1 |
greg |
1.1 |
#ifndef lint |
2 |
schorsch |
2.5 |
static const char RCSid[] = "$Id: trans.c,v 2.4 2003/06/08 12:03:09 schorsch Exp $"; |
3 |
greg |
1.1 |
#endif |
4 |
5 |
* Translator utilities |
6 |
7 |
* Greg Ward |
8 |
9 |
10 |
#include <stdio.h> |
11 |
greg |
2.2 |
#include <stdlib.h> |
12 |
schorsch |
2.4 |
#include <string.h> |
13 |
greg |
1.1 |
14 |
schorsch |
2.5 |
#include "rterror.h" |
15 |
greg |
1.1 |
#include "trans.h" |
16 |
17 |
schorsch |
2.4 |
static int idcmp(ID *id1, ID *id2); |
18 |
static void fputidlist(IDLIST *qp, FILE *fp); |
19 |
static int qtype(char *qnm, register QLIST *qlp); |
20 |
21 |
schorsch |
2.5 |
extern int |
22 |
schorsch |
2.4 |
fgetid( /* read an id up to char in dls from fp */ |
23 |
schorsch |
2.5 |
ID *idp, |
24 |
char *dls, |
25 |
register FILE *fp |
26 |
schorsch |
2.4 |
27 |
greg |
1.1 |
28 |
char dset[256/8]; |
29 |
char buf[MAXSTR]; |
30 |
register int c; |
31 |
register char *cp; |
32 |
/* create delimiter set */ |
33 |
for (cp = dset+sizeof(dset); cp-- > dset; ) |
34 |
*cp = 0; |
35 |
for (cp = dls; *cp; cp++) |
36 |
dset[*cp>>3] |= 1<<(*cp&7); |
37 |
/* get characters up to delimiter */ |
38 |
cp = buf; |
39 |
while ((c = getc(fp)) != EOF && !(dset[c>>3] & 1<<(c&7))) |
40 |
*cp++ = c; |
41 |
/* check for empty */ |
42 |
if (cp == buf) { |
43 |
if (c == EOF) |
44 |
return(EOF); |
45 |
idp->number = 0; |
46 |
idp->name = NULL; |
47 |
return(0); |
48 |
49 |
/* truncate space at end */ |
50 |
while (cp[-1] == ' ' || cp[-1] == '\t') |
51 |
cp--; |
52 |
*cp = '\0'; |
53 |
/* skip white space at beginning */ |
54 |
for (cp = buf; *cp && (*cp == ' ' || *cp == '\t'); cp++) |
55 |
56 |
/* assign value */ |
57 |
idp->number = atoi(cp); |
58 |
idp->name = NULL; |
59 |
/* check for ghost string */ |
60 |
if (!*cp) |
61 |
return(0); |
62 |
/* check for name */ |
63 |
if (idp->number == 0 && *cp != '0') |
64 |
idp->name = savestr(cp); |
65 |
return(0); |
66 |
67 |
68 |
69 |
schorsch |
2.5 |
extern int |
70 |
schorsch |
2.4 |
findid( /* find (or insert) id in list */ |
71 |
schorsch |
2.5 |
register IDLIST *idl, |
72 |
ID *idp, |
73 |
int insert |
74 |
schorsch |
2.4 |
75 |
greg |
1.1 |
76 |
int upper, lower; |
77 |
register int cm, i; |
78 |
/* binary search */ |
79 |
lower = 0; |
80 |
upper = cm = idl->nids; |
81 |
while ((i = (lower + upper) >> 1) != cm) { |
82 |
cm = idcmp(idp, &idl->id[i]); |
83 |
if (cm > 0) |
84 |
lower = i; |
85 |
else if (cm < 0) |
86 |
upper = i; |
87 |
else |
88 |
return(i); |
89 |
cm = i; |
90 |
91 |
if (!insert) |
92 |
return(-1); |
93 |
if (idl->nids == 0) { /* create new list */ |
94 |
idl->id = (ID *)malloc(sizeof(ID)); |
95 |
if (idl->id == NULL) |
96 |
goto memerr; |
97 |
} else { /* grow old list */ |
98 |
greg |
2.3 |
idl->id = (ID *)realloc((void *)idl->id,(idl->nids+1)*sizeof(ID)); |
99 |
greg |
1.1 |
100 |
