root/Development/ray/src/gen/SConscript
Revision: 1.5
Committed: Sat Oct 23 18:55:52 2004 UTC (20 years, 11 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6P1
Changes since 1.4: +6 -4 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # standard targets
9 PROGS = (
10 # name sources libs
11 ('genbeads', Split('genbeads.c hermite3.c'), []),
12 ('genbox', ['genbox.c',], []),
13 ('genmarble', ['genmarble.c',], []),
14 ('gensky', Split('gensky.c sun.c',), []),
15 ('genblinds', ['genblinds.c',], []),
16 ('genprism', ['genprism.c',], []),
17 ('genrev', ['genrev.c',], ['rtfunc','rtcont','rtmem','rtio','rterror']),
18 ('gencatenary', ['gencat.c',], []),
19 ('genworm', ['genworm.c',],
20 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
21 ('gensurf', ['gensurf.c',],
22 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
23 ('genclock', ['genclock.c',], []),
24 ('genbranch', ['genbranch.c',], []),
25 ('replmarks', ['replmarks.c',],
26 ['rtproc','rtpath','rtmath','rtio','rterror']),
27 ('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'),
28 ['rtproc','rtscene','rtpath','rtmath','rtio','rtcont','rterror']),
29 ('xform', ['xform.c',],
30 ['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror']),
31 )
32 progs = []
33 for p in PROGS:
34 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
35 source=p[1], LIBS=p[2] + mlib)
36 progs.append(prog)
37
38 if os.name == 'posix':
39 Default(env.InstallCsh(os.path.join('$RAD_BUILDBIN', 'glaze'), 'glaze.csh'))
40
41 Default('#src/gen')
42 env.Install('$RAD_BINDIR', progs)
43
44 #surf.cal clockface.hex
45 LIBFILES = Split('illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal')
46 env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES))
47
48
