| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: tmesh2rad.c,v 2.13 2003/06/26 00:58:09 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Convert a trianglular mesh into a Radiance description.
| 6 |
| 7 |
* Unlike most other converters, we have defined a file
| 8 |
* format for the input ourselves. The format contains eight types,
| 9 |
* each of which is identified by a single letter. These are:
| 10 |
| 11 |
* # comment = a comment. Continues until end of line.
| 12 |
* v id Px Py Pz = a vertex. The id must be an integer.
| 13 |
* n Nx Ny Nz = a normal. Corresponds to most recent vertex.
| 14 |
* i Iu Iv = an index. Corresponds to most recent vertex.
| 15 |
* p picture = a picture. Used as a pattern for following.
| 16 |
* m material = a material name. Used for what follows.
| 17 |
* o object = an object name. Used for what follows.
| 18 |
* t id1 id2 id3 = a triangle.
| 19 |
| 20 |
* Only the 't' type results in any output. The others merely set values
| 21 |
* to be used in generating triangles. If no picture or "p -" is given,
| 22 |
* there will be no pattern associated with the geometry. If no material
| 23 |
* or "m -" is given, no material will be associated. (Note that this
| 24 |
* only makes sense for a mesh which is to be put into an octree for
| 25 |
* instancing.) Using a pattern requires that each vertex have an
| 26 |
* associated index value for generating the colorpict primitive.
| 27 |
* Likewise, an interpolated surface normal also requires that each
| 28 |
* vertex of the triangle have an associated normal vector.
| 29 |
* It is not necessary for the normal vectors to have unit length.
| 30 |
| 31 |
| 32 |
#include "standard.h"
| 33 |
| 34 |
#include "tmesh.h"
| 35 |
| 36 |
#define VOIDID "void" /* this is defined in object.h */
| 37 |
| 38 |
#define PATNAME "T-pat" /* triangle pattern name (reused) */
| 39 |
#define TEXNAME "T-nor" /* triangle texture name (reused) */
| 40 |
| 41 |
#define V_DEFINED 01 /* this vertex is defined */
| 42 |
#define V_HASNORM 02 /* vertex has surface normal */
| 43 |
#define V_HASINDX 04 /* vertex has index */
| 44 |
| 45 |
typedef struct {
| 46 |
short flags; /* vertex flags, from above */
| 47 |
FVECT pos; /* location */
| 48 |
FVECT nor; /* normal */
| 49 |
float ndx[2]; /* picture index */
| 50 |
} VERTEX;
| 51 |
| 52 |
VERTEX *vlist = NULL; /* our vertex list */
| 53 |
int nverts = 0; /* number of vertices in our list */
| 54 |
| 55 |
#define novert(i) (((i)<0)|((i)>=nverts) || !(vlist[i].flags&V_DEFINED))
| 56 |
| 57 |
#define CHUNKSIZ 128 /* vertex allocation chunk size */
| 58 |
| 59 |
extern VERTEX *vnew(); /* allocate a vertex (never freed) */
| 60 |
| 61 |
char *defmat = VOIDID; /* default (starting) material name */
| 62 |
char *defpat = ""; /* default (starting) picture name */
| 63 |
char *defobj = "T"; /* default (starting) object name */
| 64 |
| 65 |
| 66 |
main(argc, argv) /* read in T-mesh files and convert */
| 67 |
int argc;
| 68 |
char *argv[];
| 69 |
| 70 |
FILE *fp;
| 71 |
int i;
| 72 |
| 73 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 74 |
switch (argv[i][1]) {
| 75 |
case 'o': /* object name */
| 76 |
defobj = argv[++i];
| 77 |
break;
| 78 |
case 'm': /* default material */
| 79 |
defmat = argv[++i];
| 80 |
break;
| 81 |
case 'p': /* default picture */
| 82 |
defpat = argv[++i];
| 83 |
break;
| 84 |
default:
| 85 |
fprintf(stderr,
| 86 |
"Usage: %s [-o obj][-m mat][-p pic] [file ..]\n",