goto memerr; |
101 |
for (i = idl->nids; i > upper; i--) { |
102 |
idl->id[i].number = idl->id[i-1].number; |
103 |
idl->id[i].name = idl->id[i-1].name; |
104 |
105 |
106 |
idl->nids++; /* insert new element */ |
107 |
idl->id[i].number = idp->number; |
108 |
if (idp->name == NULL) |
109 |
idl->id[i].name = NULL; |
110 |
else |
111 |
idl->id[i].name = savestr(idp->name); |
112 |
return(i); |
113 |
memerr: |
114 |
eputs("Out of memory in findid\n"); |
115 |
quit(1); |
116 |
schorsch |
2.4 |
return -1; /* pro forma return */ |
117 |
greg |
1.1 |
118 |
119 |
120 |
schorsch |
2.4 |
static int |
121 |
idcmp( /* compare two identifiers */ |
122 |
schorsch |
2.5 |
register ID *id1, |
123 |
register ID *id2 |
124 |
schorsch |
2.4 |
125 |
greg |
1.1 |
126 |
/* names are greater than numbers */ |
127 |
if (id1->name == NULL) |
128 |
if (id2->name == NULL) |
129 |
return(id1->number - id2->number); |
130 |
else |
131 |
return(-1); |
132 |
else |
133 |
134 |
return(1); |
135 |
else |
136 |
return(strcmp(id1->name, id2->name)); |
137 |
138 |
139 |
140 |
schorsch |
2.5 |
extern void |
141 |
schorsch |
2.4 |
write_quals( /* write out qualifier lists */ |
142 |
schorsch |
2.5 |
QLIST *qlp, |
143 |
IDLIST idl[], |
144 |
FILE *fp |
145 |
schorsch |
2.4 |
146 |
greg |
1.1 |
147 |
int i; |
148 |
149 |
for (i = 0; i < qlp->nquals; i++) |
150 |
if (idl[i].nids > 0) { |
151 |
fprintf(fp, "qualifier %s begin\n", qlp->qual[i]); |
152 |
fputidlist(&idl[i], fp); |
153 |
fprintf(fp, "end\n"); |
154 |
155 |
156 |
157 |
158 |
schorsch |
2.4 |
static void |
159 |
fputidlist( /* put id list out to fp */ |
160 |
schorsch |
2.5 |
IDLIST *qp, |
161 |
FILE *fp |
162 |
schorsch |
2.4 |
163 |
greg |
1.1 |
164 |
int fi; |
165 |
register int i; |
166 |
/* print numbers/ranges */ |
167 |
fi = 0; |
168 |
for (i = 0; i < qp->nids && qp->id[i].name == NULL; i++) |
169 |
if (i > 0 && qp->id[i].number > qp->id[i-1].number+1) { |
170 |
if (i > fi+1) |
171 |
fprintf(fp, "[%d:%d]\n", qp->id[fi].number, |
172 |
qp->id[i-1].number); |
173 |
else |
174 |
fprintf(fp, "%d\n", qp->id[fi].number); |
175 |
fi = i; |
176 |
177 |
if (i-1 > fi) |
178 |
179 |
180 |
else if (i > 0) |
181 |
182 |
for ( ; i < qp->nids; i++) |
183 |
fprintf(fp, "\"%s\"\n", qp->id[i].name); |
184 |
185 |
186 |
187 |
RULEHD * |
188 |
schorsch |
2.4 |
getmapping( /* read in mapping file */ |
189 |
schorsch |
2.5 |
char *file, |
190 |
QLIST *qlp |
191 |
schorsch |
2.4 |
192 |
greg |
1.1 |
193 |
char *err; |
194 |
register int c; |
195 |
RULEHD *mp = NULL; |
196 |
int nrules = 0; |
197 |
register RULEHD *rp; |
198 |
register int qt; |
199 |
char buf[MAXSTR]; |
200 |
FILE *fp; |
201 |
202 |
if ((fp = fopen(file, "r")) == NULL) { |
203 |
eputs(file); |
204 |
eputs(": cannot open\n"); |
205 |
quit(1); |
206 |
207 |
/* get each rule */ |
208 |
while (fscanf(fp, " %[^ ;\n]", buf) == 1) { |
