root/Development/ray/src/gen/README
Revision: 2.4
Committed: Sat Feb 22 02:07:23 2003 UTC (22 years, 10 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, rad3R5, HEAD
# User Rev Content
1 greg 1.1 GENERATOR PROGRAMS
2 greg 2.4 SCCSid "@(#)README 2.3 8/25/95 LBL"
3 greg 1.1
4     This directory contains programs for generating and transforming
5     Radiance scene descriptions.
6
7     mkillum.h common definitions for mkillum
8 greg 2.2 genbeads.c generate a string of spheres using Hermite curve
9 greg 1.1 genblinds.c make some curved or flat venetian blinds
10     genbox.c generate a parallelepiped
11 greg 2.3 genbranch.c generate a tree branch
12     gencat.c generate a catenary of marks (use with replmarks)
13     genclock.c generate a clock showing a specified time
14     genmarble.c generate a marble with air bubbles
15 greg 1.1 genprism.c generate a prism
16     genrev.c program to generate functions of rotation about z
17     gensky.c program to generate sky functions
18     gensurf.c program to generate functional surfaces
19     genworm.c program to generate worms (strings with varying thickness)
20     hermite3.c routines for 3D hermite curves
21     mkillum.c make illum sources for optimizing rendering process
22     mkillum2.c routines to do the actual calculation for mkillum
23     mkillum3.c routines to print mkillum objects
24     replmarks.c replace markers with objects or instances
25 greg 2.3 sun.c solar postion calculations
26     xform.c program to transform object files
27     illum.cal function file for mkillum output
28 greg 2.2 rev.cal function file for smoothing option of genrev
29     skybright.cal function file for gensky output
30     surf.cal function file for gensurf smoothing
