root/Development/ray/src/gen/SConscript
Revision: 1.16
Committed: Sat Mar 5 13:24:58 2016 UTC (9 years, 7 months ago) by schorsch
Changes since 1.15: +5 -6 lines
1 import os
2
3 Import('env') # inherit from parent
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 #Make sure sun.c is compiled only once
9 sun = env.Object(source="sun.c")
10
11 # standard targets
12 PROGS = (
13 # name sources libs
14 ('gendaylit', Split('gendaylit.c',)+[sun], ['rtlamps']),
15 ('gendaymtx', Split('gendaymtx.c',)+[sun],
16 ['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror',mlib]),
17 ('genbeads', Split('genbeads.c hermite3.c'), []),
18 ('genbox', ['genbox.c',], []),
19 ('genmarble', ['genmarble.c',], []),
20 ('gensky', Split('gensky.c',)+[sun], []),
21 ('genblinds', ['genblinds.c',], []),
22 ('genprism', ['genprism.c',], []),
23 ('genrev', ['genrev.c',], ['rtfunc','rtcont','rtmem','rtio','rterror']),
24 ('gencatenary', ['gencat.c',], []),
25 ('genworm', ['genworm.c',],
26 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
27 ('gensurf', ['gensurf.c',],
28 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
29 ('genclock', ['genclock.c',], []),
30 ('genbranch', ['genbranch.c',], []),
31 ('replmarks', ['replmarks.c',],
32 ['rtproc','rtpath','rtmath','rtio','rterror']),
33 ('xform', ['xform.c',],
34 ['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror']),
35 )
36 progs = []
37 for p in PROGS:
38 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', p[0]),
39 source=p[1], LIBS=p[2] + mlib)
40 progs.append(prog)
41
42 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mkillum'),
43 source=Split('mkillum.c mkillum2.c mkillum3.c'),
44 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
45 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc',
46 'rtnet','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']
47 + mlib)
48 progs.append(prog)
49 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mksource'),
50 source=['mksource.c'],
51 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
52 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc','rtnet',
53 'rtmath','rtcont','rtmem','rtargs','rtio','rtpath','rterror'] + mlib)
54 progs.append(prog)
55
56 if os.name == 'posix':
57 Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze'), 'glaze.csh'))
58
59 Default('#src/gen')
60 env.Install('$RAD_BINDIR', progs)
61
62 #surf.cal clockface.hex
63 LIBFILES = Split('''illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal
64 perezlum.cal coeff_perez.dat defangle.dat''')
65 env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES))
66
67 # vim: set syntax=python:
