--- ray/src/cv/tmesh2rad.c 1994/02/15 15:58:03 2.1 +++ ray/src/cv/tmesh2rad.c 1994/06/22 12:35:58 2.8 @@ -5,18 +5,19 @@ static char SCCSid[] = "$SunId$ LBL"; #endif /* - * Convert a triangle mesh into a Radiance description. + * Convert a trianglular mesh into a Radiance description. * * Unlike most other converters, we have defined a file - * format for the mesh ourselves. It contains eight types, + * format for the input ourselves. The format contains eight types, * each of which is identified by a single letter. These are: * * # comment = a comment. Continues until end of line. * v id Px Py Pz = a vertex. The id must be an integer. * n Nx Ny Nz = a normal. Corresponds to most recent vertex. * i Iu Iv = an index. Corresponds to most recent vertex. - * p picture = a picture. Used as a pattern what follows. + * p picture = a picture. Used as a pattern for following. * m material = a material name. Used for what follows. + * o object = an object name. Used for what follows. * t id1 id2 id3 = a triangle. * * Only the 't' type results in any output. The others merely set values @@ -26,14 +27,20 @@ static char SCCSid[] = "$SunId$ LBL"; * only makes sense for a mesh which is to be put into an octree for * instancing.) Using a pattern requires that each vertex have an * associated index value for generating the colorpict primitive. + * Likewise, an interpolated surface normal also requires that each + * vertex of the triangle have an associated normal vector. + * It is not necessary for the normal vectors to have unit length. */ #include "standard.h" -#define CALNAME "tmesh.cal" /* the name of our auxiliary file */ -#define PATNAME "tpat" /* triangle pattern name (reused) */ -#define TEXNAME "tnor" /* triangle texture name (reused) */ +#include "tmesh.h" +#define VOIDID "void" /* this is defined in object.h */ + +#define PATNAME "T-pat" /* triangle pattern name (reused) */ +#define TEXNAME "T-nor" /* triangle texture name (reused) */ + #define V_DEFINED 01 /* this vertex is defined */ #define V_HASNORM 02 /* vertex has surface normal */ #define V_HASINDX 04 /* vertex has index */ @@ -48,15 +55,17 @@ typedef struct { VERTEX *vlist = NULL; /* our vertex list */ int nverts = 0; /* number of vertices in our list */ -typedef FLOAT BARYCCM[3][4]; +#define novert(i) ((i)<0|(i)>=nverts || !(vlist[i].flags&V_DEFINED)) -#define novert(i) ((i)<0|(i)>=nverts||!(vlist[i].flags&V_DEFINED)) - #define CHUNKSIZ 128 /* vertex allocation chunk size */ extern VERTEX *vnew(); /* allocate a vertex (never freed) */ +char *defmat = VOIDID; /* default (starting) material name */ +char *defpat = ""; /* default (starting) picture name */ +char *defobj = "T"; /* default (starting) object name */ + main(argc, argv) /* read in T-mesh files and convert */ int argc; char *argv[]; @@ -64,10 +73,27 @@ char *argv[]; FILE *fp; int i; - if (argc == 1) + for (i = 1; i < argc && argv[i][0] == '-'; i++) + switch (argv[i][1]) { + case 'o': /* object name */ + defobj = argv[++i]; + break; + case 'm': /* default material */ + defmat = argv[++i]; + break; + case 'p': /* default picture */ + defpat = argv[++i]; + break; + default: + fprintf(stderr, + "Usage: %s [-o obj][-m mat][-p pic] [file ..]