| 1 |
/* RCSid $Id: transportSimplex.h,v 2.1 2014/03/26 02:52:31 greg Exp $ */
| 2 |
| 3 |
transportSimplex.h
| 4 |
| 5 |
A C++ implementation of the transportation simplex algorithm.
| 6 |
| 7 |
Last edit Sept 3 2006
| 8 |
| 9 |
Copyright (C) 2006 Darren MacDonald
| 10 |
[email protected]
| 11 |
www.site.uottawa.ca/~dmacd070/emd
| 12 |
| 13 |
except some data structures and interface adapted from
| 14 |
http://ai.stanford.edu/~rubner/emd/emd.c,
| 15 |
Copyright 1998 Yossi Rubner.
| 16 |
| 17 |
This algorithm solves the problem of finding the least-cost way to transport
| 18 |
goods from a set of source (supply) nodes to a set of sink (demand) nodes.
| 19 |
| 20 |
To use the code, simply include this file in the user code and add 'using namespace t_simplex;'.
| 21 |
Organize the nodes into signatures using the TsSignature<TF> class, which contains a feature
| 22 |
array (of type TF) and an array of the respective weights of the features.
| 23 |
| 24 |
Solve the system by calling
| 25 |
transportSimplex(&Sig1, &Sig2, grndDist);
| 26 |
where Sig1 is the source signature, containing an array of source features and an array of their respective
| 27 |
supplies, Sig2 is the sink signature, containing the sink features and and their respective demands, and
| 28 |
grndDist is a pointer to a function which accepts two features pointers as arguments and returns the unit
| 29 |
cost of transporting goods between the two.
| 30 |
| 31 |
transportSimplex either returns the optimal transportation cost or throws a TsError.
| 32 |
| 33 |
For more information see the documentation at
| 34 |
www.site.uottawa.ca/~dmacd070/emd/index.html
| 35 |
and the example implemenation at
| 36 |
www.site.uottawa.ca/~dmacd070/emd/main.cpp.
| 37 |
| 38 |
| 39 |
#ifndef _T_SIMPLEX_H
| 40 |
#define _T_SIMPLEX_H
| 41 |
#include <iostream>
| 42 |
#include <stdlib.h>
| 43 |
#include <math.h>
| 44 |
#include <new>
| 45 |
| 46 |
#define TSINFINITY 1e20
| 47 |
#define TSEPSILON 1e-6
| 48 |
#define TSPIVOTLIMIT 0.00
| 49 |
| 50 |
namespace t_simplex {
| 51 |
| 52 |
/* DECLARATION OF DATA TYPES */
| 53 |
enum TsError { TsErrBadInput };
| 54 |
| 55 |
//TsSignature is used for inputting the source and sink signatures
| 56 |
template <class TF>
| 57 |
class TsSignature {
| 58 |
public:
| 59 |
int n; // Number of features in the signature
| 60 |
TF *features; // Pointer to the features vector
| 61 |
double *weights; // Pointer to the weights of the features
| 62 |
TsSignature(int nin, TF *fin, double * win):n(nin), features(fin), weights(win){};
| 63 |
| 64 |
| 65 |
//TsFlow is used for outputting the final flow table
| 66 |
typedef struct TsFlow {
| 67 |
int from; // Feature number in signature 1
| 68 |
int to; // Feature number in signature 2
| 69 |
double amount; // Amount of flow from signature1.features[from] to signature2.features[to]
| 70 |
} TsFlow;
| 71 |
| 72 |
// TsBasic is used for 2D lists, allowing for easy navigation of the basic variables
| 73 |
typedef struct TsBasic{
| 74 |
int i, j;
| 75 |
double val;
| 76 |
TsBasic *nextSnk, *prevSnk; // next/previous node in the column
| 77 |
TsBasic *nextSrc, *prevSrc; // next/previous node in the row
| 78 |
} TsBasic;
| 79 |
| 80 |
// TsStone is used for _BFS
| 81 |
typedef struct TsStone {
| 82 |
struct TsStone *prev;
| 83 |
struct TsBasic *node;
| 84 |
} TsStone;
| 85 |
| 86 |
// TsRusPen is used for 1D lists in _initRussel
| 87 |
typedef struct TsRusPen {
| 88 |
int i;
| 89 |
double val;
| 90 |
struct TsRusPen *next, *prev;
| 91 |
} TsRusPen;
| 92 |
| 93 |
// TsVogPen is used for 1D lists in _initVogel
| 94 |
typedef struct TsVogPen {
| 95 |
int i;
| 96 |
struct TsVogPen *next, *prev;
| 97 |
int one, two;
| 98 |
double oneCost, twoCost;
| 99 |
} TsVogPen;
| 100 |
| 101 |
/* DECLARATION OF GLOBALS */
| 102 |
double ** _tsC = NULL; // Cost matrix
| 103 |
double _tsMaxC; // Maximum of all costs
| 104 |
double _tsMaxW; // Maximum of all weights
| 105 |
| 106 |
| 107 |
/* INTERNAL FUNCTIONS */
| 108 |
double _pivot(TsBasic * basics, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2);
| 109 |
TsStone * _BFS(TsStone *stoneTree, TsBasic ** srcBasics, TsBasic ** snkBasics, bool complete = false);
| 110 |
void _initVogel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2);
| 111 |
void _initRussel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2);
| 112 |
| 113 |
| 114 |
transportSimplex() - Program entry point.
