root/radiance/ray/src/gen/Rmakefile
Wed Jul 30 17:30:27 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.34 , to selected 1.20
Improved use of sun.h
Fri May 30 00:00:54 2014 UTC (10 years ago) by greg
Changes since 2.33: +4 -1 lines
Diff to previous 2.33 , to selected 1.20
Sat Apr 26 15:59:38 2014 UTC (10 years, 1 month ago) by greg
Diff to previous 2.32 , to selected 1.20
Fri Aug 9 16:51:15 2013 UTC (10 years, 10 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31 , to selected 1.20
Added header file for solar position calculations
Wed Jan 30 01:02:42 2013 UTC (11 years, 4 months ago) by greg
Diff to previous 2.30 , to selected 1.20
Replaced gendaylit with new version by Wendelin Sprenger and Jan Wienold
Fri Jan 18 01:12:59 2013 UTC (11 years, 5 months ago) by greg
Diff to previous 2.29 , to selected 1.20
Wrote gendaymtx based on Ian Ashdown's H32_gendaylit.c -- untested as yet
Sat Oct 13 20:15:43 2012 UTC (11 years, 8 months ago) by greg
Diff to previous 2.28 , to selected 1.20
Sat Oct 22 22:38:10 2011 UTC (12 years, 8 months ago) by greg
Changes since 2.27: +4 -1 lines
Diff to previous 2.27 , to selected 1.20
Added qt interface for rvu and cmake files from Bill Hoffman
Fri Sep 3 23:53:50 2010 UTC (13 years, 9 months ago) by greg
Diff to previous 2.26 , to selected 1.20
Wed Jun 17 20:41:47 2009 UTC (15 years ago) by greg
Changes since 2.25: +5 -12 lines
Diff to previous 2.25 , to selected 1.20
Mon Jun 15 22:27:21 2009 UTC (15 years ago) by greg
Diff to previous 2.24 , to selected 1.20
Added missing library data files used by gendaylit
Fri Jun 12 17:37:37 2009 UTC (15 years ago) by greg
Changes since 2.23: +11 -6 lines
Diff to previous 2.23 , to selected 1.20
Broke BSDF-handling routines into their own module
Sat Jun 6 20:18:32 2009 UTC (15 years ago) by greg
Changes since 2.22: +6 -3 lines
Diff to previous 2.22 , to selected 1.20
Tue Jun 24 02:01:20 2008 UTC (16 years ago) by greg
Diff to previous 2.21 , to selected 1.20
Thu Feb 7 23:02:13 2008 UTC (16 years, 4 months ago) by greg
Diff to previous 2.20 , to selected 1.20
Sat Dec 8 01:43:09 2007 UTC (16 years, 6 months ago) by greg
Changes since 2.19: +6 -2 lines
Diff to previous 2.19 , to selected 1.20
Sat Nov 24 00:37:27 2007 UTC (16 years, 7 months ago) by greg
Diff to previous 2.18 , to selected 1.20
Fri Sep 21 05:53:21 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.17: +7 -5 lines
Diff to previous 2.17 , to selected 1.20
Tue Sep 18 19:51:07 2007 UTC (16 years, 9 months ago) by greg
Diff to previous 2.16 , to selected 1.20
Thu Sep 13 06:31:21 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.15: +11 -8 lines
Diff to previous 2.15 , to selected 1.20
Changed mkillum from calling rtrace to calling Radiance library (raypcalls.o)
Fri Mar 10 19:40:12 2006 UTC (18 years, 3 months ago) by schorsch
Changes since 2.14: +9 -9 lines
Diff to previous 2.14 , to selected 1.20
Tue Apr 12 03:30:43 2005 UTC (19 years, 2 months ago) by greg
Changes since 2.13: +14 -2 lines
Diff to previous 2.13 , to selected 1.20
Created mksource program
Wed Oct 27 23:23:47 2004 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 2.12 , to selected 1.20
Sat Aug 21 11:54:06 2004 UTC (19 years, 10 months ago) by greg
Changes since 2.11: +5 -3 lines
Diff to previous 2.11 , to selected 1.20
Thu Jan 1 19:31:45 2004 UTC (20 years, 5 months ago) by greg
Diff to previous 2.10 , to selected 1.20
Mon Oct 20 15:10:18 2003 UTC (20 years, 8 months ago) by greg
Diff to previous 2.9 , to selected 1.20
Mon Aug 4 22:37:53 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 2.8 , to selected 1.20
Fri Jun 27 06:53:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.7: +7 -5 lines
Diff to previous 2.7 , to selected 1.20
Sat Feb 22 02:07:23 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.6: +10 -5 lines
Diff to previous 2.6 , to selected 1.20
Tue Mar 19 12:37:44 1996 UTC (28 years, 3 months ago) by greg
