root/Development/ray/src/gen/genblinds.c
Sat Jun 7 05:09:45 2025 UTC (7 months ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.15 , to selected 2.5
Sat Jul 25 19:23:09 2020 UTC (5 years, 5 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.14: +9 -24 lines
fix(genblinds): normalized header for Windows
Tue Jun 30 18:16:30 2020 UTC (5 years, 6 months ago) by greg
perf(genblinds): decreased maximum step for curved slats from 10 to 3 degrees
Sat Aug 1 23:27:04 2015 UTC (10 years, 5 months ago) by greg
Wed Dec 28 19:42:13 2005 UTC (20 years ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 2.11: +18 -16 lines
Fixed problems with genblinds
Sun Nov 16 10:29:38 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.10: +96 -82 lines
Sun Jun 8 12:03:09 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 2.9: +57 -52 lines
Sat Feb 22 02:07:23 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.8: +2 -8 lines
Tue Feb 21 16:00:55 1995 UTC (30 years, 10 months ago) by greg
fixed degenerate -r case
Mon Oct 10 12:07:45 1994 UTC (31 years, 3 months ago) by greg
changed delta to 10 degrees from 5
Mon Aug 2 14:22:58 1993 UTC (32 years, 5 months ago) by greg
Changes since 2.5: +4 -0 lines
added conditional declaration of atof()
Fri Jun 4 14:29:34 1993 UTC (32 years, 7 months ago) by greg
Changes since 2.4: +0 -4 lines
Removed unnecessary declaration of atof()
Fri Oct 2 16:10:45 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.3: +0 -2 lines
Thu Aug 27 13:51:59 1992 UTC (33 years, 4 months ago) by greg
fixed bug in argument reading for -r and +r
Thu Dec 19 15:07:33 1991 UTC (34 years ago) by greg
Changes since 2.1: +5 -1 lines
Tue Nov 12 17:04:36 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.1: +0 -0 lines
Thu Feb 2 11:16:25 1989 UTC (36 years, 11 months ago) by greg
Diff to selected 2.5