| 115 |
| 116 |
signature1 and signature2 define the source and sink sets. Unit costs between two features are computed from
| 117 |
grndDist. Signature weights must be positive and all costs must be positive.
| 118 |
TsFlow is an output parameter which can be set to an array that will be filled with the final flow amounts.
| 119 |
The array must be of size signature1->n + signature2->n - 1 . flowSize is a pointer to an integer which
| 120 |
indicates the number of functional entries in Flow, because all spaces are not necessarily used. Flow and
| 121 |
flowSize can be set to NULL or omitted from the argument list if this information is not important.
| 122 |
| 123 |
The return value is the transportation cost.
| 124 |
| 125 |
| 126 |
template <class TF>
| 127 |
double transportSimplex(TsSignature<TF> *signature1, TsSignature<TF> *signature2, double (*grndDist)(TF *, TF *),
| 128 |
TsFlow *flowTable = NULL, int *flowSize = NULL) {
| 129 |
| 130 |
int n1, n2; // number of features in signature1 and Signature 2
| 131 |
int i, j;
| 132 |
| 133 |
double totalCost;
| 134 |
double w;
| 135 |
| 136 |
double srcSum, snkSum, diff;
| 137 |
| 138 |
TF *P1, *P2;
| 139 |
| 140 |
n1 = signature1->n;
| 141 |
n2 = signature2->n;
| 142 |
| 143 |
TsBasic * basics = NULL; ///Array of basic variables.
| 144 |
bool ** isBasic = NULL; //Flag matrix. isBasic[i][j] is true there is flow between source i and sink j
| 145 |
TsBasic **srcBasics = NULL; //Array of pointers to the first basic variable in each row
| 146 |
TsBasic **snkBasics = NULL; //Array of pointers to the first basic variable in each column
| 147 |
double * src = NULL; //Array of source supplies
| 148 |
double * snk =NULL; //Array of sink demands
| 149 |
| 150 |
| 151 |
// Equalize source and sink weights. A dummy source or sink may be added to equalize the total sink
| 152 |
// and source weights. n1 = signature1->n + 1 if there is a dummy source, and n2 = signature2->n + 1
| 153 |
// if there is a dummy sink.
| 154 |
srcSum = 0.0;
| 155 |
for(i=0; i < n1; i++)
| 156 |
srcSum += signature1->weights[i];
| 157 |
| 158 |
snkSum = 0.0;
| 159 |
for(j=0; j < n2; j++)
| 160 |
snkSum += signature2->weights[j];
| 161 |
| 162 |
diff = srcSum - snkSum;
| 163 |
if (fabs(diff) > TSEPSILON * srcSum) {
| 164 |
if (diff < 0.0)
| 165 |
n1++;
| 166 |
else
| 167 |
n2++;
| 168 |
| 169 |
_tsMaxW = srcSum > snkSum ? srcSum : snkSum;
| 170 |
w = srcSum < snkSum ? srcSum : snkSum;
| 171 |
| 172 |
//Allocate memory for arrays
| 173 |
try {
| 174 |
| 175 |
basics = new TsBasic[n1 + n2];
| 176 |
| 177 |
isBasic = new bool*[n1];
| 178 |
for(i = 0; i < n1; i++)
| 179 |
isBasic[i] = NULL;
| 180 |
| 181 |
for(i = 0; i < n1; i++) {
| 182 |
isBasic[i] = new bool[n2];
| 183 |
for (j=0; j < n2; j++)
| 184 |
isBasic[i][j] = 0;
| 185 |
| 186 |
| 187 |
srcBasics = new TsBasic*[n1];
| 188 |
for (i = 0; i < n1; i++)
| 189 |
srcBasics[i] = NULL;
| 190 |
| 191 |
snkBasics = new TsBasic*[n2];
| 192 |
for (i = 0; i < n2; i++)
| 193 |
snkBasics[i] = NULL;
| 194 |
| 195 |
// Compute the cost matrix
| 196 |
_tsMaxC = 0;
| 197 |
_tsC = new double*[n1];
| 198 |
| 199 |
_tsC[i] = NULL;
| 200 |
| 201 |
for(i=0, P1=signature1->features; i < n1; i++, P1++) {
| 202 |
_tsC[i] = new double[n2]; //What happens if bad here?
