1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Convert a triangle mesh into a Radiance description. |
9 |
10 |
* Unlike most other converters, we have defined a file |
11 |
* format for the mesh ourselves. It contains eight types, |
12 |
* each of which is identified by a single letter. These are: |
13 |
14 |
* # comment = a comment. Continues until end of line. |
15 |
* v id Px Py Pz = a vertex. The id must be an integer. |
16 |
* n Nx Ny Nz = a normal. Corresponds to most recent vertex. |
17 |
* i Iu Iv = an index. Corresponds to most recent vertex. |
18 |
* p picture = a picture. Used as a pattern what follows. |
19 |
* m material = a material name. Used for what follows. |
20 |
* t id1 id2 id3 = a triangle. |
21 |
22 |
* Only the 't' type results in any output. The others merely set values |
23 |
* to be used in generating triangles. If no picture or "p -" is given, |
24 |
* there will be no pattern associated with the geometry. If no material |
25 |
* or "m -" is given, no material will be associated. (Note that this |
26 |
* only makes sense for a mesh which is to be put into an octree for |
27 |
* instancing.) Using a pattern requires that each vertex have an |
28 |
* associated index value for generating the colorpict primitive. |
29 |
30 |
31 |
#include "standard.h" |
32 |
33 |
#define CALNAME "tmesh.cal" /* the name of our auxiliary file */ |
34 |
#define PATNAME "tpat" /* triangle pattern name (reused) */ |
35 |
#define TEXNAME "tnor" /* triangle texture name (reused) */ |
36 |
37 |
#define V_DEFINED 01 /* this vertex is defined */ |
38 |
#define V_HASNORM 02 /* vertex has surface normal */ |
39 |
#define V_HASINDX 04 /* vertex has index */ |
40 |
41 |
typedef struct { |
42 |
short flags; /* vertex flags, from above */ |
43 |
FVECT pos; /* location */ |
44 |
FVECT nor; /* normal */ |
45 |
float ndx[2]; /* picture index */ |
46 |
} VERTEX; |
47 |
48 |
VERTEX *vlist = NULL; /* our vertex list */ |
49 |
int nverts = 0; /* number of vertices in our list */ |
50 |
51 |
typedef FLOAT BARYCCM[3][4]; |
52 |
53 |
#define novert(i) ((i)<0|(i)>=nverts||!(vlist[i].flags&V_DEFINED)) |
54 |
55 |
#define CHUNKSIZ 128 /* vertex allocation chunk size */ |
56 |
57 |
extern VERTEX *vnew(); /* allocate a vertex (never freed) */ |
58 |
59 |
60 |
main(argc, argv) /* read in T-mesh files and convert */ |
61 |
int argc; |
62 |
char *argv[]; |
63 |
64 |
FILE *fp; |
65 |
int i; |
66 |
67 |
if (argc == 1) |
68 |
convert("<stdin>", stdin); |
69 |
else |
70 |
for (i = 1; i < argc; i++) { |
71 |
if ((fp = fopen(argv[i], "r")) == NULL) { |
72 |
perror(argv[i]); |
73 |
exit(1); |
74 |
75 |
convert(argv[i], fp); |
76 |
fclose(fp); |
77 |
78 |
exit(0); |
79 |
80 |
81 |
82 |
convert(fname, fp) /* convert a T-mesh */ |
83 |
char *fname; |
84 |
FILE *fp; |
85 |
86 |
char typ[2]; |
87 |
int id[3]; |
88 |
double vec[3]; |
89 |
char picfile[128]; |
90 |
char matname[64]; |
91 |
char *err; |
92 |
register int c; |
93 |
register VERTEX *lastv = NULL; |
94 |
95 |
printf("# T-mesh from: %s\n", fname); |
96 |
97 |
picfile[0] = '\0'; |
98 |
strcpy(matname, "void"); |
99 |
100 |
while (fscanf(fp, "%1s", typ) == 1) |
