root/radiance/ray/src/gen/SConscript
Revision: 1.19
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 5 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Changes since 1.18: +10 -1 lines
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4
5 Import('env') # inherit from parent
6
7 # math libs
8 mlib = env['RAD_MLIB']
9
10 #Make sure sun.c is compiled only once
11 sun = env.Object(source="sun.c")
12
13 # standard targets
14 PROGS = (
15 # name sources libs
16 ('gendaylit', Split('gendaylit.c',)+[sun], ['rtrad']),
17 ('gendaymtx', Split('gendaymtx.c',)+[sun], ['rtrad',mlib]),
18 ('genbeads', Split('genbeads.c hermite3.c'), []),
19 ('genbox', ['genbox.c',], []),
20 ('genmarble', ['genmarble.c',], []),
21 ('gensky', Split('gensky.c',)+[sun], []),
22 ('genblinds', ['genblinds.c',], []),
23 ('genprism', ['genprism.c',], []),
24 ('genrev', ['genrev.c',], ['rtrad',]),
25 ('gencatenary', ['gencat.c',], []),
26 ('genworm', ['genworm.c',], ['rtrad']),
27 ('gensurf', ['gensurf.c',], ['rtrad']),
28 ('genclock', ['genclock.c',], []),
29 ('genbranch', ['genbranch.c',], []),
30 ('replmarks', ['replmarks.c',], ['rtrad']),
31 ('xform', ['xform.c',], ['rtrad']),
32 )
33 progs = []
34 for p in PROGS:
35 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', p[0]),
36 source=p[1], LIBS=p[2] + mlib)
37 progs.append(prog)
38
39 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mkillum'),
40 source=Split('mkillum.c mkillum2.c mkillum3.c'),
41 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
42 LIBS=['raycalls','rttrace','rtrad'] + mlib)
43 progs.append(prog)
44 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mksource'),
45 source=['mksource.c'],
46 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
47 LIBS=['raycalls','rttrace','rtrad'] + mlib)
48 progs.append(prog)
49
50 if os.name == 'posix':
51 Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze.csh'),
52 'glaze.csh'))
53 Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze'),
54 'glaze.py'))
55 else:
56 Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze.py'),
57 'glaze.py'))
58
59 Default('#src/gen')
60 env.Install('$RAD_BINDIR', progs)
61
62 #surf.cal clockface.hex
63 LIBFILES = Split('''illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal
64 perezlum.cal''')
65 env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES))
66
67 # vim: set syntax=python:
68 # vi: set ts=4 sw=4 :