| 203 |
for(j=0, P2=signature2->features; j < n2; j++, P2++) {
| 204 |
if (i == signature1->n || j == signature2->n) {
| 205 |
_tsC[i][j] = 0; // cost is zero for flow to or from a dummy
| 206 |
} else {
| 207 |
_tsC[i][j] = grndDist(P1, P2);
| 208 |
if (_tsC[i][j] < 0) throw TsErrBadInput;
| 209 |
| 210 |
| 211 |
| 212 |
if (_tsC[i][j] > _tsMaxC)
| 213 |
_tsMaxC = _tsC[i][j];
| 214 |
| 215 |
| 216 |
| 217 |
src = new double[n1]; //init the source array
| 218 |
for (i = 0; i < signature1->n; i++) {
| 219 |
src[i] = signature1->weights[i];
| 220 |
if (src[i] < 0) throw TsErrBadInput;
| 221 |
| 222 |
if (n1 != signature1->n)
| 223 |
src[signature1->n] = -diff;
| 224 |
| 225 |
snk = new double[n2]; //init the sink array
| 226 |
for (i = 0; i < signature2->n; i++) {
| 227 |
snk[i] = signature2->weights[i];
| 228 |
if (snk[i] < 0) throw TsErrBadInput;
| 229 |
| 230 |
if (n2 != signature2->n)
| 231 |
snk[signature2->n] = diff;
| 232 |
| 233 |
// Find the initail basic feasible solution. Use either _initRussel or _initVogel
| 234 |
| 235 |
| 236 |
_initRussel(src, snk, basics, srcBasics, snkBasics, isBasic, n1, n2);
| 237 |
//_initVogel(src, snk, basics, srcBasics, snkBasics, isBasic, n1, n2);
| 238 |
| 239 |
| 240 |
// Enter the main pivot loop
| 241 |
totalCost = _pivot(basics, srcBasics, snkBasics, isBasic, n1, n2);
| 242 |
| 243 |
} catch (...) {
| 244 |
| 245 |
delete[] isBasic[i];
| 246 |
delete[] isBasic;
| 247 |
| 248 |
| 249 |
delete[] _tsC[i];
| 250 |
delete[] _tsC;
| 251 |
| 252 |
delete[] src;
| 253 |
delete[] snk;
| 254 |
delete[] srcBasics;
| 255 |
delete[] snkBasics;
| 256 |
delete[] basics;
| 257 |
| 258 |
throw;
| 259 |
| 260 |
| 261 |
// Fill the Flow data structure
| 262 |
TsBasic * basicPtr;
| 263 |
TsFlow * flowPtr = flowTable;
| 264 |
if (flowTable != NULL) {
| 265 |
for (i = 0; i < n1+n2 -1; i++) {
| 266 |
basicPtr = basics + i;
| 267 |
if (isBasic[basicPtr->i][basicPtr->j] && basicPtr->i != signature1->n && basicPtr->j != signature2->n && basicPtr->val != 0.0) {
| 268 |
flowPtr->to = basicPtr->j;
| 269 |
flowPtr->from = basicPtr->i;
| 270 |
flowPtr->amount = basicPtr->val;
| 271 |
flowPtr++;
| 272 |
| 273 |
| 274 |
| 275 |
if (flowSize != NULL) {
| 276 |
*flowSize = (int)(flowPtr - flowTable);
| 277 |
| 278 |
| 279 |
| 280 |
| 281 |
| 282 |
delete[] isBasic;
| 283 |
| 284 |
| 285 |
delete[] _tsC[i];
| 286 |
delete[] _tsC;
| 287 |
| 288 |
delete[] src;
| 289 |
delete[] snk;
| 290 |
delete[] srcBasics;
| 291 |
delete[] snkBasics;
| 292 |
delete[] basics;
| 293 |
| 294 |
return totalCost;
| 295 |
| 296 |
| 297 |
| 298 |
Main pivot loop.
| 299 |
Pivots until the system is optimal and return the optimal transportation cost.