101 |
switch (typ[0]) { |
102 |
case 'v': /* vertex */ |
103 |
if (fscanf(fp, "%d %lf %lf %lf", &id[0], |
104 |
&vec[0], &vec[1], &vec[2]) != 4) |
105 |
syntax(fname, fp, "Bad vertex"); |
106 |
lastv = vnew(id[0], vec[0], vec[1], vec[2]); |
107 |
break; |
108 |
case 't': /* triangle */ |
109 |
if (fscanf(fp, "%d %d %d", &id[0], &id[1], &id[2]) != 3) |
110 |
syntax(fname, fp, "Bad triangle"); |
111 |
if (novert(id[0]) | novert(id[1]) | novert(id[2])) |
112 |
syntax(fname, fp, "Undefined triangle vertex"); |
113 |
triangle(picfile, matname, &vlist[id[0]], |
114 |
&vlist[id[1]], &vlist[id[2]]); |
115 |
break; |
116 |
case 'n': /* surface normal */ |
117 |
if (lastv == NULL) |
118 |
syntax(fname, fp, "No vertex for normal"); |
119 |
if (fscanf(fp, "%lf %lf %lf", |
120 |
&vec[0], &vec[1], &vec[2]) != 3) |
121 |
syntax(fname, fp, "Bad vertex normal"); |
122 |
lastv->nor[0] = vec[0]; |
123 |
lastv->nor[1] = vec[1]; |
124 |
lastv->nor[2] = vec[2]; |
125 |
if (normalize(lastv->nor) == 0.0) |
126 |
syntax(fname, fp, "Zero vertex normal"); |
127 |
lastv->flags |= V_HASNORM; |
128 |
break; |
129 |
case 'i': /* index position */ |
130 |
131 |
syntax(fname, fp, "No vertex for index"); |
132 |
if (fscanf(fp, "%lf %lf", &vec[0], &vec[1]) != 2) |
133 |
syntax(fname, fp, "Bad index"); |
134 |
lastv->ndx[0] = vec[0]; |
135 |
lastv->ndx[1] = vec[1]; |
136 |
lastv->flags |= V_HASINDX; |
137 |
break; |
138 |
case 'm': /* material */ |
139 |
if (fscanf(fp, "%s", matname) != 1) |
140 |
syntax(fname, fp, "Bad material"); |
141 |
if (matname[0] == '-' && !matname[1]) |
142 |
143 |
break; |
144 |
case 'p': /* picture */ |
145 |
if (fscanf(fp, "%s", picfile) != 1) |
146 |
syntax(fname, fp, "Bad pattern"); |
147 |
if (picfile[0] == '-' && !picfile[1]) |
148 |
149 |
break; |
150 |
case '#': /* comment */ |
151 |
while ((c = getc(fp)) != EOF && c != '\n') |
152 |
153 |
break; |
154 |
default: |
155 |
syntax(fname, fp, "Unknown type"); |
156 |
break; |
157 |
158 |
159 |
160 |
161 |
triangle(pn, mn, v1, v2, v3) /* put out a triangle */ |
162 |
char *pn, *mn; |
163 |
register VERTEX *v1, *v2, *v3; |
164 |
165 |
static int ntri = 0; |
166 |
char *mod = mn; |
167 |
BARYCCM bvecs; |
168 |
/* compute barycentric coordinates */ |
169 |
if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM)) |
170 |
if (comp_baryc(bvecs, v1->pos, v2->pos, v3->pos) < 0) |
171 |
return; |
172 |
/* put out texture (if any) */ |
173 |
if (v1->flags & v2->flags & v3->flags & V_HASNORM) { |
174 |
printf("\n%s texfunc %s\n", mod, TEXNAME); |
175 |
mod = TEXNAME; |
176 |
printf("4 dx dy dz %s\n", CALNAME); |
177 |
printf("0\n21\n"); |
178 |
put_baryc(bvecs); |
179 |
printf("\t%14.12g %14.12g %14.12g\n", |
180 |
v1->nor[0], v2->nor[0], v3->nor[0]); |
181 |
182 |
v1->nor[1], v2->nor[1], v3->nor[1]); |
183 |
184 |
v1->nor[2], v2->nor[2], v3->nor[2]); |
185 |
186 |
/* put out pattern (if any) */ |
187 |
if (*pn && (v1->flags & v2->flags & v3->flags & V_HASINDX)) { |
188 |
printf("\n%s colorpict %s\n", mod, PATNAME); |
189 |
mod = PATNAME; |
190 |
printf("7 noneg noneg noneg %s %s u v\n", pn, CALNAME); |
191 |
printf("0\n18\n"); |
