--- ray/src/gen/SConscript 2016/03/05 00:29:28 1.15 +++ ray/src/gen/SConscript 2018/01/08 13:38:37 1.19 @@ -1,3 +1,5 @@ +from __future__ import division, print_function, unicode_literals + import os Import('env') # inherit from parent @@ -11,29 +13,22 @@ sun = env.Object(source="sun.c") # standard targets PROGS = ( # name sources libs -('gendaylit', Split('gendaylit.c',)+[sun], ['rtlamps']), +('gendaylit', Split('gendaylit.c',)+[sun], ['rtrad']), +('gendaymtx', Split('gendaymtx.c',)+[sun], ['rtrad',mlib]), ('genbeads', Split('genbeads.c hermite3.c'), []), ('genbox', ['genbox.c',], []), ('genmarble', ['genmarble.c',], []), ('gensky', Split('gensky.c',)+[sun], []), ('genblinds', ['genblinds.c',], []), ('genprism', ['genprism.c',], []), -('genrev', ['genrev.c',], ['rtfunc','rtcont','rtmem','rtio','rterror']), +('genrev', ['genrev.c',], ['rtrad',]), ('gencatenary', ['gencat.c',], []), -('genworm', ['genworm.c',], - ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']), -('gensurf', ['gensurf.c',], - ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']), +('genworm', ['genworm.c',], ['rtrad']), +('gensurf', ['gensurf.c',], ['rtrad']), ('genclock', ['genclock.c',], []), ('genbranch', ['genbranch.c',], []), -('replmarks', ['replmarks.c',], - ['rtproc','rtpath','rtmath','rtio','rterror']), -#('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'), -# ['rtproc','rtscene','rtpath','rtmath','rtio','rtcont','rterror']), -#('mksource', ['mksource.c'], -# ['rtio','rtmath','rterror']), -('xform', ['xform.c',], - ['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror']), +('replmarks', ['replmarks.c',], ['rtrad']), +('xform', ['xform.c',], ['rtrad']), ) progs = [] for p in PROGS: @@ -44,25 +39,30 @@ for p in PROGS: prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mkillum'), source=Split('mkillum.c mkillum2.c mkillum3.c'), CPPPATH=env.get('CPPPATH', []) + ['#src/rt'], - LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc', - 'rtnet','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror'] - + mlib) + LIBS=['raycalls','rttrace','rtrad'] + mlib) progs.append(prog) prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mksource'), source=['mksource.c'], CPPPATH=env.get('CPPPATH', []) + ['#src/rt'], - LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc','rtnet', - 'rtmath','rtcont','rtmem','rtargs','rtio','rtpath','rterror'] + mlib) + LIBS=['raycalls','rttrace','rtrad'] + mlib) progs.append(prog) if os.name == 'posix': - Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze'), 'glaze.csh')) + Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze.csh'), + 'glaze.csh')) + Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze'), + 'glaze.py')) +else: + Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze.py'), + 'glaze.py')) Default('#src/gen') env.Install('$RAD_BINDIR', progs) #surf.cal clockface.hex -LIBFILES = Split('illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal perezlum.cal coeff_perez.dat defangle.dat') +LIBFILES = Split('''illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal + perezlum.cal''') env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES)) - +# vim: set syntax=python: +# vi: set ts=4 sw=4 :
