root/Development/ray/src/gen/SConscript
Mon Jan 8 13:38:37 2018 UTC (7 years, 10 months ago) by schorsch
Changes since 1.18: +10 -1 lines
Diff to previous 1.18 , to selected 1.1
Thu Mar 10 21:43:22 2016 UTC (9 years, 8 months ago) by schorsch
Changes since 1.17: +9 -17 lines
Diff to previous 1.17 , to selected 1.1
Thu Mar 10 01:49:56 2016 UTC (9 years, 8 months ago) by schorsch
Diff to previous 1.16 , to selected 1.1
SCons build system learns about platform architecture
Sat Mar 5 13:24:58 2016 UTC (9 years, 8 months ago) by schorsch
Changes since 1.15: +5 -6 lines
Diff to previous 1.15 , to selected 1.1
Sat Mar 5 00:29:28 2016 UTC (9 years, 8 months ago) by schorsch
Changes since 1.14: +3 -3 lines
Diff to previous 1.14 , to selected 1.1
update SCons
Wed Dec 15 21:51:46 2010 UTC (14 years, 11 months ago) by greg
Changes since 1.13: +68 -64 lines
Diff to previous 1.13 , to selected 1.1
Additional fixes for MINGW thanks to Guy Vaessen
Wed Dec 15 01:40:11 2010 UTC (14 years, 11 months ago) by greg
Diff to previous 1.12 , to selected 1.1
Updated SConscript files for compiling under MINGW
Fri Jul 9 15:24:45 2010 UTC (15 years, 4 months ago) by greg
Diff to previous 1.11 , to selected 1.1
Removed duplicate installs and added dctimestep
Wed Oct 7 22:05:42 2009 UTC (16 years, 1 month ago) by schorsch
Changes since 1.10: +1 -4 lines
Diff to previous 1.10 , to selected 1.1
Adapting to move of ezxml.c to common and removal of mkillum4.c.
Sun Apr 27 17:22:48 2008 UTC (17 years, 7 months ago) by schorsch
Diff to previous 1.9 , to selected 1.1
Thu Apr 24 10:28:25 2008 UTC (17 years, 7 months ago) by schorsch
Changes since 1.8: +4 -1 lines
Diff to previous 1.8 , to selected 1.1
Mon Apr 21 07:31:29 2008 UTC (17 years, 7 months ago) by schorsch
Changes since 1.7: +10 -4 lines
Diff to previous 1.7 , to selected 1.1
Scons update for mingw.
Mon Sep 19 12:32:12 2005 UTC (20 years, 2 months ago) by schorsch
Changes since 1.6: +10 -1 lines
Diff to previous 1.6 , to selected 1.1
Added mksource to SCons build, fixed some compile warnings.
Mon Sep 12 14:44:09 2005 UTC (20 years, 2 months ago) by schorsch
Diff to previous 1.5 , to selected 1.1
Updates to SConscripts for 3R7.
Sat Oct 23 18:55:52 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 1.4: +6 -4 lines
Diff to previous 1.4 , to selected 1.1
Thu Oct 21 15:47:12 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 1.3: +10 -3 lines
Diff to previous 1.3 , to selected 1.1
SCons build simplifications.
Thu Jan 1 20:55:42 2004 UTC (21 years, 10 months ago) by schorsch
Changes since 1.2: +16 -16 lines
Diff to previous 1.2 , to selected 1.1
Renamed gencat to gencatenary.
Mon Oct 27 10:35:42 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 1.1: +20 -16 lines
Revision 1.1 - (view) (download) (annotate) - [selected]
Tue Oct 21 19:27:28 2003 UTC (22 years, 1 month ago) by schorsch
