1 |
import os
2 |
3 |
Import('env') # inherit from parent
4 |
5 |
# math libs
6 |
mlib = env['RAD_MLIB']
7 |
8 |
#Make sure sun.c is compiled only once
9 |
sun = env.Object(source="sun.c")
10 |
11 |
# standard targets
12 |
PROGS = (
13 |
# name sources libs
14 |
('gendaylit', Split('gendaylit.c',)+[sun], ['rtlamps']),
15 |
('gendaymtx', Split('gendaymtx.c',)+[sun],
16 |
['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror',mlib]),
17 |
('genbeads', Split('genbeads.c hermite3.c'), []),
18 |
('genbox', ['genbox.c',], []),
19 |
('genmarble', ['genmarble.c',], []),
20 |
('gensky', Split('gensky.c',)+[sun], []),
21 |
('genblinds', ['genblinds.c',], []),
22 |
('genprism', ['genprism.c',], []),
23 |
('genrev', ['genrev.c',], ['rtfunc','rtcont','rtmem','rtio','rterror']),
24 |
('gencatenary', ['gencat.c',], []),
25 |
('genworm', ['genworm.c',],
26 |
['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
27 |
('gensurf', ['gensurf.c',],
28 |
29 |
('genclock', ['genclock.c',], []),
30 |
('genbranch', ['genbranch.c',], []),
31 |
('replmarks', ['replmarks.c',],
32 |
['rtproc','rtpath','rtmath','rtio','rterror']),
33 |
('xform', ['xform.c',],
34 |
['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror']),
35 |
36 |
progs = []
37 |
for p in PROGS:
38 |
prog = env.Program(target=os.path.join('$RAD_BUILDBIN', p[0]),
39 |
source=p[1], LIBS=p[2] + mlib)
40 |
progs.append(prog)
41 |
42 |
prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mkillum'),
43 |
source=Split('mkillum.c mkillum2.c mkillum3.c'),
44 |
CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
45 |
LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc',
46 |
'rtnet','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']
47 |
+ mlib)
48 |
progs.append(prog)
49 |
prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mksource'),
50 |
source=['mksource.c'],
51 |
52 |
LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc','rtnet',
53 |
'rtmath','rtcont','rtmem','rtargs','rtio','rtpath','rterror'] + mlib)
54 |
progs.append(prog)
55 |
56 |
if os.name == 'posix':
57 |
Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze'), 'glaze.csh'))
58 |
59 |
Default('#src/gen')
60 |
env.Install('$RAD_BINDIR', progs)
61 |
62 |
#surf.cal clockface.hex
63 |
LIBFILES = Split('''illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal
64 |
perezlum.cal coeff_perez.dat defangle.dat''')
65 |
env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES))
66 |
67 |
# vim: set syntax=python:
