root/radiance/ray/src/gen/CMakeLists.txt
Sun Sep 12 16:41:32 2021 UTC (2 years, 8 months ago) by greg
CVS Tags: HEAD, rad5R4
chore(genbox): Added missing link to math library
Sun Apr 18 02:30:37 2021 UTC (3 years, 1 month ago) by greg
chore(genbox): changed library linkage order
Fri Apr 9 01:48:20 2021 UTC (3 years, 1 month ago) by greg
feat(genbox): Added polygonal modeling of rounded edges and -o option for .OBJ
Sat Jul 25 23:47:36 2020 UTC (3 years, 10 months ago) by greg
Changes since 2.6: +4 -3 lines
chore(genblinds, genbox, gensky): added missing library links
Fri Aug 31 16:01:45 2018 UTC (5 years, 9 months ago) by greg
New versions of evalglare and gendaylit from Jan Wienold
Mon Jan 8 16:51:32 2018 UTC (6 years, 4 months ago) by greg
Changes since 2.4: +37 -12 lines
Update to CMake build system from Rob G. and Alex S., adding test cases
Mon Feb 4 22:09:17 2013 UTC (11 years, 3 months ago) by greg
Update for removed gendaylit dependencies (data files)
Fri Jan 18 19:56:02 2013 UTC (11 years, 4 months ago) by greg
Changes since 2.2: +31 -28 lines
Fixed first major coding bugs in gendaymtx
Wed Apr 25 22:21:06 2012 UTC (12 years, 1 month ago) by greg
Changes since 2.1: +6 -2 lines
Diff to previous 2.1
Sat Oct 22 22:38:10 2011 UTC (12 years, 7 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
