| 1 |
greg |
1.1 |
#ifndef lint
| 2 |
greg |
2.7 |
static const char RCSid[] = "$Id: trans.c,v 2.6 2018/03/20 18:45:04 greg Exp $";
| 3 |
greg |
1.1 |
#endif
| 4 |
| 5 |
* Translator utilities
| 6 |
| 7 |
* Greg Ward
| 8 |
| 9 |
| 10 |
greg |
2.2 |
#include <stdlib.h>
| 11 |
greg |
1.1 |
| 12 |
schorsch |
2.5 |
#include "rterror.h"
| 13 |
greg |
2.6 |
#include "rtio.h"
| 14 |
greg |
1.1 |
#include "trans.h"
| 15 |
| 16 |
schorsch |
2.4 |
static int idcmp(ID *id1, ID *id2);
| 17 |
static void fputidlist(IDLIST *qp, FILE *fp);
| 18 |
static int qtype(char *qnm, register QLIST *qlp);
| 19 |
| 20 |
schorsch |
2.5 |
extern int
| 21 |
schorsch |
2.4 |
fgetid( /* read an id up to char in dls from fp */
| 22 |
schorsch |
2.5 |
ID *idp,
| 23 |
char *dls,
| 24 |
register FILE *fp
| 25 |
schorsch |
2.4 |
| 26 |
greg |
1.1 |
| 27 |
char dset[256/8];
| 28 |
char buf[MAXSTR];
| 29 |
register int c;
| 30 |
register char *cp;
| 31 |
/* create delimiter set */
| 32 |
for (cp = dset+sizeof(dset); cp-- > dset; )
| 33 |
*cp = 0;
| 34 |
for (cp = dls; *cp; cp++)
| 35 |
dset[*cp>>3] |= 1<<(*cp&7);
| 36 |
/* get characters up to delimiter */
| 37 |
cp = buf;
| 38 |
while ((c = getc(fp)) != EOF && !(dset[c>>3] & 1<<(c&7)))
| 39 |
*cp++ = c;
| 40 |
/* check for empty */
| 41 |
if (cp == buf) {
| 42 |
if (c == EOF)
| 43 |
return(EOF);
| 44 |
idp->number = 0;
| 45 |
idp->name = NULL;
| 46 |
return(0);
| 47 |
| 48 |
/* truncate space at end */
| 49 |
while (cp[-1] == ' ' || cp[-1] == '\t')
| 50 |
cp--;
| 51 |
*cp = '\0';
| 52 |
/* skip white space at beginning */
| 53 |
for (cp = buf; *cp && (*cp == ' ' || *cp == '\t'); cp++)
| 54 |
| 55 |
/* assign value */
| 56 |
idp->number = atoi(cp);
| 57 |
idp->name = NULL;
| 58 |
/* check for ghost string */
| 59 |
if (!*cp)
| 60 |
return(0);
| 61 |
/* check for name */
| 62 |
if (idp->number == 0 && *cp != '0')
| 63 |
idp->name = savestr(cp);
| 64 |
return(0);
| 65 |
| 66 |
| 67 |
| 68 |
schorsch |
2.5 |
extern int
| 69 |
schorsch |
2.4 |
findid( /* find (or insert) id in list */
| 70 |
schorsch |
2.5 |
register IDLIST *idl,
| 71 |
ID *idp,
| 72 |
int insert
| 73 |
schorsch |
2.4 |
| 74 |
greg |
1.1 |
| 75 |
int upper, lower;
| 76 |
register int cm, i;
| 77 |
/* binary search */
| 78 |
lower = 0;
| 79 |
upper = cm = idl->nids;
| 80 |
while ((i = (lower + upper) >> 1) != cm) {
| 81 |
cm = idcmp(idp, &idl->id[i]);
| 82 |
if (cm > 0)
| 83 |
lower = i;
| 84 |
else if (cm < 0)
| 85 |
upper = i;
| 86 |
else
| 87 |
return(i);
| 88 |
cm = i;
| 89 |
| 90 |
if (!insert)
| 91 |
return(-1);
| 92 |
if (idl->nids == 0) { /* create new list */
| 93 |
idl->id = (ID *)malloc(sizeof(ID));
| 94 |
if (idl->id == NULL)
| 95 |
goto memerr;
| 96 |
} else { /* grow old list */
| 97 |
greg |
2.3 |
idl->id = (ID *)realloc((void *)idl->id,(idl->nids+1)*sizeof(ID));
| 98 |
greg |
1.1 |
| 99 |
goto memerr;
| 100 |
for (i = idl->nids; i > upper; i--) {
