root/radiance/ray/src/cv/trans.h
Revision: 2.3
Committed: Sat Jun 7 01:10:23 2003 UTC (21 years ago) by schorsch
Changes since 2.2: +19 -3 lines
Removed NOPROTO sections.
1 /* RCSid: $Id: trans.h,v 2.2 2003/02/22 02:07:23 greg Exp $ */
2 /*
3 * Translator definitions
4 *
5 * Greg Ward
6 */
7 #ifndef _RAD_TRANS_H_
8 #define _RAD_TRANS_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13
14 #define MAXSTR 128 /* maximum input string length */
15
16 #define VOIDID "void" /* null modifier */
17
18 /* qualifier list */
19 typedef struct {
20 int nquals; /* number of qualifiers */
21 char **qual; /* qualifier array */
22 } QLIST;
23 /* identifier */
24 typedef struct {
25 char *name; /* string, NULL if number */
26 int number;
27 } ID;
28 /* identifier list */
29 typedef struct {
30 int nids; /* number of ids */
31 ID *id; /* id array */
32 } IDLIST;
33 /* identifier range */
34 typedef struct {
35 char *nam; /* string, NULL if range */
36 int min, max; /* accepted range */
37 } IDMATCH;
38 /* mapping rule */
39 typedef struct rule {
40 char *mnam; /* material name */
41 long qflg; /* qualifier condition flags */
42 struct rule *next; /* next rule in mapping */
43 /* followed by the IDMATCH array */
44 } RULEHD;
45 /* useful macros */
46 #define doneid(idp) if ((idp)->name != NULL) freestr((idp)->name)
47 #define FL(qn) (1L<<(qn))
48 #define rulsiz(nq) (sizeof(RULEHD)+(nq)*sizeof(IDMATCH))
49 #define idm(rp) ((IDMATCH *)((rp)+1))
50
51
52 /* defined in common/savestr.c - XXX one of several declarations */
53 char *savestr(char *str);
54 /* defined in trans.c */
55 RULEHD *getmapping(char *file, QLIST *qlp);
56
57
58 #ifdef __cplusplus
59 }
60 #endif
61 #endif /* _RAD_TRANS_H_ */
62
