root/Development/ray/src/gen/SConscript
Revision: 1.4
Committed: Thu Oct 21 15:47:12 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 1.3: +10 -3 lines
SCons build simplifications.
1 import os
2
3 Import('env') # inherit from parent
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # standard targets
9 PROGS = (
10 # name sources libs
11 ('genbeads', Split('genbeads.c hermite3.c'), []),
12 ('genbox', ['genbox.c',], []),
13 ('genmarble', ['genmarble.c',], []),
14 ('gensky', Split('gensky.c sun.c',), []),
15 ('genblinds', ['genblinds.c',], []),
16 ('genprism', ['genprism.c',], []),
17 ('genrev', ['genrev.c',], ['rterror','rtfunc','rtcont','rtmem']),
18 ('gencatenary', ['gencat.c',], []),
19 ('genworm', ['genworm.c',], ['rtfunc','rtmem','rtcont','rtmath']),
20 ('gensurf', ['gensurf.c',], ['rtfunc','rtmem','rtcont','rtmath','rtio']),
21 ('genclock', ['genclock.c',], []),
22 ('genbranch', ['genbranch.c',], []),
23 ('replmarks', ['replmarks.c',],
24 ['rtproc','rtpath','rtmath','rtio','rterror']),
25 ('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'),
26 ['rtscene','rtproc','rtpath','rtmath','rtio','rtcont','rterror']),
27 ('xform', ['xform.c',],
28 ['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror']),
29 )
30 progs = []
31 for p in PROGS:
32 prog = env.Program(target=os.path.join(env['RAD_BUILDBIN'], p[0]),
33 source=p[1], LIBS=p[2] + mlib)
34 progs.append(prog)
35
36 if os.name == 'posix':
37 Default(env.InstallCsh(os.path.join('$RAD_BUILDBIN', 'glaze'), 'glaze.csh'))
38
39 Default('#src/gen')
40 env.Install('$RAD_BINDIR', progs)
41
42 #surf.cal clockface.hex
43 LIBFILES = Split('illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal')
44 env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES))
45
46