| 87 |
argv[0]);
| 88 |
exit(1);
| 89 |
| 90 |
if (i >= argc)
| 91 |
convert("<stdin>", stdin);
| 92 |
else
| 93 |
for ( ; i < argc; i++) {
| 94 |
if ((fp = fopen(argv[i], "r")) == NULL) {
| 95 |
perror(argv[i]);
| 96 |
exit(1);
| 97 |
| 98 |
convert(argv[i], fp);
| 99 |
fclose(fp);
| 100 |
| 101 |
exit(0);
| 102 |
| 103 |
| 104 |
| 105 |
convert(fname, fp) /* convert a T-mesh */
| 106 |
char *fname;
| 107 |
FILE *fp;
| 108 |
| 109 |
char typ[4];
| 110 |
int id[3];
| 111 |
double vec[3];
| 112 |
char picfile[128];
| 113 |
char matname[64];
| 114 |
char objname[64];
| 115 |
register int i;
| 116 |
register VERTEX *lastv;
| 117 |
/* start fresh */
| 118 |
i = nverts;
| 119 |
lastv = vlist;
| 120 |
while (i--)
| 121 |
(lastv++)->flags = 0;
| 122 |
lastv = NULL;
| 123 |
strcpy(picfile, defpat);
| 124 |
strcpy(matname, defmat);
| 125 |
strcpy(objname, defobj);
| 126 |
| 127 |
printf("\n## T-mesh read from: %s\n", fname);
| 128 |
/* scan until EOF */
| 129 |
while (fscanf(fp, "%1s", typ) == 1)
| 130 |
switch (typ[0]) {
| 131 |
case 'v': /* vertex */
| 132 |
if (fscanf(fp, "%d %lf %lf %lf", &id[0],
| 133 |
&vec[0], &vec[1], &vec[2]) != 4)
| 134 |
syntax(fname, fp, "Bad vertex");
| 135 |
lastv = vnew(id[0], vec[0], vec[1], vec[2]);
| 136 |
break;
| 137 |
case 't': /* triangle */
| 138 |
if (fscanf(fp, "%d %d %d", &id[0], &id[1], &id[2]) != 3)
| 139 |
syntax(fname, fp, "Bad triangle");
| 140 |
if (novert(id[0]) | novert(id[1]) | novert(id[2]))
| 141 |
syntax(fname, fp, "Undefined triangle vertex");
| 142 |
triangle(picfile, matname, objname, &vlist[id[0]],
| 143 |
&vlist[id[1]], &vlist[id[2]]);
| 144 |
break;
| 145 |
case 'n': /* surface normal */
| 146 |
if (lastv == NULL)
| 147 |
syntax(fname, fp, "No vertex for normal");
| 148 |
if (fscanf(fp, "%lf %lf %lf",
| 149 |
&vec[0], &vec[1], &vec[2]) != 3)
| 150 |
syntax(fname, fp, "Bad vertex normal");
| 151 |
lastv->nor[0] = vec[0];
| 152 |
lastv->nor[1] = vec[1];
| 153 |
lastv->nor[2] = vec[2];
| 154 |
if (normalize(lastv->nor) == 0.0)
| 155 |
syntax(fname, fp, "Zero vertex normal");
| 156 |
lastv->flags |= V_HASNORM;
| 157 |
break;
| 158 |
case 'i': /* index position */
| 159 |
if (lastv == NULL)
| 160 |
syntax(fname, fp, "No vertex for index");
| 161 |
if (fscanf(fp, "%lf %lf", &vec[0], &vec[1]) != 2)
| 162 |
syntax(fname, fp, "Bad index");
| 163 |
lastv->ndx[0] = vec[0];
| 164 |
lastv->ndx[1] = vec[1];
| 165 |
lastv->flags |= V_HASINDX;
| 166 |
break;
| 167 |
| 168 |
if (fscanf(fp, "%s", objname) != 1)
| 169 |
syntax(fname, fp, "Bad object name");
| 170 |
break;
| 171 |
case 'm': /* material */
| 172 |
if (fscanf(fp, "%s", matname) != 1)
| 173 |
syntax(fname, fp, "Bad material");
| 174 |
if (matname[0] == '-' && !matname[1])
| 175 |
strcpy(matname, VOIDID);
| 176 |
break;
| 177 |
case 'p': /* picture */
| 178 |
if (fscanf(fp, "%s", picfile) != 1)
| 179 |
syntax(fname, fp, "Bad pattern");
| 180 |
if (picfile[0] == '-' && !picfile[1])
| 181 |
picfile[0] = '\0';
| 182 |
break;
| 183 |
case '#': /* comment */
| 184 |
fputs("\n#", stdout);
| 185 |
while ((i = getc(fp)) != EOF) {
| 186 |
putchar(i);
| 187 |
if (i == '\n')
| 188 |
break;
| 189 |
| 190 |
break;
| 191 |
default:
| 192 |
syntax(fname, fp, "Unknown type");
| 193 |
break;
| 194 |
| 195 |
| 196 |
| 197 |
| 198 |
triangle(pn, mod, obj, v1, v2, v3) /* put out a triangle */
| 199 |
char *pn, *mod, *obj;
| 200 |
register VERTEX *v1, *v2, *v3;
| 201 |
| 202 |
static char vfmt[] = "%18.12g %18.12g %18.12g\n";
