Added missing library data files used by gendaylit
Broke BSDF-handling routines into their own module
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Created mksource program
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -r option to genprism
added genclock program
added MLIB for redefining math library
removed genpine and genwindow
removed STRUCTASSIGN macro
changed definition of luminous efficacy!
standardized macro settings
moved librt.a to ../lib
added cal files
first version of mkillum
moved many routines to a common library
corrected oversight for xf.o dependencies
added RCONST to compilation of caldefn.o
modified for LESO machines
added replmarks
added MAT4 type
added otypes.h to xform.c for upward compatibility
added portability of bcopy()
improved smoothing in gensurf
Added fgetline.o
got rid of sccs check
fixed .csh installs
