root/radiance/ray/src/gen/genbackg.csh
Revision: 2.2
Committed: Mon Aug 25 04:50:32 2008 UTC (15 years, 8 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3, HEAD
Changes since 2.1: +16 -12 lines
Made temporary files safe from malicious attackers
# User Rev Content
1 greg 2.1 #!/bin/csh -f
2 greg 2.2 # RCSid: $Id: genbackg.csh,v 2.1 2003/02/22 02:07:23 greg Exp $
3 greg 2.1 #
4     # Generate height field to surround a mesh with an irregular border
5     #
6     # 4/16/2002 Greg Ward
7     #
8     if ( $#argv < 3 ) goto userr
9     # Get arguments
10     set mat = $1
11     set nam = $2
12     set mesh = $3
13     # Get options
14     set smooth=""
15     set i = 4
16     while ( $i <= $#argv )
17     switch ($argv[$i])
18     case -c:
19     @ i++ ; set a=$i
20     @ i++ ; set b=$i
21     @ i++ ; set c=$i
22     set c00=($argv[$a] $argv[$b] $argv[$c])
23     @ i++ ; set a=$i
24     @ i++ ; set b=$i
25     @ i++ ; set c=$i
26     set c01=($argv[$a] $argv[$b] $argv[$c])
27     @ i++ ; set a=$i
28     @ i++ ; set b=$i
29     @ i++ ; set c=$i
30     set c11=($argv[$a] $argv[$b] $argv[$c])
31     @ i++ ; set a=$i
32     @ i++ ; set b=$i
33     @ i++ ; set c=$i
34     set c10=($argv[$a] $argv[$b] $argv[$c])
35     unset a b c
36     breaksw
37     case -r:
38     @ i++
39     set step = $argv[$i]
40     breaksw
41     case -b:
42     @ i++
43     set bord = $argv[$i]
44     breaksw
45     case -s:
46     set smooth="-s"
47     breaksw
48     default:
49     goto userr
50     endsw
51     @ i++
52     end
53     # Get corner points
54     set lim=(`getbbox -h $mesh`)
55     if (! $?bord ) then
56     set bord=`ev "($lim[2]-$lim[1]+$lim[4]-$lim[3])/20"`
57     endif
58     if (! $?c00 ) then
59     set c00=(`ev "$lim[1]-$bord" "$lim[3]-$bord" "($lim[5]+$lim[6])/2"`)
60     set c01=(`ev "$lim[2]+$bord" "$lim[3]-$bord" "($lim[5]+$lim[6])/2"`)
61     set c10=(`ev "$lim[1]-$bord" "$lim[4]+$bord" "($lim[5]+$lim[6])/2"`)
62     set c11=(`ev "$lim[2]+$bord" "$lim[4]+$bord" "($lim[5]+$lim[6])/2"`)
63     endif
64     # Get mesh resolution
65     if (! $?step ) then
66     set step=`ev "sqrt(($c11[1]-$c00[1])*($c11[1]-$c00[1])+($c11[2]-$c00[2])*($c11[2]-$c00[2]))/70"`
67     endif
68     set res=(`ev "ceil(sqrt(($c01[1]-$c00[1])*($c01[1]-$c00[1])+($c01[2]-$c00[2])*($c01[2]-$c00[2]))/$step)" "ceil(sqrt(($c10[1]-$c00[1])*($c10[1]-$c00[1])+($c10[2]-$c00[2])*($c10[2]-$c00[2]))/$step)"`)
69 greg 2.2 set edgef=`mktemp /tmp/edgerad.XXXXXX`
70     cat > $edgef << _EOF_
71 greg 2.1 void sphere c00
72     0 0 4
73     $c00 .001
74     void sphere c01
75     0 0 4
76     $c01 .001
77     void sphere c10
78     0 0 4
79     $c10 .001
80     void sphere c11
81     0 0 4
82     $c11 .001
