root/radiance/ray/src/cv/tmesh2rad.c
Revision: 2.8
Committed: Wed Jun 22 12:35:58 1994 UTC (29 years, 10 months ago) by greg
Changes since 2.7: +3 -76 lines
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Convert a trianglular mesh into a Radiance description.
9 *
10 * Unlike most other converters, we have defined a file
11 * format for the input ourselves. The format contains eight types,
12 * each of which is identified by a single letter. These are:
13 *
14 * # comment = a comment. Continues until end of line.
15 * v id Px Py Pz = a vertex. The id must be an integer.
16 * n Nx Ny Nz = a normal. Corresponds to most recent vertex.
17 * i Iu Iv = an index. Corresponds to most recent vertex.
18 * p picture = a picture. Used as a pattern for following.
19 * m material = a material name. Used for what follows.
20 * o object = an object name. Used for what follows.
21 * t id1 id2 id3 = a triangle.
22 *
23 * Only the 't' type results in any output. The others merely set values
24 * to be used in generating triangles. If no picture or "p -" is given,
25 * there will be no pattern associated with the geometry. If no material
26 * or "m -" is given, no material will be associated. (Note that this
27 * only makes sense for a mesh which is to be put into an octree for
28 * instancing.) Using a pattern requires that each vertex have an
29 * associated index value for generating the colorpict primitive.
30 * Likewise, an interpolated surface normal also requires that each
31 * vertex of the triangle have an associated normal vector.
32 * It is not necessary for the normal vectors to have unit length.
33 */
34
35 #include "standard.h"
36
37 #include "tmesh.h"
38
39 #define VOIDID "void" /* this is defined in object.h */
40
41 #define PATNAME "T-pat" /* triangle pattern name (reused) */
42 #define TEXNAME "T-nor" /* triangle texture name (reused) */
43
44 #define V_DEFINED 01 /* this vertex is defined */
45 #define V_HASNORM 02 /* vertex has surface normal */
46 #define V_HASINDX 04 /* vertex has index */
47
48 typedef struct {
49 short flags; /* vertex flags, from above */
50 FVECT pos; /* location */
51 FVECT nor; /* normal */
52 float ndx[2]; /* picture index */
53 } VERTEX;
54
55 VERTEX *vlist = NULL; /* our vertex list */
56 int nverts = 0; /* number of vertices in our list */
57
58 #define novert(i) ((i)<0|(i)>=nverts || !(vlist[i].flags&V_DEFINED))
59
60 #define CHUNKSIZ 128 /* vertex allocation chunk size */
61
62 extern VERTEX *vnew(); /* allocate a vertex (never freed) */
63
64 char *defmat = VOIDID; /* default (starting) material name */
65 char *defpat = ""; /* default (starting) picture name */
66 char *defobj = "T"; /* default (starting) object name */
67
68
69 main(argc, argv) /* read in T-mesh files and convert */
70 int argc;
71 char *argv[];
72 {
73 FILE *fp;
74 int i;
75
76 for (i = 1; i < argc && argv[i][0] == '-'; i++)
77 switch (argv[i][1]) {
78 case 'o': /* object name */
79 defobj = argv[++i];
80 break;
81 case 'm': /* default material */
82 defmat = argv[++i];
83 break;
84 case 'p': /* default picture */
85 defpat = argv[++i];
86 break;
87 default:
88 fprintf(stderr,
89 "Usage: %s [-o obj][-m mat][-p pic] [file ..]\n",
90 argv[0]);
91 exit(1);
92 }
93 if (i >= argc)
94 convert("<stdin>", stdin);
95 else
96 for ( ; i < argc; i++) {
97 if ((fp = fopen(argv[i], "r")) == NULL) {
98 perror(argv[i]);
99 exit(1);
100 }
101 convert(argv[i], fp);
102 fclose(fp);
103 }
104 exit(0);
105 }
106
107
108 convert(fname, fp) /* convert a T-mesh */
109 char *fname;
110 FILE *fp;
111 {
112 char typ[4];
113 int id[3];
114 double vec[3];
115 char picfile[128];
116 char matname[64];
117 char objname[64];
118 register int i;
119 register VERTEX *lastv;
120 /* start fresh */
121 i = nverts;
122 lastv = vlist;
123 while (i--)
124 (lastv++)->flags = 0;
125 lastv = NULL;
126 strcpy(picfile, defpat);
127 strcpy(matname, defmat);
128 strcpy(objname, defobj);
129
130 printf("\n## T-mesh read from: %s\n", fname);
131 /* scan until EOF */
132 while (fscanf(fp, "%1s", typ) == 1)
133 switch (typ[0]) {
134 case 'v': /* vertex */
135 if (fscanf(fp, "%d %lf %lf %lf", &id[0],
136 &vec[0], &vec[1], &vec[2]) != 4)
137 syntax(fname, fp, "Bad vertex");
138 lastv = vnew(id[0], vec[0], vec[1], vec[2]);
139 break;
140 case 't': /* triangle */
141 if (fscanf(fp, "%d %d %d", &id[0], &id[1], &id[2]) != 3)
142 syntax(fname, fp, "Bad triangle");
143 if (novert(id[0]) | novert(id[1]) | novert(id[2]))
