root/radiance/ray/src/gen/genbackg.csh
Revision: 2.1
Committed: Sat Feb 22 02:07:23 2003 UTC (22 years, 3 months ago) by greg
Content type: application/x-csh
CVS Tags: rad3R7P2, rad3R7P1, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9
1 #!/bin/csh -f
2 # RCSid: $Id$
3 #
4 # Generate height field to surround a mesh with an irregular border
5 #
6 # 4/16/2002 Greg Ward
7 #
8 if ( $#argv < 3 ) goto userr
9 # Get arguments
10 set mat = $1
11 set nam = $2
12 set mesh = $3
13 # Get options
14 set smooth=""
15 set i = 4
16 while ( $i <= $#argv )
17 switch ($argv[$i])
18 case -c:
19 @ i++ ; set a=$i
20 @ i++ ; set b=$i
21 @ i++ ; set c=$i
22 set c00=($argv[$a] $argv[$b] $argv[$c])
23 @ i++ ; set a=$i
24 @ i++ ; set b=$i
25 @ i++ ; set c=$i
26 set c01=($argv[$a] $argv[$b] $argv[$c])
27 @ i++ ; set a=$i
28 @ i++ ; set b=$i
29 @ i++ ; set c=$i
30 set c11=($argv[$a] $argv[$b] $argv[$c])
31 @ i++ ; set a=$i
32 @ i++ ; set b=$i
33 @ i++ ; set c=$i
34 set c10=($argv[$a] $argv[$b] $argv[$c])
35 unset a b c
36 breaksw
37 case -r:
38 @ i++
39 set step = $argv[$i]
40 breaksw
41 case -b:
42 @ i++
43 set bord = $argv[$i]
44 breaksw
45 case -s:
46 set smooth="-s"
47 breaksw
48 default:
49 goto userr
50 endsw
51 @ i++
52 end
53 # Get corner points
54 set lim=(`getbbox -h $mesh`)
55 if (! $?bord ) then
56 set bord=`ev "($lim[2]-$lim[1]+$lim[4]-$lim[3])/20"`
57 endif
58 if (! $?c00 ) then
59 set c00=(`ev "$lim[1]-$bord" "$lim[3]-$bord" "($lim[5]+$lim[6])/2"`)
60 set c01=(`ev "$lim[2]+$bord" "$lim[3]-$bord" "($lim[5]+$lim[6])/2"`)
61 set c10=(`ev "$lim[1]-$bord" "$lim[4]+$bord" "($lim[5]+$lim[6])/2"`)
62 set c11=(`ev "$lim[2]+$bord" "$lim[4]+$bord" "($lim[5]+$lim[6])/2"`)
63 endif
64 # Get mesh resolution
65 if (! $?step ) then
66 set step=`ev "sqrt(($c11[1]-$c00[1])*($c11[1]-$c00[1])+($c11[2]-$c00[2])*($c11[2]-$c00[2]))/70"`
67 endif
68 set res=(`ev "ceil(sqrt(($c01[1]-$c00[1])*($c01[1]-$c00[1])+($c01[2]-$c00[2])*($c01[2]-$c00[2]))/$step)" "ceil(sqrt(($c10[1]-$c00[1])*($c10[1]-$c00[1])+($c10[2]-$c00[2])*($c10[2]-$c00[2]))/$step)"`)
69 cat > /tmp/edge$$.rad << _EOF_
70 void sphere c00
71 0 0 4
72 $c00 .001
73 void sphere c01
74 0 0 4
75 $c01 .001
76 void sphere c10
77 0 0 4
78 $c10 .001
79 void sphere c11
80 0 0 4
81 $c11 .001
82 void cylinder ex0
83 0 0 7
84 $c00 $c10 .001
