1 |
GENERATOR PROGRAMS |
2 |
SCCSid "@(#)README 2.3 8/25/95 LBL" |
3 |
4 |
This directory contains programs for generating and transforming |
5 |
Radiance scene descriptions. |
6 |
7 |
mkillum.h common definitions for mkillum |
8 |
genbeads.c generate a string of spheres using Hermite curve |
9 |
genblinds.c make some curved or flat venetian blinds |
10 |
genbox.c generate a parallelepiped |
11 |
genbranch.c generate a tree branch |
12 |
gencat.c generate a catenary of marks (use with replmarks) |
13 |
genclock.c generate a clock showing a specified time |
14 |
genmarble.c generate a marble with air bubbles |
15 |
genprism.c generate a prism |
16 |
genrev.c program to generate functions of rotation about z |
17 |
gensky.c program to generate sky functions |
18 |
gensurf.c program to generate functional surfaces |
19 |
genworm.c program to generate worms (strings with varying thickness) |
20 |
hermite3.c routines for 3D hermite curves |
21 |
mkillum.c make illum sources for optimizing rendering process |
22 |
mkillum2.c routines to do the actual calculation for mkillum |
23 |
mkillum3.c routines to print mkillum objects |
24 |
replmarks.c replace markers with objects or instances |
25 |
sun.c solar postion calculations |
26 |
xform.c program to transform object files |
27 |
illum.cal function file for mkillum output |
28 |
rev.cal function file for smoothing option of genrev |
29 |
skybright.cal function file for gensky output |
30 |
surf.cal function file for gensurf smoothing |