| 203 |
static int ntri = 0;
| 204 |
int flatness = ISFLAT;
| 205 |
BARYCCM bvecs;
| 206 |
RREAL bvm[3][3];
| 207 |
register int i;
| 208 |
/* compute barycentric coordinates */
| 209 |
if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM))
| 210 |
if (comp_baryc(&bvecs, v1->pos, v2->pos, v3->pos) < 0)
| 211 |
return;
| 212 |
/* check flatness */
| 213 |
if (v1->flags & v2->flags & v3->flags & V_HASNORM) {
| 214 |
flatness = flat_tri(v1->pos, v2->pos, v3->pos,
| 215 |
v1->nor, v2->nor, v3->nor);
| 216 |
if (flatness == DEGEN)
| 217 |
return;
| 218 |
| 219 |
/* put out texture (if any) */
| 220 |
if (flatness == ISBENT || flatness == RVBENT) {
| 221 |
printf("\n%s texfunc %s\n", mod, TEXNAME);
| 222 |
mod = TEXNAME;
| 223 |
printf("4 dx dy dz %s\n", TCALNAME);
| 224 |
printf("0\n");
| 225 |
for (i = 0; i < 3; i++) {
| 226 |
bvm[i][0] = v1->nor[i];
| 227 |
bvm[i][1] = v2->nor[i];
| 228 |
bvm[i][2] = v3->nor[i];
| 229 |
| 230 |
put_baryc(&bvecs, bvm, 3);
| 231 |
| 232 |
/* put out pattern (if any) */
| 233 |
if (*pn && (v1->flags & v2->flags & v3->flags & V_HASINDX)) {
| 234 |
printf("\n%s colorpict %s\n", mod, PATNAME);
| 235 |
mod = PATNAME;
| 236 |
printf("7 noneg noneg noneg %s %s u v\n", pn, TCALNAME);
| 237 |
printf("0\n");
| 238 |
for (i = 0; i < 2; i++) {
| 239 |
bvm[i][0] = v1->ndx[i];
| 240 |
bvm[i][1] = v2->ndx[i];
| 241 |
bvm[i][2] = v3->ndx[i];
| 242 |
| 243 |
put_baryc(&bvecs, bvm, 2);
| 244 |
| 245 |
/* put out (reversed) triangle */
| 246 |
printf("\n%s polygon %s.%d\n", mod, obj, ++ntri);
| 247 |
printf("0\n0\n9\n");
| 248 |
if (flatness == RVFLAT || flatness == RVBENT) {
| 249 |
printf(vfmt, v3->pos[0],v3->pos[1],v3->pos[2]);
| 250 |
printf(vfmt, v2->pos[0],v2->pos[1],v2->pos[2]);
| 251 |
printf(vfmt, v1->pos[0],v1->pos[1],v1->pos[2]);
| 252 |
} else {
| 253 |
| 254 |
| 255 |
| 256 |
| 257 |
| 258 |
| 259 |
| 260 |
VERTEX *
| 261 |
vnew(id, x, y, z) /* create a new vertex */
| 262 |
register int id;
| 263 |
double x, y, z;
| 264 |
| 265 |
register int i;
| 266 |
| 267 |
if (id >= nverts) { /* get some more */
| 268 |
i = nverts;
| 269 |
nverts = CHUNKSIZ*((id/CHUNKSIZ)+1);
| 270 |
if (vlist == NULL)
| 271 |
vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX));
| 272 |
else
| 273 |
vlist = (VERTEX *)realloc((void *)vlist,
| 274 |
| 275 |
if (vlist == NULL) {
| 276 |
fprintf(stderr,
| 277 |
"Out of memory while allocating vertex %d\n", id);
| 278 |
exit(1);
| 279 |
| 280 |
while (i < nverts) /* clear what's new */
| 281 |
vlist[i++].flags = 0;
| 282 |
| 283 |
/* assign new vertex */
| 284 |
vlist[id].pos[0] = x;
| 285 |
vlist[id].pos[1] = y;
| 286 |
vlist[id].pos[2] = z;
| 287 |
vlist[id].flags = V_DEFINED;
| 288 |
/* return it */
| 289 |
return(&vlist[id]);
| 290 |
| 291 |
| 292 |
| 293 |
syntax(fn, fp, er) /* report syntax error and exit */
| 294 |
char *fn;
| 295 |
register FILE *fp;
| 296 |
char *er;
| 297 |
| 298 |
extern long ftell();
| 299 |
register long cpos;
| 300 |
register int c;
| 301 |
int lineno;
| 302 |
| 303 |
if (fp == stdin)
| 304 |
fprintf(stderr, "%s: T-mesh format error: %s\n", fn, er);
| 305 |
else {
| 306 |
cpos = ftell(fp);
| 307 |
fseek(fp, 0L, 0);
| 308 |
lineno = 1;
| 309 |
while (cpos-- > 0) {
| 310 |
if ((c = getc(fp)) == EOF)
| 311 |
break;
| 312 |
if (c == '\n')
| 313 |
lineno++;
| 314 |
| 315 |
fprintf(stderr, "%s: T-mesh format error at line %d: %s\n",
| 316 |
fn, lineno, er);
| 317 |
| 318 |
exit(1);
| 319 |