| 300 |
| 301 |
double _pivot(TsBasic * basics, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2) {
| 302 |
| 303 |
double * srcDuals = NULL;
| 304 |
double * snkDuals = NULL;
| 305 |
TsStone * stonePath = NULL;
| 306 |
| 307 |
TsStone * spitra, * spitrb, * leaving;
| 308 |
TsBasic * XP;
| 309 |
TsBasic * basicsEnd = basics + n1 + n2;
| 310 |
TsBasic * entering = basicsEnd - 1 ;
| 311 |
TsBasic dummyBasic;
| 312 |
dummyBasic.i = -1;
| 313 |
dummyBasic.j = 0;
| 314 |
| 315 |
int i,j, lowI, lowJ;
| 316 |
double objectiveValue = TSINFINITY, oldObjectiveValue = 0;
| 317 |
double lowVal;
| 318 |
int numPivots = 0;
| 319 |
| 320 |
try {
| 321 |
srcDuals = new double[n1];
| 322 |
snkDuals = new double[n2];
| 323 |
stonePath = new TsStone[n1 + n2];
| 324 |
} catch (std::bad_alloc) {
| 325 |
delete[] srcDuals;
| 326 |
delete[] snkDuals;
| 327 |
delete[] stonePath;
| 328 |
throw;
| 329 |
| 330 |
| 331 |
while (1) {
| 332 |
| 333 |
oldObjectiveValue = objectiveValue;
| 334 |
objectiveValue = 0;
| 335 |
| 336 |
for (XP = basics; XP != basicsEnd; XP++){
| 337 |
if (XP != entering)
| 338 |
objectiveValue += _tsC[XP->i][XP->j] * XP->val;
| 339 |
| 340 |
| 341 |
// Compute the dual variables for each row and column. Begin by finding a spanning tree (stonepath)
| 342 |
// of the basic variables using the breadth-first search routine seeded at an imaginary basic
| 343 |
// variable in the first column. The dual variables can then be computed incrementally by traversing
| 344 |
// the tree.
| 345 |
stonePath[0].node = &dummyBasic;
| 346 |
stonePath[0].prev = NULL;
| 347 |
spitrb = _BFS(stonePath, srcBasics, snkBasics, true);
| 348 |
| 349 |
spitra = stonePath;
| 350 |
snkDuals[spitra->node->j] = 0;
| 351 |
for (spitra++; spitra != spitrb; spitra++) {
| 352 |
if (spitra->node->i == spitra->prev->node->i) {
| 353 |
//node is in same row as parent
| 354 |
snkDuals[spitra->node->j] = _tsC[spitra->node->i][spitra->node->j] - srcDuals[spitra->node->i];
| 355 |
} else if (spitra->node->j == spitra->prev->node->j) {
| 356 |
srcDuals[spitra->node->i] = _tsC[spitra->node->i][spitra->node->j] - snkDuals[spitra->node->j];
| 357 |
| 358 |
| 359 |
| 360 |
// After computing the duals, find the non-basic variable that has the greatest negative value of
| 361 |
// delta = _tsC[i][j] - srcDuals[i] - snkDuals[j]. This is the entering variable
| 362 |
lowVal = 0.0;
| 363 |
| 364 |
for (j = 0; j < n2; j++)
| 365 |
if (!isBasic[i][j] && _tsC[i][j] - srcDuals[i] - snkDuals[j] < lowVal) {
| 366 |
lowVal = _tsC[i][j] - srcDuals[i] - snkDuals[j];
| 367 |
lowI = i;
| 368 |
lowJ = j;
| 369 |
| 370 |
| 371 |
// If all delta values are non-negative, the table is optimal
| 372 |
if (lowVal >= -TSEPSILON * _tsMaxC || (oldObjectiveValue - objectiveValue) < TSPIVOTLIMIT) {
| 373 |
delete[] srcDuals;
| 374 |
delete[] snkDuals;
| 375 |
delete[] stonePath;
| 376 |
//std::cout << numPivots << "\t";
| 377 |
return objectiveValue;
| 378 |
| 379 |
| 380 |
// Add the entering variable
| 381 |
entering->i = lowI;
| 382 |
entering->j = lowJ;
| 383 |
isBasic[lowI][lowJ] = 1;
| 384 |
entering->val = 0;
| 385 |
| 386 |
entering->nextSrc = srcBasics[lowI];
| 387 |
if (srcBasics[lowI] != NULL) srcBasics[lowI]->prevSrc = entering;
| 388 |
entering->nextSnk = snkBasics[lowJ];
| 389 |
if (snkBasics[lowJ] != NULL) snkBasics[lowJ]->prevSnk = entering;
| 390 |
| 391 |
srcBasics[lowI] = entering;
| 392 |
entering->prevSrc = srcBasics[lowI];
| 393 |
snkBasics[lowJ] = entering;
| 394 |
entering->prevSnk = snkBasics[lowJ];
| 395 |
| 396 |
stonePath[0].node = entering;
| 397 |
| 398 |
| 399 |
// Use breadth-first search to find a loop of basics.