85 void cylinder ex1
86 0 0 7
87 $c01 $c11 .001
88 void cylinder ey0
89 0 0 7
90 $c00 $c01 .001
91 void cylinder ey1
92 0 0 7
93 $c10 $c11 .001
94 _EOF_
95 cat > /tmp/mesh$$.cal << _EOF_
96 lerp(x,y0,y1):(1-x)*y0+x*y1;
97 and(a,b):if(a,b,-1);
98 or(a,b):if(a,1,b);
99 not(a):if(a,-1,1);
100 max(a,b):if(a-b,a,b);
101 min(a,b):if(a-b,b,a);
102 EPS:1e-7;
103 XR:min(32,floor($res[1]/2));
104 YR:8;
105 eq(a,b):and(a-b+EPS,b-a+EPS);
106 sumfun2x(f,y,x0,x1):if(x1-x0+EPS,f(x0,y)+sumfun2x(f,y,x0+1,x1),0);
107 sumfun2(f,x0,x1,y0,y1):if(y1-y0+EPS,
108 sumfun2x(f,y0,x0,x1)+sumfun2(f,x0,x1,y0+1,y1), 0);
109 xpos(xf,yf)=lerp(xf,lerp(yf,$c00[1],$c10[1]),lerp(yf,$c01[1],$c11[1]));
110 ypos(xf,yf)=lerp(xf,lerp(yf,$c00[2],$c10[2]),lerp(yf,$c01[2],$c11[2]));
111 onedge=or(or(eq(x,0),eq(x,xmax-1)),or(eq(y,0),eq(y,ymax-1)));
112 z0:$lim[5]-$bord;
113 height(xo,yo)=z0+gi(1,xo,yo);
114 maxwt(xo,yo):if(and(eq(xo,0),eq(yo,0)),100,1/(xo*xo+yo*yo));
115 wt(xo,yo)=if(height(xo,yo)-1e9, 0, maxwt(xo,yo));
116 wtv(xo,yo)=wt(xo,yo)*height(xo,yo);
117 wts=sumfun2(wt,-XR,XR,-YR,YR);
118 sum=sumfun2(wtv,-XR,XR,-YR,YR);
119 inmesh=and(not(onedge),eq(sumfun2(wt,-1,1,-1,1),sumfun2(maxwt,-1,1,-1,1)));
120 lo=if(inmesh,1e10,if(wts-EPS,sum/wts,($lim[5]+$lim[6])/2));
121 _EOF_
122 # Generate height image
123 xform -m void $mesh | oconv - /tmp/edge$$.rad > /tmp/mesh$$.oct
124 cnt $res[2] $res[1] \
125 | rcalc -e 'sp=$2/'"($res[1]-1)" -e 'tp=1-$1/'"($res[2]-1)" \
126 -f /tmp/mesh$$.cal -e "xp=xpos(sp,tp);yp=ypos(sp,tp)" \
127 -e '$1=xp;$2=yp;$3=z0;$4=0;$5=0;$6=1' \
128 | rtrace -w -faf -oL -x $res[1] -y $res[2] /tmp/mesh$$.oct \
129 | pvalue -r -b -df > /tmp/mesh$$.pic
130 rm /tmp/edge$$.rad /tmp/mesh$$.oct
131 # Output mesh surround
132 cat << _EOF_
133 # $0 $argv[*]
134 # Corner points:
135 # $c00
136 # $c01
137 # $c11
138 # $c10
139 _EOF_
140 pflip -v /tmp/mesh$$.pic \
141 | pcomb -f /tmp/mesh$$.cal - \
142 | pvalue -h -H -pG -d \
143 | gensurf $mat $nam 'xpos(s,t)' 'ypos(s,t)' - \
144 `ev $res[1]-1 $res[2]-1` \
145 -e 'valid(xf,yf)=1e9-Z`SYS(xf,yf)' \
146 -f /tmp/mesh$$.cal $smooth
147 rm /tmp/mesh$$.cal /tmp/mesh$$.pic
148 # All done -- exit
149 exit 0
150 # Usage error message
151 userr:
152 echo Usage: $0 "mat name mesh_file [-c corners][-b bord_width][-r step_size][-s]"
153 exit 1
