root/Development/ray/src/gen/SConscript
Revision: 1.13
Committed: Wed Dec 15 01:40:11 2010 UTC (14 years, 9 months ago) by greg
Updated SConscript files for compiling under MINGW
1 import os
2
3 Import('env') # inherit from parent
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # standard targets
9 PROGS = (
10 # name sources libs
11 ('gendaylit', Split('gendaylit.c sun.c',), ['rtlamps']),
12 ('genbeads', Split('genbeads.c hermite3.c'), []),
13 ('genbox', ['genbox.c',], []),
14 ('genmarble', ['genmarble.c',], []),
15 ('gensky', Split('gensky.c sun.c',), []),
16 ('genblinds', ['genblinds.c',], []),
17 ('genprism', ['genprism.c',], []),
18 ('genrev', ['genrev.c',], ['rtfunc','rtcont','rtmem','rtio','rterror']),
19 ('gencatenary', ['gencat.c',], []),
20 ('genworm', ['genworm.c',],
21 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
22 ('gensurf', ['gensurf.c',],
23 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
24 ('genclock', ['genclock.c',], []),
25 ('genbranch', ['genbranch.c',], []),
26 ('replmarks', ['replmarks.c',],
27 ['rtproc','rtpath','rtmath','rtio','rterror']),
28 #('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'),
29 # ['rtproc','rtscene','rtpath','rtmath','rtio','rtcont','rterror']),
30 #('mksource', ['mksource.c'],
31 # ['rtio','rtmath','rterror']),
32 ('xform', ['xform.c',],
33 ['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror']),
34 )
35 progs = []
36 for p in PROGS:
37 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', p[0]),
38 source=p[1], LIBS=p[2] + mlib)
39 progs.append(prog)
40
41 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mkillum'),
42 source=Split('mkillum.c mkillum2.c mkillum3.c'),
43 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
44 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc',
45 'rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']
46 + mlib)
47 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mksource'),
48 source=['mksource.c'],
49 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
50 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc',
51 'rtmath','rtcont','rtmem','rtargs','rtio','rtpath','rterror'] + mlib)
52 progs.append(prog)
53
54 if os.name == 'posix':
55 Default(env.InstallCsh(os.path.join('$RAD_BUILDBIN', 'glaze'), 'glaze.csh'))
56
57 Default('#src/gen')
58 env.Install('$RAD_BINDIR', progs)
59
60 #surf.cal clockface.hex
61 LIBFILES = Split('illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal')
62 env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES))
63
64
