| 1 |
greg |
2.1 |
/* RCSid: $Id: vect.h,v 1.3 2003/06/07 01:11:17 schorsch Exp $ */
| 2 |
#ifndef _MGF_VECT_H_
| 3 |
#define _MGF_VECT_H_
| 4 |
#ifdef __cplusplus
| 5 |
extern "C" {
| 6 |
#endif
| 7 |
| 8 |
| 9 |
#include <stdio.h>
| 10 |
| 11 |
typedef float Vector[3];
| 12 |
| 13 |
#define X 0
| 14 |
#define Y 1
| 15 |
#define Z 2
| 16 |
| 17 |
/* Transformation matrix */
| 18 |
typedef float Matrix[4][4];
| 19 |
| 20 |
void vect_init (Vector v, float x, float y, float z);
| 21 |
void vect_copy (Vector v1, Vector v2);
| 22 |
int vect_equal (Vector v1, Vector v2);
| 23 |
void vect_add (Vector v1, Vector v2, Vector v3);
| 24 |
void vect_sub (Vector v1, Vector v2, Vector v3);
| 25 |
void vect_scale (Vector v1, Vector v2, float k);
| 26 |
float vect_mag (Vector v);
| 27 |
void vect_normalize (Vector v);
| 28 |
float vect_dot (Vector v1, Vector v2);
| 29 |
void vect_cross (Vector v1, Vector v2, Vector v3);
| 30 |
void vect_min (Vector v1, Vector v2, Vector v3);
| 31 |
void vect_max (Vector v1, Vector v2, Vector v3);
| 32 |
float vect_angle (Vector v1, Vector v2);
| 33 |
void vect_print (FILE *f, Vector v, int dec, char sep);
| 34 |
void vect_rotate (Vector v1, Vector v2, int axis, float angle);
| 35 |
void vect_axis_rotate (Vector v1, Vector v2, Vector axis, float angle);
| 36 |
void mat_identity (Matrix mat);
| 37 |
void mat_copy (Matrix mat1, Matrix mat2);
| 38 |
void mat_rotate (Matrix mat1, Matrix mat2, int axis, float angle);
| 39 |
void mat_axis_rotate (Matrix mat1, Matrix mat2, Vector axis, float angle);
| 40 |
void mat_mult (Matrix mat1, Matrix mat2, Matrix mat3);
| 41 |
void vect_transform (Vector v1, Vector v2, Matrix mat);
| 42 |
void mat_decode (Matrix mat, Vector scale, Vector shear, Vector rotate, Vector
| 43 |
transl);
| 44 |
float mat_inv (Matrix mat1, Matrix mat2);
| 45 |
| 46 |
| 47 |
#ifdef __cplusplus
| 48 |
| 49 |
#endif
| 50 |
#endif /* _MGF_VECT_H_ */
