root/Development/ray/src/gen/SConscript
Revision: 1.15
Committed: Sat Mar 5 00:29:28 2016 UTC (9 years, 7 months ago) by schorsch
Changes since 1.14: +3 -3 lines
update SCons
1 import os
2
3 Import('env') # inherit from parent
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 #Make sure sun.c is compiled only once
9 sun = env.Object(source="sun.c")
10
11 # standard targets
12 PROGS = (
13 # name sources libs
14 ('gendaylit', Split('gendaylit.c',)+[sun], ['rtlamps']),
15 ('genbeads', Split('genbeads.c hermite3.c'), []),
16 ('genbox', ['genbox.c',], []),
17 ('genmarble', ['genmarble.c',], []),
18 ('gensky', Split('gensky.c',)+[sun], []),
19 ('genblinds', ['genblinds.c',], []),
20 ('genprism', ['genprism.c',], []),
21 ('genrev', ['genrev.c',], ['rtfunc','rtcont','rtmem','rtio','rterror']),
22 ('gencatenary', ['gencat.c',], []),
23 ('genworm', ['genworm.c',],
24 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
25 ('gensurf', ['gensurf.c',],
26 ['rtfunc','rtmem','rtcont','rtmath','rtio','rterror']),
27 ('genclock', ['genclock.c',], []),
28 ('genbranch', ['genbranch.c',], []),
29 ('replmarks', ['replmarks.c',],
30 ['rtproc','rtpath','rtmath','rtio','rterror']),
31 #('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'),
32 # ['rtproc','rtscene','rtpath','rtmath','rtio','rtcont','rterror']),
33 #('mksource', ['mksource.c'],
34 # ['rtio','rtmath','rterror']),
35 ('xform', ['xform.c',],
36 ['rtproc','rtscene','rtmath','rtargs','rtio','rtcont','rtpath','rterror']),
37 )
38 progs = []
39 for p in PROGS:
40 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', p[0]),
41 source=p[1], LIBS=p[2] + mlib)
42 progs.append(prog)
43
44 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mkillum'),
45 source=Split('mkillum.c mkillum2.c mkillum3.c'),
46 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
47 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc',
48 'rtnet','rtpath','rtmath','rtargs','rtio','rtcont','rtmem','rterror']
49 + mlib)
50 progs.append(prog)
51 prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mksource'),
52 source=['mksource.c'],
53 CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
54 LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtproc','rtnet',
55 'rtmath','rtcont','rtmem','rtargs','rtio','rtpath','rterror'] + mlib)
56 progs.append(prog)
57
58 if os.name == 'posix':
59 Default(env.InstallScript(os.path.join('$RAD_BUILDBIN', 'glaze'), 'glaze.csh'))
60
61 Default('#src/gen')
62 env.Install('$RAD_BINDIR', progs)
63
64 #surf.cal clockface.hex
65 LIBFILES = Split('illum.cal rev.cal skybright.cal glaze1.cal glaze2.cal perezlum.cal coeff_perez.dat defangle.dat')
66 env.Append(RAD_RLIBINSTALL=env.Install('$RAD_RLIBDIR', LIBFILES))
67
68
