root/radiance/ray/src/gen/SConscript
Revision: 1.1
Committed: Tue Oct 21 19:27:28 2003 UTC (20 years, 7 months ago) by schorsch
1 import os
2
3 Import('env') # inherit from parent
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # standard targets
9 PROGS = (
10 # name sources libs
11 ('genbeads', Split('genbeads.c hermite3.c'), mlib),
12 ('genbox', Split('genbox.c'), mlib),
13 ('genmarble', Split('genmarble.c'), mlib),
14 ('gensky', Split('gensky.c sun.c'), mlib),
15 ('genblinds', Split('genblinds.c'), mlib),
16 ('genprism', Split('genprism.c'), mlib),
17 ('xform', Split('xform.c'), ['rt'] + mlib),
18 ('replmarks', Split('replmarks.c'), ['rt'] + mlib),
19 ('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'), ['rt'] + mlib),
20 ('genvev', Split('genrev.c'), ['rt'] + mlib),
21 ('gencat', Split('gencat.c'), ['rt'] + mlib),
22 ('genworm', Split('genworm.c'), ['rt'] + mlib),
23 ('gensurf', Split('gensurf.c'), ['rt'] + mlib),
24 ('genclock', Split('genclock.c'), mlib),
25 ('genbranch', Split('genbranch.c'), mlib),
26 )
27 for p in PROGS:
28 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
29 source=p[1], LIBS=p[2])
30 Default(prog)
31 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
32
33 #surf.cal clockface.hex
34 LIBFILES = Split('illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal')
35 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