192 |
put_baryc(bvecs); |
193 |
printf("\t%f %f %f\n", v1->ndx[0], v2->ndx[0], v3->ndx[0]); |
194 |
printf("\t%f %f %f\n", v1->ndx[1], v2->ndx[1], v3->ndx[1]); |
195 |
196 |
/* put out triangle */ |
197 |
printf("\n%s polygon t%d\n", mod, ++ntri); |
198 |
printf("0\n0\n9\n"); |
199 |
printf("%18.12g %18.12g %18.12g\n", v1->pos[0],v1->pos[1],v1->pos[2]); |
200 |
printf("%18.12g %18.12g %18.12g\n", v2->pos[0],v2->pos[1],v2->pos[2]); |
201 |
printf("%18.12g %18.12g %18.12g\n", v3->pos[0],v3->pos[1],v3->pos[2]); |
202 |
203 |
204 |
205 |
int |
206 |
comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */ |
207 |
register BARYCCM bcm; |
208 |
FVECT v1, v2, v3; |
209 |
210 |
FLOAT *vt; |
211 |
FVECT va, vab, vcb; |
212 |
double d; |
213 |
register int i, j; |
214 |
215 |
for (j = 0; j < 3; j++) { |
216 |
for (i = 0; i < 3; i++) { |
217 |
vab[i] = v1[i] - v2[i]; |
218 |
vcb[i] = v3[i] - v2[i]; |
219 |
220 |
d = DOT(vcb,vcb); |
221 |
if (d <= FTINY) |
222 |
return(-1); |
223 |
d = DOT(vcb,vab)/d; |
224 |
for (i = 0; i < 3; i++) |
225 |
va[i] = vab[i] - vcb[i]*d; |
226 |
d = DOT(va,va); |
227 |
if (d <= FTINY) |
228 |
return(-1); |
229 |
230 |
va[i] /= d; |
231 |
bcm[j][i] = va[i]; |
232 |
233 |
bcm[j][3] = -DOT(v2,va); |
234 |
/* rotate vertices */ |
235 |
vt = v1; |
236 |
v1 = v2; |
237 |
v2 = v3; |
238 |
v3 = vt; |
239 |
240 |
return(0); |
241 |
242 |
243 |
244 |
put_baryc(bcm) /* put barycentric coord. vectors */ |
245 |
246 |
247 |
register int i; |
248 |
249 |
250 |
printf("%14.8f %14.8f %14.8f %14.8f\n", |
251 |
bcm[i][0], bcm[i][1], bcm[i][2], bcm[i][3]); |
252 |
253 |
254 |
255 |
VERTEX * |
256 |
vnew(id, x, y, z) /* create a new vertex */ |
257 |
register int id; |
258 |
double x, y, z; |
259 |
260 |
register int i; |
261 |
262 |
if (id > nverts) { /* get some more */ |
263 |
i = nverts; |
264 |
nverts = CHUNKSIZ*((id%CHUNKSIZ)+1); |
265 |
if (vlist == NULL) |
266 |
vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX)); |
267 |
else |
268 |
vlist = (VERTEX *)realloc((char *)vlist, |
269 |
270 |
if (vlist == NULL) { |
271 |
fprintf(stderr, |
272 |
"Out of memory while allocating vertex %d\n", id); |
273 |
exit(1); |
274 |
275 |
while (i < nverts) /* clear them */ |
276 |
vlist[i++].flags = 0; |
277 |
278 |
/* assign it */ |
279 |
vlist[id].pos[0] = x; |
280 |
vlist[id].pos[1] = y; |
281 |
vlist[id].pos[2] = z; |
282 |
vlist[id].flags = V_DEFINED; |
283 |
/* return it */ |
284 |
return(&vlist[id]); |
285 |
286 |
287 |
288 |
syntax(fn, fp, er) /* report syntax error and exit */ |
289 |
char *fn; |
290 |
register FILE *fp; |
291 |
char *er; |
292 |
293 |
extern long ftell(); |
294 |
register long cpos; |
295 |
register int c; |
296 |
int lineno; |
297 |
298 |
if (fp == stdin) |
299 |
fprintf(stderr, "%s: syntax error: %s\n", fn, er); |
300 |
else { |
301 |
cpos = ftell(fp); |
302 |
fseek(fp, 0L, 0); |
303 |
lineno = 1; |
304 |
while (cpos-- > 0) { |
305 |
if ((c = getc(fp)) == EOF) |
306 |
break; |
307 |
if (c == '\n') |
308 |
lineno++; |
309 |
310 |
fprintf(stderr, "%s: syntax error at line %d: %s\n", |
311 |
fn, lineno, er); |
312 |
313 |
exit(1); |
314 |