| 400 |
spitra = spitrb = _BFS(stonePath, srcBasics, snkBasics);
| 401 |
lowVal = TSINFINITY;
| 402 |
bool add = false;
| 403 |
| 404 |
// Find the lowest flow along the loop (leaving variable)
| 405 |
do {
| 406 |
if (!add && spitrb->node->val < lowVal) {
| 407 |
leaving = spitrb;
| 408 |
lowVal = spitrb->node->val;
| 409 |
| 410 |
add = !add;
| 411 |
} while ((spitrb = spitrb->prev));
| 412 |
| 413 |
add = false;
| 414 |
spitrb = spitra;
| 415 |
| 416 |
// Alternately increase and decrease flow along the loop
| 417 |
do {
| 418 |
if (add) spitrb->node->val += lowVal;
| 419 |
else spitrb->node->val -= lowVal;
| 420 |
add = !add;
| 421 |
| 422 |
| 423 |
i = leaving->node->i;
| 424 |
j = leaving->node->j;
| 425 |
isBasic[i][j] = 0;
| 426 |
| 427 |
| 428 |
if (srcBasics[i] == leaving->node) {
| 429 |
srcBasics[i] = leaving->node->nextSrc;
| 430 |
srcBasics[i]->prevSrc = NULL;
| 431 |
} else {
| 432 |
leaving->node->prevSrc->nextSrc = leaving->node->nextSrc;
| 433 |
if (leaving->node->nextSrc != NULL)
| 434 |
leaving->node->nextSrc->prevSrc = leaving->node->prevSrc;
| 435 |
| 436 |
| 437 |
if (snkBasics[j] == leaving->node) {
| 438 |
snkBasics[j] = leaving->node->nextSnk;
| 439 |
snkBasics[j]->prevSnk = NULL;
| 440 |
} else {
| 441 |
leaving->node->prevSnk->nextSnk = leaving->node->nextSnk;
| 442 |
if (leaving->node->nextSnk != NULL)
| 443 |
leaving->node->nextSnk->prevSnk = leaving->node->prevSnk;
| 444 |
| 445 |
entering = leaving->node;
| 446 |
numPivots++;
| 447 |
| 448 |
| 449 |
| 450 |
| 451 |
| 452 |
_BFS
| 453 |
Perform a breadth-first search of the basic varaibles. The search tree is stored in stoneTree, where each
| 454 |
'stone' contains a pointer to a basic variable, and a pointer to that stone's parent. srcBasics and snkBasics
| 455 |
are arrays of linked lists which allow for easy identification of a node's neighbours in the flow network.
| 456 |
If complete == true, find all basics in the table. Otherwise, terminate when a basic variable which completes
| 457 |
a loop has been found and return a pointer to the final stone in the loop.
| 458 |
| 459 |
TsStone * _BFS(TsStone * stoneTree, TsBasic ** srcBasics, TsBasic ** snkBasics, bool complete) {
| 460 |
bool column = true;
| 461 |
int jumpoffset = 0;
| 462 |
TsBasic * bitr;
| 463 |
TsStone * sitra = &stoneTree[0], * sitrb = &stoneTree[1];
| 464 |
do {
| 465 |
if (column) {
| 466 |
for (bitr = snkBasics[sitra->node->j]; bitr != NULL; bitr = bitr->nextSnk) {
| 467 |
if (bitr != sitra->node){
| 468 |
sitrb->node = bitr;
| 469 |
sitrb->prev = sitra;
| 470 |
sitrb++;
| 471 |
| 472 |
| 473 |
} else {
| 474 |
for (bitr = srcBasics[sitra->node->i]; bitr != NULL; bitr = bitr->nextSrc) {
| 475 |
| 476 |
sitrb->node = bitr;
| 477 |
| 478 |
sitrb++;
| 479 |
| 480 |
| 481 |
| 482 |
| 483 |
sitra++;
| 484 |
if (sitra == sitrb) //no cycle found and no cycles in tree
| 485 |
return sitra;
| 486 |
| 487 |
if (sitra->node->i == sitra->prev->node->i)