| 101 |
idl->id[i].number = idl->id[i-1].number;
| 102 |
idl->id[i].name = idl->id[i-1].name;
| 103 |
| 104 |
| 105 |
idl->nids++; /* insert new element */
| 106 |
idl->id[i].number = idp->number;
| 107 |
if (idp->name == NULL)
| 108 |
idl->id[i].name = NULL;
| 109 |
else
| 110 |
idl->id[i].name = savestr(idp->name);
| 111 |
return(i);
| 112 |
memerr:
| 113 |
eputs("Out of memory in findid\n");
| 114 |
quit(1);
| 115 |
schorsch |
2.4 |
return -1; /* pro forma return */
| 116 |
greg |
1.1 |
| 117 |
| 118 |
| 119 |
schorsch |
2.4 |
static int
| 120 |
idcmp( /* compare two identifiers */
| 121 |
schorsch |
2.5 |
register ID *id1,
| 122 |
register ID *id2
| 123 |
schorsch |
2.4 |
| 124 |
greg |
1.1 |
| 125 |
/* names are greater than numbers */
| 126 |
if (id1->name == NULL)
| 127 |
if (id2->name == NULL)
| 128 |
return(id1->number - id2->number);
| 129 |
else
| 130 |
return(-1);
| 131 |
else
| 132 |
| 133 |
return(1);
| 134 |
else
| 135 |
return(strcmp(id1->name, id2->name));
| 136 |
| 137 |
| 138 |
| 139 |
schorsch |
2.5 |
extern void
| 140 |
schorsch |
2.4 |
write_quals( /* write out qualifier lists */
| 141 |
schorsch |
2.5 |
QLIST *qlp,
| 142 |
IDLIST idl[],
| 143 |
FILE *fp
| 144 |
schorsch |
2.4 |
| 145 |
greg |
1.1 |
| 146 |
int i;
| 147 |
| 148 |
for (i = 0; i < qlp->nquals; i++)
| 149 |
if (idl[i].nids > 0) {
| 150 |
fprintf(fp, "qualifier %s begin\n", qlp->qual[i]);
| 151 |
fputidlist(&idl[i], fp);
| 152 |
fprintf(fp, "end\n");
| 153 |
| 154 |
| 155 |
| 156 |
| 157 |
schorsch |
2.4 |
static void
| 158 |
fputidlist( /* put id list out to fp */
| 159 |
schorsch |
2.5 |
IDLIST *qp,
| 160 |
FILE *fp
| 161 |
schorsch |
2.4 |
| 162 |
greg |
1.1 |
| 163 |
int fi;
| 164 |
register int i;
| 165 |
/* print numbers/ranges */
| 166 |
fi = 0;
| 167 |
for (i = 0; i < qp->nids && qp->id[i].name == NULL; i++)
| 168 |
if (i > 0 && qp->id[i].number > qp->id[i-1].number+1) {
| 169 |
if (i > fi+1)
| 170 |
fprintf(fp, "[%d:%d]\n", qp->id[fi].number,
| 171 |
qp->id[i-1].number);
| 172 |
else
| 173 |
fprintf(fp, "%d\n", qp->id[fi].number);
| 174 |
fi = i;
| 175 |
| 176 |
if (i-1 > fi)
| 177 |
| 178 |
| 179 |
else if (i > 0)
| 180 |
| 181 |
for ( ; i < qp->nids; i++)
| 182 |
fprintf(fp, "\"%s\"\n", qp->id[i].name);
| 183 |
| 184 |
| 185 |
| 186 |
RULEHD *
| 187 |
schorsch |
2.4 |
getmapping( /* read in mapping file */
| 188 |
schorsch |
2.5 |
char *file,
| 189 |
QLIST *qlp
| 190 |
schorsch |
2.4 |
| 191 |
greg |
1.1 |
| 192 |
char *err;
| 193 |
register int c;
| 194 |
RULEHD *mp = NULL;
| 195 |
int nrules = 0;
| 196 |
register RULEHD *rp;
| 197 |
register int qt;
| 198 |
char buf[MAXSTR];
| 199 |
FILE *fp;
| 200 |
| 201 |
if ((fp = fopen(file, "r")) == NULL) {
| 202 |
eputs(file);
| 203 |
eputs(": cannot open\n");
| 204 |
quit(1);
| 205 |
| 206 |
/* get each rule */
| 207 |
while (fscanf(fp, " %[^ ;\n]", buf) == 1) {
| 208 |