Diff to previous 2.5 , to selected 1.20
added -r option to genprism
Thu May 25 16:38:09 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.4: +8 -5 lines
Diff to previous 2.4 , to selected 1.20
added genclock program
Thu Dec 9 17:29:24 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.3: +12 -11 lines
Diff to previous 2.3 , to selected 1.20
added MLIB for redefining math library
Fri Jul 9 09:10:05 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.2: +1 -3 lines
Diff to previous 2.2 , to selected 1.20
removed genpine and genwindow
Wed Jul 1 15:07:08 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.1: +14 -13 lines
Diff to previous 2.1 , to selected 1.20
Tue Nov 12 17:04:55 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.22: +0 -0 lines
Diff to previous 1.22 , to selected 1.20
Thu Nov 7 11:05:20 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.21 , to selected 1.20
removed STRUCTASSIGN macro
Thu Oct 24 10:32:19 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.20
changed definition of luminous efficacy!
Revision 1.20 - (view) (download) (annotate) - [selected]
Wed Oct 23 10:46:07 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.19
standardized macro settings
Thu Aug 22 09:23:41 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.18: +7 -8 lines
Diff to previous 1.18 , to selected 1.20
moved librt.a to ../lib
Thu Aug 22 08:55:34 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.17: +7 -1 lines
Diff to previous 1.17 , to selected 1.20
added cal files
Wed Jul 24 16:48:28 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.16: +10 -3 lines
Diff to previous 1.16 , to selected 1.20
first version of mkillum
Mon Jul 15 13:07:29 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.15: +16 -32 lines
Diff to previous 1.15 , to selected 1.20
moved many routines to a common library
Wed Jun 26 13:00:30 1991 UTC (33 years ago) by greg
Diff to previous 1.14 , to selected 1.20
corrected oversight for xf.o dependencies
Tue Apr 23 15:53:11 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.13 , to selected 1.20
added RCONST to compilation of caldefn.o
Thu Apr 11 09:21:21 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.12 , to selected 1.20
Tue Mar 19 12:11:03 1991 UTC (33 years, 3 months ago) by greg
Diff to previous 1.11 , to selected 1.20
modified for LESO machines
Thu Mar 7 14:48:28 1991 UTC (33 years, 3 months ago) by greg
Changes since 1.10: +6 -3 lines
Diff to previous 1.10 , to selected 1.20
Sun Feb 17 22:37:05 1991 UTC (33 years, 4 months ago) by greg
Changes since 1.9: +5 -2 lines
Diff to previous 1.9 , to selected 1.20
added replmarks
Sat Dec 15 15:00:54 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.8: +4 -2 lines
Diff to previous 1.8 , to selected 1.20
added MAT4 type
Thu Dec 13 11:25:57 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.7: +2 -0 lines
Diff to previous 1.7 , to selected 1.20
added otypes.h to xform.c for upward compatibility
Fri Jan 19 00:01:15 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.6: +4 -2 lines
Diff to previous 1.6 , to selected 1.20
added portability of bcopy()
Wed Oct 18 17:44:07 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.5 , to selected 1.20
improved smoothing in gensurf
Sat Oct 14 11:34:08 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.4: +3 -1 lines
Diff to previous 1.4 , to selected 1.20
Wed Oct 4 16:07:54 1989 UTC (34 years, 8 months ago) by greg
Diff to previous 1.3 , to selected 1.20
Added fgetline.o
Thu Mar 9 09:06:00 1989 UTC (35 years, 3 months ago) by greg
Changes since 1.2: +0 -1 lines
Diff to previous 1.2 , to selected 1.20
got rid of sccs check
Thu Feb 2 14:58:40 1989 UTC (35 years, 4 months ago) by greg
Changes since 1.1: +5 -2 lines
Diff to previous 1.1 , to selected 1.20
fixed .csh installs
Thu Feb 2 11:16:21 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.20
