root/radiance/ray/src/gen/genbox.c
Revision: 2.6
Committed: Sun Jun 8 12:03:09 2003 UTC (21 years ago) by schorsch
Changes since 2.5: +94 -88 lines
2 static const char RCSid[] = "$Id: genbox.c,v 2.5 2003/02/22 02:07:23 greg Exp $";
5 * genbox.c - generate a parallelepiped.
6 *
7 * 1/8/86
8 */
9
10 #include <stdio.h>
11
12 #include <stdlib.h>
13
14 #include <math.h>
15
16
17 char let[]="0123456789._ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz";
18
19 char *cmtype; /* ppd material type */
20
21 char *cname; /* ppd name */
22
23 double size[3]; /* ppd size */
24
25 double bevel = 0.0; /* bevel amount */
26
27 int rounde = 0; /* boolean true for rounde edges */
28
29 int reverse = 0; /* boolean true for reversed normals */
30
31
32
33 static void
34 vertex(v)
35 register int v;
36 {
37 register int i;
38
39 for (i = 0; i < 3; i++) {
40 if (v & 010)
41 printf("\t%18.12g", v & 01 ? size[i]-bevel : bevel);
42 else
43 printf("\t%18.12g", v & 01 ? size[i] : 0.0);
44 v >>= 1;
45 }
46 printf("\n");
47 }
48
49
50 static void
51 side(a, b, c, d) /* generate a rectangular face */
52 int a, b, c, d;
53 {
54 printf("\n%s polygon %s.%c%c%c%c\n", cmtype, cname,
55 let[a], let[b], let[c], let[d]);
56 printf("0\n0\n12\n");
57 if (reverse) {
58 vertex(d);
59 vertex(c);
60 vertex(b);
61 vertex(a);
62 } else {
63 vertex(a);
64 vertex(b);
65 vertex(c);
66 vertex(d);
67 }
68 }
69
70
71 static void
72 corner(a, b, c) /* generate a triangular face */
73 int a, b, c;
74 {
75 printf("\n%s polygon %s.%c%c%c\n", cmtype, cname,
76 let[a], let[b], let[c]);
77 printf("0\n0\n9\n");
78 if (reverse) {
79 vertex(c);
80 vertex(b);
81 vertex(a);
82 } else {
83 vertex(a);
84 vertex(b);
85 vertex(c);
86 }
87 }
88
89
90 static void
91 cylinder(v0, v1) /* generate a cylinder */
92 int v0, v1;
93 {
94 printf("\n%s cylinder %s.%c%c\n", cmtype, cname, v0+'0', v1+'0');
95 printf("0\n0\n7\n");
96 vertex(v0);
97 vertex(v1);
98 printf("\t%18.12g\n", bevel);
99 }
100
101
102 sphere(v0) /* generate a sphere */
103 int v0;
104 {
105 printf("\n%s sphere %s.%c\n", cmtype, cname, v0+'0');
106 printf("0\n0\n4\n");
107 vertex(v0);
108 printf("\t%18.12g\n", bevel);
109 }
110
111
112 printhead(ac, av) /* print command header */
113 register int ac;
114 register char **av;
115 {
116 putchar('#');
117 while (ac--) {
118 putchar(' ');
119 fputs(*av++, stdout);
120 }
121 putchar('\n');
122 }
123
124
125 main(argc, argv)
126 int argc;
127 char **argv;
128 {
129 int i;
130
131 if (argc < 6)
132 goto userr;
133
134 cmtype = argv[1];
135 cname = argv[2];
136 size[0] = atof(argv[3]);
137 size[1] = atof(argv[4]);
138 size[2] = atof(argv[5]);
139
140 for (i = 6; i < argc; i++) {
141 if (argv[i][0] != '-')
142 goto userr;
143 switch (argv[i][1]) {
144 case 'r':
145 rounde = 1;
146 /* fall through */
147 case 'b':
148 bevel = atof(argv[++i]);
149 break;
150 case 'i':
151 reverse = 1;
152 break;
153 default:
154 goto userr;
155 }
156 }
157
158 printhead(argc, argv);
159
160 if (bevel > 0.0) {
161 /* minor faces */
162 side(051, 055, 054, 050);
163 side(064, 066, 062, 060);
164 side(032, 033, 031, 030);
165 side(053, 052, 056, 057);
166 side(065, 061, 063, 067);
167 side(036, 034, 035, 037);
168 }
169 if (bevel > 0.0 && !rounde) {
170 /* bevel faces */
171 side(031, 051, 050, 030);
172 side(060, 062, 032, 030);
173 side(050, 054, 064, 060);
174 side(034, 036, 066, 064);
175 side(037, 057, 056, 036);
176 side(052, 062, 066, 056);
177 side(052, 053, 033, 032);
178 side(057, 067, 063, 053);
179 side(061, 031, 033, 063);
180 side(065, 067, 037, 035);
181 side(055, 051, 061, 065);
182 side(034, 054, 055, 035);
183 /* bevel corners */
184 corner(030, 050, 060);
185 corner(051, 031, 061);
186 corner(032, 062, 052);
187 corner(064, 054, 034);
188 corner(036, 056, 066);
189 corner(065, 035, 055);
190 corner(053, 063, 033);
191 corner(037, 067, 057);
192 }
193 if (bevel > 0.0 && rounde) {
194 /* rounde edges */
195 cylinder(070, 071);
196 cylinder(070, 074);
197 cylinder(070, 072);
198 cylinder(073, 071);
199 cylinder(073, 072);
200 cylinder(073, 077);
201 cylinder(075, 071);
202 cylinder(075, 074);
203 cylinder(075, 077);
204 cylinder(076, 072);
205 cylinder(076, 074);
206 cylinder(076, 077);
207 /* rounde corners */
208 sphere(070);
209 sphere(071);
210 sphere(072);
211 sphere(073);
212 sphere(074);
213 sphere(075);
214 sphere(076);
215 sphere(077);
216 }
217 if (bevel == 0.0 ) {
218 /* only need major faces */
219 side(1, 5, 4, 0);
220 side(4, 6, 2, 0);
221 side(2, 3, 1, 0);
222 side(3, 2, 6, 7);
223 side(5, 1, 3, 7);
224 side(6, 4, 5, 7);
225 }
226 exit(0);
227 userr:
228 fprintf(stderr, "Usage: %s ", argv[0]);
229 fprintf(stderr, "material name xsize ysize zsize ");
230 fprintf(stderr, "[-i] [-b bevel | -r rounde]\n");
231 exit(1);
232 }
233