if (buf[0] == '#') { /* comment */
| 209 |
while ((c = getc(fp)) != EOF && c != '\n')
| 210 |
| 211 |
continue;
| 212 |
| 213 |
rp = (RULEHD *)calloc(1, rulsiz(qlp->nquals));
| 214 |
if (rp == NULL)
| 215 |
goto memerr;
| 216 |
rp->mnam = savestr(buf);
| 217 |
for ( ; ; ) { /* get conditions */
| 218 |
while ((c = getc(fp)) != '(')
| 219 |
if (c == ';' || c == EOF)
| 220 |
goto endloop;
| 221 |
if (fscanf(fp, " %s ", buf) != 1) {
| 222 |
err = "missing variable";
| 223 |
goto fmterr;
| 224 |
| 225 |
if ((qt = qtype(buf, qlp)) == -1) {
| 226 |
err = "unknown variable";
| 227 |
goto fmterr;
| 228 |
| 229 |
if (rp->qflg & FL(qt)) {
| 230 |
err = "variable repeated";
| 231 |
goto fmterr;
| 232 |
| 233 |
rp->qflg |= FL(qt);
| 234 |
c = getc(fp);
| 235 |
switch (c) {
| 236 |
case '"': /* id name */
| 237 |
if (fscanf(fp, "%[^\"]\" )", buf) != 1) {
| 238 |
err = "bad string value";
| 239 |
goto fmterr;
| 240 |
| 241 |
idm(rp)[qt].nam = savestr(buf);
| 242 |
break;
| 243 |
case '[': /* id range */
| 244 |
if (fscanf(fp, "%d : %d ] )", &idm(rp)[qt].min,
| 245 |
&idm(rp)[qt].max) != 2) {
| 246 |
err = "bad range value";
| 247 |
goto fmterr;
| 248 |
| 249 |
if (idm(rp)[qt].min > idm(rp)[qt].max) {
| 250 |
err = "reverse range value";
| 251 |
goto fmterr;
| 252 |
| 253 |
break;
| 254 |
default: /* id number? */
| 255 |
if ((c < '0' || c > '9') && c != '-') {
| 256 |
err = "unrecognizable value";
| 257 |
goto fmterr;
| 258 |
| 259 |
ungetc(c, fp);
| 260 |
if (fscanf(fp, "%d )", &idm(rp)[qt].min) != 1) {
| 261 |
err = "bad number id";
| 262 |
goto fmterr;
| 263 |
| 264 |
idm(rp)[qt].max = idm(rp)[qt].min;
| 265 |
break;
| 266 |
| 267 |
| 268 |
endloop:
| 269 |
rp->next = mp;
| 270 |
mp = rp;
| 271 |
nrules++;
| 272 |
| 273 |
fclose(fp);
| 274 |
return(mp);
| 275 |
fmterr:
| 276 |
sprintf(buf, "%s: %s for rule %d\n", file, err, nrules+1);
| 277 |
eputs(buf);
| 278 |
quit(1);
| 279 |
memerr:
| 280 |
eputs("Out of memory in getmapping\n");
| 281 |
quit(1);
| 282 |
schorsch |
2.4 |
return NULL; /* pro forma return */
| 283 |
greg |
1.1 |
| 284 |
| 285 |
| 286 |
schorsch |
2.4 |
static int
| 287 |
qtype( /* return number for qualifier name */
| 288 |
schorsch |
2.5 |
char *qnm,
| 289 |
register QLIST *qlp
| 290 |
schorsch |
2.4 |
| 291 |
greg |
1.1 |
| 292 |
register int i;
| 293 |
| 294 |
| 295 |
if (!strcmp(qnm, qlp->qual[i]))
| 296 |
return(i);
| 297 |
return(-1);
| 298 |
| 299 |
| 300 |
| 301 |
schorsch |
2.5 |
extern int
| 302 |
schorsch |
2.4 |
matchid( /* see if we match an id */
| 303 |
schorsch |
2.5 |
register ID *it,
| 304 |
register IDMATCH *im
| 305 |
schorsch |
2.4 |
| 306 |
greg |
1.1 |
| 307 |
if (it->name == NULL) {
| 308 |
if (im->nam != NULL)
| 309 |
return(0);
| 310 |
return(it->number >= im->min && it->number <= im->max);
| 311 |
| 312 |
if (im->nam == NULL)
| 313 |
return(0);
| 314 |
return(!strcmp(it->name, im->nam));
| 315 |