209 |
if (buf[0] == '#') { /* comment */ |
210 |
while ((c = getc(fp)) != EOF && c != '\n') |
211 |
212 |
continue; |
213 |
214 |
rp = (RULEHD *)calloc(1, rulsiz(qlp->nquals)); |
215 |
if (rp == NULL) |
216 |
goto memerr; |
217 |
rp->mnam = savestr(buf); |
218 |
for ( ; ; ) { /* get conditions */ |
219 |
while ((c = getc(fp)) != '(') |
220 |
if (c == ';' || c == EOF) |
221 |
goto endloop; |
222 |
if (fscanf(fp, " %s ", buf) != 1) { |
223 |
err = "missing variable"; |
224 |
goto fmterr; |
225 |
226 |
if ((qt = qtype(buf, qlp)) == -1) { |
227 |
err = "unknown variable"; |
228 |
goto fmterr; |
229 |
230 |
if (rp->qflg & FL(qt)) { |
231 |
err = "variable repeated"; |
232 |
goto fmterr; |
233 |
234 |
rp->qflg |= FL(qt); |
235 |
c = getc(fp); |
236 |
switch (c) { |
237 |
case '"': /* id name */ |
238 |
if (fscanf(fp, "%[^\"]\" )", buf) != 1) { |
239 |
err = "bad string value"; |
240 |
goto fmterr; |
241 |
242 |
idm(rp)[qt].nam = savestr(buf); |
243 |
break; |
244 |
case '[': /* id range */ |
245 |
if (fscanf(fp, "%d : %d ] )", &idm(rp)[qt].min, |
246 |
&idm(rp)[qt].max) != 2) { |
247 |
err = "bad range value"; |
248 |
goto fmterr; |
249 |
250 |
if (idm(rp)[qt].min > idm(rp)[qt].max) { |
251 |
err = "reverse range value"; |
252 |
goto fmterr; |
253 |
254 |
break; |
255 |
default: /* id number? */ |
256 |
if ((c < '0' || c > '9') && c != '-') { |
257 |
err = "unrecognizable value"; |
258 |
goto fmterr; |
259 |
260 |
ungetc(c, fp); |
261 |
if (fscanf(fp, "%d )", &idm(rp)[qt].min) != 1) { |
262 |
err = "bad number id"; |
263 |
goto fmterr; |
264 |
265 |
idm(rp)[qt].max = idm(rp)[qt].min; |
266 |
break; |
267 |
268 |
269 |
endloop: |
270 |
rp->next = mp; |
271 |
mp = rp; |
272 |
nrules++; |
273 |
274 |
fclose(fp); |
275 |
return(mp); |
276 |
fmterr: |
277 |
sprintf(buf, "%s: %s for rule %d\n", file, err, nrules+1); |
278 |
eputs(buf); |
279 |
quit(1); |
280 |
memerr: |
281 |
eputs("Out of memory in getmapping\n"); |
282 |
quit(1); |
283 |
schorsch |
2.4 |
return NULL; /* pro forma return */ |
284 |
greg |
1.1 |
285 |
286 |
287 |
schorsch |
2.4 |
static int |
288 |
qtype( /* return number for qualifier name */ |
289 |
schorsch |
2.5 |
char *qnm, |
290 |
register QLIST *qlp |
291 |
schorsch |
2.4 |
292 |
greg |
1.1 |
293 |
register int i; |
294 |
295 |
296 |
if (!strcmp(qnm, qlp->qual[i])) |
297 |
return(i); |
298 |
return(-1); |
299 |
300 |
301 |
302 |
schorsch |
2.5 |
extern int |
303 |
schorsch |
2.4 |
matchid( /* see if we match an id */ |
304 |
schorsch |
2.5 |
register ID *it, |
305 |
register IDMATCH *im |
306 |
schorsch |
2.4 |
307 |
greg |
1.1 |
308 |
if (it->name == NULL) { |
309 |
if (im->nam != NULL) |
310 |
return(0); |
311 |
return(it->number >= im->min && it->number <= im->max); |
312 |
313 |
if (im->nam == NULL) |
314 |
return(0); |
315 |
return(!strcmp(it->name, im->nam)); |
316 |