144 syntax(fname, fp, "Undefined triangle vertex");
145 triangle(picfile, matname, objname, &vlist[id[0]],
146 &vlist[id[1]], &vlist[id[2]]);
147 break;
148 case 'n': /* surface normal */
149 if (lastv == NULL)
150 syntax(fname, fp, "No vertex for normal");
151 if (fscanf(fp, "%lf %lf %lf",
152 &vec[0], &vec[1], &vec[2]) != 3)
153 syntax(fname, fp, "Bad vertex normal");
154 lastv->nor[0] = vec[0];
155 lastv->nor[1] = vec[1];
156 lastv->nor[2] = vec[2];
157 if (normalize(lastv->nor) == 0.0)
158 syntax(fname, fp, "Zero vertex normal");
159 lastv->flags |= V_HASNORM;
160 break;
161 case 'i': /* index position */
162 if (lastv == NULL)
163 syntax(fname, fp, "No vertex for index");
164 if (fscanf(fp, "%lf %lf", &vec[0], &vec[1]) != 2)
165 syntax(fname, fp, "Bad index");
166 lastv->ndx[0] = vec[0];
167 lastv->ndx[1] = vec[1];
168 lastv->flags |= V_HASINDX;
169 break;
170 case 'o': /* object name */
171 if (fscanf(fp, "%s", objname) != 1)
172 syntax(fname, fp, "Bad object name");
173 break;
174 case 'm': /* material */
175 if (fscanf(fp, "%s", matname) != 1)
176 syntax(fname, fp, "Bad material");
177 if (matname[0] == '-' && !matname[1])
178 strcpy(matname, VOIDID);
179 break;
180 case 'p': /* picture */
181 if (fscanf(fp, "%s", picfile) != 1)
182 syntax(fname, fp, "Bad pattern");
183 if (picfile[0] == '-' && !picfile[1])
184 picfile[0] = '\0';
185 break;
186 case '#': /* comment */
187 fputs("\n#", stdout);
188 while ((i = getc(fp)) != EOF) {
189 putchar(i);
190 if (i == '\n')
191 break;
192 }
193 break;
194 default:
195 syntax(fname, fp, "Unknown type");
196 break;
197 }
198 }
199
200
201 triangle(pn, mod, obj, v1, v2, v3) /* put out a triangle */
202 char *pn, *mod, *obj;
203 register VERTEX *v1, *v2, *v3;
204 {
205 static int ntri = 0;
206 BARYCCM bvecs;
207 FLOAT bvm[3][3];
208 register int i;
209 /* compute barycentric coordinates */
210 if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM))
211 if (comp_baryc(&bvecs, v1->pos, v2->pos, v3->pos) < 0)
212 return;
213 /* put out texture (if any) */
214 if (v1->flags & v2->flags & v3->flags & V_HASNORM) {
215 printf("\n%s texfunc %s\n", mod, TEXNAME);
216 mod = TEXNAME;
217 printf("4 dx dy dz %s\n", TCALNAME);
218 printf("0\n");
219 for (i = 0; i < 3; i++) {
220 bvm[i][0] = v1->nor[i];
221 bvm[i][1] = v2->nor[i];
222 bvm[i][2] = v3->nor[i];
223 }
224 put_baryc(&bvecs, bvm, 3);
225 }
226 /* put out pattern (if any) */
227 if (*pn && (v1->flags & v2->flags & v3->flags & V_HASINDX)) {
228 printf("\n%s colorpict %s\n", mod, PATNAME);
229 mod = PATNAME;
230 printf("7 noneg noneg noneg %s %s u v\n", pn, TCALNAME);
231 printf("0\n");
232 for (i = 0; i < 2; i++) {
233 bvm[i][0] = v1->ndx[i];
234 bvm[i][1] = v2->ndx[i];
235 bvm[i][2] = v3->ndx[i];
236 }
237 put_baryc(&bvecs, bvm, 2);
238 }
239 /* put out triangle */
240 printf("\n%s polygon %s.%d\n", mod, obj, ++ntri);
241 printf("0\n0\n9\n");
242 printf("%18.12g %18.12g %18.12g\n", v1->pos[0],v1->pos[1],v1->pos[2]);
243 printf("%18.12g %18.12g %18.12g\n", v2->pos[0],v2->pos[1],v2->pos[2]);
244 printf("%18.12g %18.12g %18.12g\n", v3->pos[0],v3->pos[1],v3->pos[2]);
245 }
246
247
248 VERTEX *
249 vnew(id, x, y, z) /* create a new vertex */
250 register int id;
251 double x, y, z;
252 {
253 register int i;
254
255 if (id >= nverts) { /* get some more */
256 i = nverts;
257 nverts = CHUNKSIZ*((id/CHUNKSIZ)+1);
258 if (vlist == NULL)
259 vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX));
260 else
261 vlist = (VERTEX *)realloc((char *)vlist,
262 nverts*sizeof(VERTEX));
263 if (vlist == NULL) {
264 fprintf(stderr,
265 "Out of memory while allocating vertex %d\n", id);
266 exit(1);
267 }
268 while (i < nverts) /* clear what's new */
269 vlist[i++].flags = 0;
270 }
271 /* assign new vertex */
272 vlist[id].pos[0] = x;
273 vlist[id].pos[1] = y;
274 vlist[id].pos[2] = z;
275 vlist[id].flags = V_DEFINED;
276 /* return it */
277 return(&vlist[id]);
278 }
279
280
281 syntax(fn, fp, er) /* report syntax error and exit */
282 char *fn;
283 register FILE *fp;
284 char *er;
285 {
286 extern long ftell();
287 register long cpos;
288 register int c;
289 int lineno;
290
291 if (fp == stdin)
292 fprintf(stderr, "%s: T-mesh format error: %s\n", fn, er);
293 else {
294 cpos = ftell(fp);
295 fseek(fp, 0L, 0);
296 lineno = 1;
297 while (cpos-- > 0) {
298 if ((c = getc(fp)) == EOF)
299 break;
300 if (c == '\n')
301 lineno++;
302 }
303 fprintf(stderr, "%s: T-mesh format error at line %d: %s\n",
304 fn, lineno, er);
305 }
306 exit(1);
307 }