| 488 |
column = true;
| 489 |
else
| 490 |
column = false;
| 491 |
| 492 |
// cycle found
| 493 |
if (!complete && sitra->node->i == stoneTree[0].node->i && sitra->node->j != stoneTree[0].node->j && column == false)
| 494 |
return sitra;
| 495 |
} while(1);
| 496 |
| 497 |
| 498 |
| 499 |
// Helper function for _initVogel
| 500 |
inline void addPenalty(TsVogPen * pitr, double cost, int i) {
| 501 |
if (cost < pitr->oneCost) {
| 502 |
pitr->twoCost = pitr->oneCost;
| 503 |
pitr->two = pitr->one;
| 504 |
pitr->oneCost = cost;
| 505 |
pitr->one = i;
| 506 |
} else if (cost < pitr->twoCost) {
| 507 |
pitr->twoCost = cost;
| 508 |
pitr->two = i;
| 509 |
| 510 |
| 511 |
| 512 |
| 513 |
| 514 |
Vogel's initialization method
| 515 |
| 516 |
void _initVogel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2) {
| 517 |
int i, j;
| 518 |
TsVogPen *srcPens = NULL;
| 519 |
TsVogPen *snkPens = NULL;
| 520 |
TsVogPen *pitra, *pitrb; //iterators
| 521 |
TsVogPen *maxPen;
| 522 |
TsVogPen srcPenHead, snkPenHead;
| 523 |
bool maxIsSrc;
| 524 |
double lowVal;
| 525 |
| 526 |
try {
| 527 |
srcPens = new TsVogPen[n1];
| 528 |
snkPens = new TsVogPen[n2];
| 529 |
| 530 |
delete[] srcPens;
| 531 |
delete[] snkPens;
| 532 |
throw;
| 533 |
| 534 |
| 535 |
srcPenHead.next = pitra = srcPens;
| 536 |
for (i=0; i < n1; i++) {
| 537 |
pitra->i = i;
| 538 |
pitra->next = pitra+1;
| 539 |
pitra->prev = pitra-1;
| 540 |
pitra->one = pitra->two = 0;
| 541 |
pitra->oneCost = pitra->twoCost = TSINFINITY;
| 542 |
pitra++;
| 543 |
| 544 |
(--pitra)->next = NULL;
| 545 |
srcPens[0].prev = &srcPenHead;
| 546 |
| 547 |
snkPenHead.next = pitra = snkPens;
| 548 |
for (i=0; i < n2; i++) {
| 549 |
pitra->i = i;
| 550 |
| 551 |
| 552 |
| 553 |
| 554 |
pitra++;
| 555 |
| 556 |
| 557 |
snkPens[0].prev = &snkPenHead;
| 558 |
| 559 |
| 560 |
for (pitra = srcPenHead.next, i=0; pitra != NULL; pitra = pitra->next, i++)
| 561 |
for (pitrb = snkPenHead.next, j=0; pitrb != NULL; pitrb = pitrb->next, j++) {
| 562 |
//initialize Source Penalties;
| 563 |
addPenalty(pitra, _tsC[i][j], j);
| 564 |
addPenalty(pitrb, _tsC[i][j], i);
| 565 |
| 566 |
| 567 |
| 568 |
while (srcPenHead.next != NULL && snkPenHead.next != NULL) {
| 569 |
maxIsSrc = true;
| 570 |
for (maxPen = pitra = srcPenHead.next; pitra != NULL; pitra = pitra->next)
| 571 |
if ((pitra->twoCost - pitra->oneCost) > (maxPen->twoCost - maxPen->oneCost))
| 572 |
maxPen = pitra;
| 573 |
| 574 |
for (pitra = snkPenHead.next; pitra != NULL; pitra = pitra->next)
| 575 |
if ((pitra->twoCost - pitra->oneCost) > (maxPen->twoCost - maxPen->oneCost)) {
| 576 |
maxPen = pitra;
| 577 |
maxIsSrc = false;
| 578 |
| 579 |
| 580 |
if (maxIsSrc) {
| 581 |
i = maxPen->i;
| 582 |
j = maxPen->one;
| 583 |
} else {
| 584 |
j = maxPen->i;
| 585 |
i = maxPen->one;
| 586 |
| 587 |
| 588 |
if (D[j] - S[i] > _tsMaxW * TSEPSILON || (srcPenHead.next->next != NULL && fabs(S[i] - D[j]) < _tsMaxW * TSEPSILON)) {
| 589 |
//delete source
