--- ray/src/cv/tmesh2rad.c 1994/06/22 12:35:58 2.8 +++ ray/src/cv/tmesh2rad.c 2003/07/27 22:12:02 2.14 @@ -1,9 +1,6 @@ -/* Copyright (c) 1994 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: tmesh2rad.c,v 2.14 2003/07/27 22:12:02 schorsch Exp $"; #endif - /* * Convert a trianglular mesh into a Radiance description. * @@ -55,7 +52,7 @@ typedef struct { VERTEX *vlist = NULL; /* our vertex list */ int nverts = 0; /* number of vertices in our list */ -#define novert(i) ((i)<0|(i)>=nverts || !(vlist[i].flags&V_DEFINED)) +#define novert(i) (((i)<0)|((i)>=nverts) || !(vlist[i].flags&V_DEFINED)) #define CHUNKSIZ 128 /* vertex allocation chunk size */ @@ -202,16 +199,25 @@ triangle(pn, mod, obj, v1, v2, v3) /* put out a triang char *pn, *mod, *obj; register VERTEX *v1, *v2, *v3; { + static char vfmt[] = "%18.12g %18.12g %18.12g\n"; static int ntri = 0; + int flatness = ISFLAT; BARYCCM bvecs; - FLOAT bvm[3][3]; + RREAL bvm[3][3]; register int i; /* compute barycentric coordinates */ if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM)) if (comp_baryc(&bvecs, v1->pos, v2->pos, v3->pos) < 0) return; - /* put out texture (if any) */ + /* check flatness */ if (v1->flags & v2->flags & v3->flags & V_HASNORM) { + flatness = flat_tri(v1->pos, v2->pos, v3->pos, + v1->nor, v2->nor, v3->nor); + if (flatness == DEGEN) + return; + } + /* put out texture (if any) */ + if (flatness == ISBENT || flatness == RVBENT) { printf("\n%s texfunc %s\n", mod, TEXNAME); mod = TEXNAME; printf("4 dx dy dz %s\n", TCALNAME); @@ -236,12 +242,18 @@ register VERTEX *v1, *v2, *v3; } put_baryc(&bvecs, bvm, 2); } - /* put out triangle */ + /* put out (reversed) triangle */ printf("\n%s polygon %s.%d\n", mod, obj, ++ntri); printf("0\n0\n9\n"); - printf("%18.12g %18.12g %18.12g\n", v1->pos[0],v1->pos[1],v1->pos[2]); - printf("%18.12g %18.12g %18.12g\n", v2->pos[0],v2->pos[1],v2->pos[2]); - printf("%18.12g %18.12g %18.12g\n", v3->pos[0],v3->pos[1],v3->pos[2]); + if (flatness == RVFLAT || flatness == RVBENT) { + printf(vfmt, v3->pos[0],v3->pos[1],v3->pos[2]); + printf(vfmt, v2->pos[0],v2->pos[1],v2->pos[2]); + printf(vfmt, v1->pos[0],v1->pos[1],v1->pos[2]); + } else { + printf(vfmt, v1->pos[0],v1->pos[1],v1->pos[2]); + printf(vfmt, v2->pos[0],v2->pos[1],v2->pos[2]); + printf(vfmt, v3->pos[0],v3->pos[1],v3->pos[2]); + } } @@ -258,7 +270,7 @@ double x, y, z; if (vlist == NULL) vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX)); else - vlist = (VERTEX *)realloc((char *)vlist, + vlist = (VERTEX *)realloc((void *)vlist, nverts*sizeof(VERTEX)); if (vlist == NULL) { fprintf(stderr,
