 |
size[0] = atof(argv[3]);
| 117 |
size[1] = atof(argv[4]);
| 118 |
size[2] = atof(argv[5]);
| 119 |
| 120 |
for (i = 6; i < argc; i++) {
| 121 |
if (argv[i][0] != '-')
| 122 |
goto userr;
| 123 |
switch (argv[i][1]) {
| 124 |
case 'r':
| 125 |
rounde = 1;
| 126 |
/* fall through */
| 127 |
case 'b':
| 128 |
bevel = atof(argv[++i]);
| 129 |
break;
| 130 |
case 'i':
| 131 |
reverse = 1;
| 132 |
break;
| 133 |
default:
| 134 |
goto userr;
| 135 |
| 136 |
| 137 |
| 138 |
fputs("# ", stdout);
| 139 |
printargs(argc, argv, stdout);
| 140 |
| 141 |
if (bevel > 0.0) {
| 142 |
/* minor faces */
| 143 |
side(051, 055, 054, 050);
| 144 |
side(064, 066, 062, 060);
| 145 |
side(032, 033, 031, 030);
| 146 |
side(053, 052, 056, 057);
| 147 |
side(065, 061, 063, 067);
| 148 |
side(036, 034, 035, 037);
| 149 |
| 150 |
if (bevel > 0.0 && !rounde) {
| 151 |
/* bevel faces */
| 152 |
side(031, 051, 050, 030);
| 153 |
side(060, 062, 032, 030);
| 154 |
side(050, 054, 064, 060);
| 155 |
side(034, 036, 066, 064);
| 156 |
side(037, 057, 056, 036);
| 157 |
side(052, 062, 066, 056);
| 158 |
side(052, 053, 033, 032);
| 159 |
side(057, 067, 063, 053);
| 160 |
side(061, 031, 033, 063);
| 161 |
side(065, 067, 037, 035);
| 162 |
side(055, 051, 061, 065);
| 163 |
side(034, 054, 055, 035);
| 164 |
/* bevel corners */
| 165 |
corner(030, 050, 060);
| 166 |
corner(051, 031, 061);
| 167 |
corner(032, 062, 052);
| 168 |
corner(064, 054, 034);
| 169 |
corner(036, 056, 066);
| 170 |
corner(065, 035, 055);
| 171 |
corner(053, 063, 033);
| 172 |
corner(037, 067, 057);
| 173 |
| 174 |
if (bevel > 0.0 && rounde) {
| 175 |
/* rounde edges */
| 176 |
cylinder(070, 071);
| 177 |
cylinder(070, 074);
| 178 |
cylinder(070, 072);
| 179 |
cylinder(073, 071);
| 180 |
cylinder(073, 072);
| 181 |
cylinder(073, 077);
| 182 |
cylinder(075, 071);
| 183 |
cylinder(075, 074);
| 184 |
cylinder(075, 077);
| 185 |
cylinder(076, 072);
| 186 |
cylinder(076, 074);
| 187 |
cylinder(076, 077);
| 188 |
/* rounde corners */
| 189 |
sphere(070);
| 190 |
sphere(071);
| 191 |
sphere(072);
| 192 |
sphere(073);
| 193 |
sphere(074);
| 194 |
sphere(075);
| 195 |
sphere(076);
| 196 |
sphere(077);
| 197 |
| 198 |
if (bevel == 0.0 ) {
| 199 |
/* only need major faces */
| 200 |
side(1, 5, 4, 0);
| 201 |
side(4, 6, 2, 0);
| 202 |
side(2, 3, 1, 0);
| 203 |
side(3, 2, 6, 7);
| 204 |
side(5, 1, 3, 7);
| 205 |
side(6, 4, 5, 7);
| 206 |
| 207 |
return(0);
| 208 |
userr:
| 209 |
fprintf(stderr, "Usage: %s ", argv[0]);
| 210 |
fprintf(stderr, "material name xsize ysize zsize ");
| 211 |
fprintf(stderr, "[-i] [-b bevel | -r rounde]\n");
| 212 |
return(1);
| 213 |
| 214 |