| 590 |
lowVal = S[i];
| 591 |
maxPen = srcPens + i;
| 592 |
maxPen->prev->next = maxPen->next;
| 593 |
if (maxPen->next != NULL)
| 594 |
maxPen->next->prev = maxPen->prev;
| 595 |
| 596 |
for (pitra = snkPenHead.next; pitra != NULL; pitra = pitra->next) {
| 597 |
if (pitra->one == i || pitra->two == i){
| 598 |
pitra->oneCost = TSINFINITY;
| 599 |
| 600 |
for (pitrb = srcPenHead.next; pitrb != NULL; pitrb = pitrb->next)
| 601 |
addPenalty(pitra, _tsC[pitrb->i][pitra->i], pitrb->i);
| 602 |
| 603 |
| 604 |
} else {
| 605 |
//delete sink
| 606 |
lowVal = D[j];
| 607 |
maxPen = snkPens + j;
| 608 |
| 609 |
| 610 |
| 611 |
| 612 |
for (pitra = srcPenHead.next; pitra != NULL; pitra = pitra->next) {
| 613 |
if (pitra->one == j || pitra->two == j){
| 614 |
| 615 |
| 616 |
for (pitrb = snkPenHead.next; pitrb != NULL; pitrb = pitrb->next)
| 617 |
addPenalty(pitra, _tsC[pitra->i][pitrb->i], pitrb->i);
| 618 |
| 619 |
| 620 |
| 621 |
| 622 |
S[i] -= lowVal;
| 623 |
D[j] -= lowVal;
| 624 |
| 625 |
isBasic[i][j] = 1;
| 626 |
basicsEnd->val = lowVal;
| 627 |
basicsEnd->i = i;
| 628 |
basicsEnd->j = j;
| 629 |
| 630 |
basicsEnd->nextSnk = snkBasics[j];
| 631 |
if (snkBasics[j] != NULL) snkBasics[j]->prevSnk = basicsEnd;
| 632 |
basicsEnd->nextSrc = srcBasics[i];
| 633 |
if (srcBasics[i] != NULL) srcBasics[i]->prevSrc = basicsEnd;
| 634 |
| 635 |
srcBasics[i] = basicsEnd;
| 636 |
basicsEnd->prevSnk = NULL;
| 637 |
snkBasics[j] = basicsEnd;
| 638 |
basicsEnd->prevSrc = NULL;
| 639 |
| 640 |
basicsEnd++;
| 641 |
| 642 |
| 643 |
delete[] srcPens;
| 644 |
delete[] snkPens;
| 645 |
| 646 |
| 647 |
| 648 |
| 649 |
Russel's initialization method
| 650 |
| 651 |
void _initRussel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2) {
| 652 |
double ** Delta = NULL;
| 653 |
int i, j, lowI, lowJ;
| 654 |
TsRusPen *U = NULL;
| 655 |
TsRusPen *V = NULL;
| 656 |
TsRusPen *Uhead, *Vhead;
| 657 |
TsRusPen *Uitr, *Vitr;
| 658 |
double cost, lowVal;
| 659 |
| 660 |
try {
| 661 |
Delta = new double*[n1];
| 662 |
| 663 |
Delta[i] = new double[n2];
| 664 |
| 665 |
U = new TsRusPen[n1];
| 666 |
V = new TsRusPen[n2];
| 667 |
| 668 |
| 669 |
delete[] Delta[i];
| 670 |
delete[] Delta;
| 671 |
| 672 |
delete[] U;
| 673 |
delete[] V;
| 674 |
throw;
| 675 |
| 676 |
| 677 |
for (i = 0; i < n1; i++) {
| 678 |
U[i].i = i;
| 679 |
U[i].val = 0;
| 680 |
U[i].next = &U[i+1];
| 681 |
U[i].prev = &U[i-1];
| 682 |
| 683 |
U[n1-1].next = NULL;
| 684 |
U[0].prev = NULL;
| 685 |
| 686 |
for (i = 0; i < n2; i++) {
| 687 |
V[i].i = i;
| 688 |
V[i].val = 0;
| 689 |
V[i].next = &V[i+1];
| 690 |
V[i].prev = &V[i-1];
| 691 |
| 692 |
V[n2-1].next = NULL;
| 693 |
V[0].prev = NULL;
| 694 |
| 695 |
| 696 |
for (j = 0; j < n2; j++) {
| 697 |
cost = _tsC[i][j];
| 698 |
if (cost > U[i].val)
| 699 |
U[i].val = cost;
| 700 |
if (cost > V[j].val)
| 701 |
V[j].val = cost;
| 702 |
| 703 |
| 704 |
| 705 |
| 706 |
Delta[i][j] = _tsC[i][j] - U[i].val - V[j].val;
