| 1 |
/* RCSid: $Id: trans.h,v 2.2 2003/02/22 02:07:23 greg Exp $ */
| 2 |
| 3 |
* Translator definitions
| 4 |
| 5 |
* Greg Ward
| 6 |
| 7 |
#ifndef _RAD_TRANS_H_
| 8 |
#define _RAD_TRANS_H_
| 9 |
#ifdef __cplusplus
| 10 |
extern "C" {
| 11 |
#endif
| 12 |
| 13 |
| 14 |
#define MAXSTR 128 /* maximum input string length */
| 15 |
| 16 |
#define VOIDID "void" /* null modifier */
| 17 |
| 18 |
/* qualifier list */
| 19 |
typedef struct {
| 20 |
int nquals; /* number of qualifiers */
| 21 |
char **qual; /* qualifier array */
| 22 |
} QLIST;
| 23 |
/* identifier */
| 24 |
typedef struct {
| 25 |
char *name; /* string, NULL if number */
| 26 |
int number;
| 27 |
} ID;
| 28 |
/* identifier list */
| 29 |
typedef struct {
| 30 |
int nids; /* number of ids */
| 31 |
ID *id; /* id array */
| 32 |
} IDLIST;
| 33 |
/* identifier range */
| 34 |
typedef struct {
| 35 |
char *nam; /* string, NULL if range */
| 36 |
int min, max; /* accepted range */
| 37 |
} IDMATCH;
| 38 |
/* mapping rule */
| 39 |
typedef struct rule {
| 40 |
char *mnam; /* material name */
| 41 |
long qflg; /* qualifier condition flags */
| 42 |
struct rule *next; /* next rule in mapping */
| 43 |
/* followed by the IDMATCH array */
| 44 |
} RULEHD;
| 45 |
/* useful macros */
| 46 |
#define doneid(idp) if ((idp)->name != NULL) freestr((idp)->name)
| 47 |
#define FL(qn) (1L<<(qn))
| 48 |
#define rulsiz(nq) (sizeof(RULEHD)+(nq)*sizeof(IDMATCH))
| 49 |
#define idm(rp) ((IDMATCH *)((rp)+1))
| 50 |
| 51 |
| 52 |
/* defined in common/savestr.c - XXX one of several declarations */
| 53 |
char *savestr(char *str);
| 54 |
/* defined in trans.c */
| 55 |
RULEHD *getmapping(char *file, QLIST *qlp);
| 56 |
| 57 |
| 58 |
#ifdef __cplusplus
| 59 |
| 60 |
#endif
| 61 |
#endif /* _RAD_TRANS_H_ */
| 62 |