83     void cylinder ex0
84     0 0 7
85     $c00 $c10 .001
86     void cylinder ex1
87     0 0 7
88     $c01 $c11 .001
89     void cylinder ey0
90     0 0 7
91     $c00 $c01 .001
92     void cylinder ey1
93     0 0 7
94     $c10 $c11 .001
95     _EOF_
96 greg 2.2 set meshcal=`mkdir /tmp/meshcal.XXXXXX`
97     cat > $meshcal << _EOF_
98 greg 2.1 lerp(x,y0,y1):(1-x)*y0+x*y1;
99     and(a,b):if(a,b,-1);
100     or(a,b):if(a,1,b);
101     not(a):if(a,-1,1);
102     max(a,b):if(a-b,a,b);
103     min(a,b):if(a-b,b,a);
104     EPS:1e-7;
105     XR:min(32,floor($res[1]/2));
106     YR:8;
107     eq(a,b):and(a-b+EPS,b-a+EPS);
108     sumfun2x(f,y,x0,x1):if(x1-x0+EPS,f(x0,y)+sumfun2x(f,y,x0+1,x1),0);
109     sumfun2(f,x0,x1,y0,y1):if(y1-y0+EPS,
110     sumfun2x(f,y0,x0,x1)+sumfun2(f,x0,x1,y0+1,y1), 0);
111     xpos(xf,yf)=lerp(xf,lerp(yf,$c00[1],$c10[1]),lerp(yf,$c01[1],$c11[1]));
112     ypos(xf,yf)=lerp(xf,lerp(yf,$c00[2],$c10[2]),lerp(yf,$c01[2],$c11[2]));
113     onedge=or(or(eq(x,0),eq(x,xmax-1)),or(eq(y,0),eq(y,ymax-1)));
114     z0:$lim[5]-$bord;
115     height(xo,yo)=z0+gi(1,xo,yo);
116     maxwt(xo,yo):if(and(eq(xo,0),eq(yo,0)),100,1/(xo*xo+yo*yo));
117     wt(xo,yo)=if(height(xo,yo)-1e9, 0, maxwt(xo,yo));
118     wtv(xo,yo)=wt(xo,yo)*height(xo,yo);
119     wts=sumfun2(wt,-XR,XR,-YR,YR);
120     sum=sumfun2(wtv,-XR,XR,-YR,YR);
121     inmesh=and(not(onedge),eq(sumfun2(wt,-1,1,-1,1),sumfun2(maxwt,-1,1,-1,1)));
122     lo=if(inmesh,1e10,if(wts-EPS,sum/wts,($lim[5]+$lim[6])/2));
123     _EOF_
124     # Generate height image
125 greg 2.2 set meshoct=`/tmp/meshoct.XXXXXXX`
126     xform -m void $mesh | oconv - $edgef > $meshoct
127     set meshpic=`mktemp /tmp/meshpic.XXXXXX`
128 greg 2.1 cnt $res[2] $res[1] \
129     | rcalc -e 'sp=$2/'"($res[1]-1)" -e 'tp=1-$1/'"($res[2]-1)" \
130 greg 2.2 -f $meshcal -e "xp=xpos(sp,tp);yp=ypos(sp,tp)" \
131 greg 2.1 -e '$1=xp;$2=yp;$3=z0;$4=0;$5=0;$6=1' \
132 greg 2.2 | rtrace -w -faf -oL -x $res[1] -y $res[2] $meshoct \
133     | pvalue -r -b -df > $meshpic
134     rm $edgef $meshoct
135 greg 2.1 # Output mesh surround
136     cat << _EOF_
137     # $0 $argv[*]
138     # Corner points:
139     # $c00
140     # $c01
141     # $c11
142     # $c10
143     _EOF_
144 greg 2.2 pflip -v $meshpic \
145     | pcomb -f $meshcal - \
146 greg 2.1 | pvalue -h -H -pG -d \
147     | gensurf $mat $nam 'xpos(s,t)' 'ypos(s,t)' - \
148     `ev $res[1]-1 $res[2]-1` \
149     -e 'valid(xf,yf)=1e9-Z`SYS(xf,yf)' \
150 greg 2.2 -f $meshcal $smooth
151     rm $meshcal $meshpic
152 greg 2.1 # All done -- exit
153     exit 0
154     # Usage error message
155     userr:
156     echo Usage: $0 "mat name mesh_file [-c corners][-b bord_width][-r step_size][-s]"
157     exit 1