| 707 |
| 708 |
Uhead = U;
| 709 |
Vhead = V;
| 710 |
while (Uhead != NULL && Vhead != NULL) {
| 711 |
| 712 |
//Find lowest Delta
| 713 |
| 714 |
for (Uitr = Uhead; Uitr != NULL; Uitr = Uitr->next)
| 715 |
for (Vitr = Vhead; Vitr != NULL; Vitr = Vitr->next)
| 716 |
if (Delta[Uitr->i][Vitr->i] < lowVal) {
| 717 |
lowI = Uitr->i;
| 718 |
lowJ = Vitr->i;
| 719 |
lowVal = Delta[Uitr->i][Vitr->i];
| 720 |
| 721 |
| 722 |
| 723 |
if (D[lowJ] - S[lowI] > _tsMaxW * TSEPSILON || (fabs(S[lowI] - D[lowJ]) < _tsMaxW * TSEPSILON && Uhead->next != NULL)) {
| 724 |
//Delete Source
| 725 |
if (&U[lowI] == Uhead) { //Entering variable is first in list
| 726 |
Uhead = Uhead->next;
| 727 |
if (Uhead != NULL) Uhead->prev = NULL;
| 728 |
} else {
| 729 |
U[lowI].prev->next = U[lowI].next; //Entering variable is in middle of list;
| 730 |
if (U[lowI].next != NULL) //Entering variable is at the end of the list;
| 731 |
U[lowI].next->prev = U[lowI].prev;
| 732 |
| 733 |
//See if this source was the maximum cost for any dest
| 734 |
for (Vitr = Vhead; Vitr != NULL; Vitr = Vitr->next) {
| 735 |
if (Vitr->val == _tsC[lowI][Vitr->i]) {
| 736 |
//it is; update the dest
| 737 |
//find maximum cost in the dest
| 738 |
Vitr->val = 0;
| 739 |
| 740 |
if (_tsC[Uitr->i][Vitr->i] > Vitr->val)
| 741 |
Vitr->val = _tsC[Uitr->i][Vitr->i];
| 742 |
//update Delta
| 743 |
| 744 |
Delta[Uitr->i][Vitr->i] = _tsC[Uitr->i][Vitr->i] - Uitr->val - Vitr->val;
| 745 |
| 746 |
| 747 |
| 748 |
lowVal = S[lowI];
| 749 |
| 750 |
} else {
| 751 |
//Delete Dest
| 752 |
if (&V[lowJ] == Vhead) { //Entering variable is first in list
| 753 |
Vhead = Vhead->next;
| 754 |
if (Vhead != NULL) Vhead->prev = NULL;
| 755 |
} else {
| 756 |
V[lowJ].prev->next = V[lowJ].next; //Entering variable is in middle of list;
| 757 |
if (V[lowJ].next != NULL) //Entering variable is at the end of the list;
| 758 |
V[lowJ].next->prev = V[lowJ].prev;
| 759 |
| 760 |
| 761 |
for (Uitr = Uhead; Uitr != NULL; Uitr = Uitr->next) {
| 762 |
if (Uitr->val == _tsC[Uitr->i][lowJ]) {
| 763 |
| 764 |
| 765 |
Uitr->val = 0;
| 766 |
| 767 |
if (_tsC[Uitr->i][Vitr->i] > Uitr->val)
| 768 |
Uitr->val = _tsC[Uitr->i][Vitr->i];
| 769 |
//update Delta
| 770 |
| 771 |
| 772 |
| 773 |
| 774 |
| 775 |
lowVal = D[lowJ];
| 776 |
| 777 |
| 778 |
S[lowI] -= lowVal;
| 779 |
D[lowJ] -= lowVal;
| 780 |
| 781 |
| 782 |
| 783 |
basicsEnd->i = lowI;
| 784 |
basicsEnd->j = lowJ;
| 785 |
| 786 |
basicsEnd->nextSnk = snkBasics[lowJ];
| 787 |
if (snkBasics[lowJ] != NULL) snkBasics[lowJ]->prevSnk = basicsEnd;
| 788 |
basicsEnd->nextSrc = srcBasics[lowI];
| 789 |
if (srcBasics[lowI] != NULL) srcBasics[lowI]->prevSrc = basicsEnd;
| 790 |
| 791 |
srcBasics[lowI] = basicsEnd;
| 792 |
| 793 |
snkBasics[lowJ] = basicsEnd;
| 794 |
| 795 |
| 796 |
basicsEnd++;
| 797 |
| 798 |
| 799 |
| 800 |
delete[] U;
| 801 |
delete[] V;
| 802 |
| 803 |
delete[] Delta[i];
| 804 |
delete[] Delta;
| 805 |
| 806 |
| 807 |
#endif
| 808 |