\n", + argv[0]); + exit(1); + } + if (i >= argc) convert("", stdin); else - for (i = 1; i < argc; i++) { + for ( ; i < argc; i++) { if ((fp = fopen(argv[i], "r")) == NULL) { perror(argv[i]); exit(1); @@ -83,18 +109,26 @@ convert(fname, fp) /* convert a T-mesh */ char *fname; FILE *fp; { - char typ[2]; + char typ[4]; int id[3]; double vec[3]; char picfile[128]; char matname[64]; - char *err; - register int c; - register VERTEX *lastv = NULL; + char objname[64]; + register int i; + register VERTEX *lastv; + /* start fresh */ + i = nverts; + lastv = vlist; + while (i--) + (lastv++)->flags = 0; + lastv = NULL; + strcpy(picfile, defpat); + strcpy(matname, defmat); + strcpy(objname, defobj); - picfile[0] = '\0'; - strcpy(matname, "void"); - + printf("\n## T-mesh read from: %s\n", fname); + /* scan until EOF */ while (fscanf(fp, "%1s", typ) == 1) switch (typ[0]) { case 'v': /* vertex */ @@ -108,7 +142,7 @@ FILE *fp; syntax(fname, fp, "Bad triangle"); if (novert(id[0]) | novert(id[1]) | novert(id[2])) syntax(fname, fp, "Undefined triangle vertex"); - triangle(picfile, matname, &vlist[id[0]], + triangle(picfile, matname, objname, &vlist[id[0]], &vlist[id[1]], &vlist[id[2]]); break; case 'n': /* surface normal */ @@ -133,11 +167,15 @@ FILE *fp; lastv->ndx[1] = vec[1]; lastv->flags |= V_HASINDX; break; + case 'o': /* object name */ + if (fscanf(fp, "%s", objname) != 1) + syntax(fname, fp, "Bad object name"); + break; case 'm': /* material */ if (fscanf(fp, "%s", matname) != 1) syntax(fname, fp, "Bad material"); if (matname[0] == '-' && !matname[1]) - strcpy(matname, "void"); + strcpy(matname, VOIDID); break; case 'p': /* picture */ if (fscanf(fp, "%s", picfile) != 1) @@ -146,8 +184,12 @@ FILE *fp; picfile[0] = '\0'; break; case '#': /* comment */ - while ((c = getc(fp)) != EOF && c != '\n') - ; + fputs("\n#", stdout); + while ((i = getc(fp)) != EOF) { + putchar(i); + if (i == '\n') + break; + } break; default: syntax(fname, fp, "Unknown type"); @@ -156,41 +198,46 @@ FILE *fp; } -triangle(pn, mn, v1, v2, v3) /* put out a triangle */ -char *pn, *mn; +triangle(pn, mod, obj, v1, v2, v3) /* put out a triangle */ +char *pn, *mod, *obj; register VERTEX *v1, *v2, *v3; { static int ntri = 0; - char *mod = mn; BARYCCM bvecs; + FLOAT bvm[3][3]; + register int i; /* compute barycentric coordinates */ if (v1->flags & v2->flags & v3->flags & (V_HASINDX|V_HASNORM)) - if (comp_baryc(bvecs, v1->pos, v2->pos, v3->pos) < 0) + if (comp_baryc(&bvecs, v1->pos, v2->pos, v3->pos) < 0) return; /* put out texture (if any) */ if (v1->flags & v2->flags & v3->flags & V_HASNORM) { printf("\n%s texfunc %s\n", mod, TEXNAME); mod = TEXNAME; - printf("4 dx dy dz %s\n", CALNAME); - printf("0\n21\n"); - put_baryc(bvecs); - printf("\t%f %f %f\n", v1->nor[0], v1->nor[1], v1->nor[2]); - printf("\t%f %f %f\n", v2->nor[0], v2->nor[1], v2->nor[2]); - printf("\t%f %f %f\n", v3->nor[0], v3->nor[1], v3->nor[2]); + printf("4 dx dy dz %s\n", TCALNAME); + printf("0\n"); + for (i = 0; i < 3; i++) { + bvm[i][0] = v1->nor[i]; + bvm[i][1] = v2->nor[i]; + bvm[i][2] = v3->nor[i]; + } + put_baryc(&bvecs, bvm, 3); } /* put out pattern (if any) */ if (*pn && (v1->flags & v2->flags & v3->flags & V_HASINDX)) { printf("\n%s colorpict %s\n", mod, PATNAME); mod = PATNAME; - printf("7 noneg noneg noneg %s %s u v\n", pn, CALNAME); - printf("0\n18\n"); - put_baryc(bvecs); - printf("\t%f %f\n", v1->ndx[0], v1->ndx[1]); - printf("\t%f %f\n", v2->ndx[0], v2->ndx[1]); - printf("\t%f %f\n", v3->ndx[0], v3->ndx[1]); + printf("7 noneg noneg noneg %s %s u v\n", pn, TCALNAME); + printf("0\n"); + for (i = 0; i < 2; i++) { + bvm[i][0] = v1->ndx[i]; + bvm[i][1] = v2->ndx[i]; + bvm[i][2] = v3->ndx[i]; + } + put_baryc(&bvecs, bvm, 2); } /* put out triangle */ - printf("\n%s polygon t%d\n", mod, ++ntri); + printf("\n%s polygon %s.%d\n", mod, obj, ++ntri); printf("0\n0\n9\n"); printf("%18.12g %18.12g %18.12g\n", v1->pos[0],v1->pos[1],v1->pos[2]); printf("%18.12g %18.12g %18.12g\n", v2->pos[0],v2->pos[1],v2->pos[2]); @@ -198,56 +245,6 @@ register VERTEX *v1, *v2, *v3; } -int -comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */ -register BARYCCM bcm; -FVECT v1, v2, v3; -{ - FLOAT *vt; - FVECT va, vab, vcb; - double d; - register int i, j; - - for (j = 0; j < 3; j++) { - for (i = 0; i < 3; i++) { - vab[i] = v1[i] - v2[i]; - vcb[i] = v3[i] - v2[i]; - } - d = DOT(vcb,vcb); - if (d <= FTINY) - return(-1); - d = DOT(vcb,vab)/d; - for (i = 0; i < 3; i++) - va[i] = vab[i] - vcb[i]*d; - d = DOT(va,va); - if (d <= FTINY) - return(-1); - for (i = 0; i < 3; i++) { - va[i] /= d; - bcm[j][i] = va[i]; - } - bcm[j][3] = -DOT(v2,va); - /* rotate vertices */ - vt = v1; - v1 = v2; - v2 = v3; - v3 = vt; - } - return(0); -} - - -put_baryc(bcm) /* put barycentric coord. vectors */ -register BARYCCM bcm; -{ - register int i; - - for (i = 0; i < 3; i++) - printf("%14.8f %14.8f %14.8f %14.8f\n", - bcm[i][0], bcm[i][1], bcm[i][2], bcm[i][3]); -} - - VERTEX * vnew(id, x, y, z) /* create a new vertex */ register int id; @@ -255,9 +252,9 @@ double x, y, z; { register int i; - if (id > nverts) { /* get some more */ + if (id >= nverts) { /* get some more */ i = nverts; - nverts = CHUNKSIZ*((id%CHUNKSIZ)+1); + nverts = CHUNKSIZ*((id/CHUNKSIZ)+1); if (vlist == NULL) vlist = (VERTEX *)malloc(nverts*sizeof(VERTEX)); else @@ -268,10 +265,10 @@ double x, y, z; "Out of memory while allocating vertex %d\n", id); exit(1); } - while (i < nverts) /* clear them */ + while (i < nverts) /* clear what's new */ vlist[i++].flags = 0; } - /* assign it */ + /* assign new vertex */ vlist[id].pos[0] = x; vlist[id].pos[1] = y; vlist[id].pos[2] = z; @@ -292,7 +289,7 @@ char *er; int lineno; if (fp == stdin) - fprintf(stderr, "%s: syntax error: %s\n", fn, er); + fprintf(stderr, "%s: T-mesh format error: %s\n", fn, er); else { cpos = ftell(fp); fseek(fp, 0L, 0); @@ -303,7 +300,7 @@ char *er; if (c == '\n') lineno++; } - fprintf(stderr, "%s: syntax error at line %d: %s\n", + fprintf(stderr, "%s: T-mesh format error at line %d: %s\n", fn, lineno, er); } exit(1);
